vtkGenericPropertyDecorator Class Reference
vtkGenericPropertyDecorator is a vtkPropertyDecorator that supports multiple common use cases from a vtkPropertyDecorator. More...
#include <vtkGenericPropertyDecorator.h>
Inheritance diagram for vtkGenericPropertyDecorator:
Collaboration diagram for vtkGenericPropertyDecorator:
typedef vtkPropertyDecorator Superclass
- Public Types inherited from vtkPropertyDecorator
enum  { VisibilityChangedEvent = vtkCommand::UserEvent + 1000, EnableStateChangedEvent = vtkCommand::UserEvent + 1001 }
 This event is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void Initialize (vtkPVXMLElement *config, vtkSMProxy *proxy) override
 Constructor. More...
bool CanShow (bool showAdvanced) const override
 Methods overridden from vtkPropertyDecorator. More...
bool Enable () const override
 Override this method to override the enable state of the widget in the panel. More...
void UpdateState ()
- Public Member Functions inherited from vtkPropertyDecorator
virtual bool CanShow (bool vtkNotUsed(showAdvanced)) const
 Override this method to override the visibility of the widget in the panel. More...
static vtkGenericPropertyDecoratorNew ()
static vtkGenericPropertyDecoratorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPropertyDecorator
static vtkPropertyDecoratorNew ()
static vtkPropertyDecoratorSafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkPropertyDecoratorCreate (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Creates a new decorator, given the xml config and the proxy containing the property For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). More...
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkGenericPropertyDecorator ()
 ~vtkGenericPropertyDecorator () override
- Protected Member Functions inherited from vtkPropertyDecorator
 vtkPropertyDecorator ()
 ~vtkPropertyDecorator () override
vtkPVXMLElementXML () const
vtkSMProxyProxy () const
void InvokeVisibilityChangedEvent ()
void InvokeEnableStateChangedEvent ()
The use cases supported are as follows:
Definition at line 28 of file vtkGenericPropertyDecorator.h.
Definition at line 33 of file vtkGenericPropertyDecorator.h.
◆ vtkGenericPropertyDecorator()
vtkGenericPropertyDecorator::vtkGenericPropertyDecorator ( )
◆ ~vtkGenericPropertyDecorator()
vtkGenericPropertyDecorator::~vtkGenericPropertyDecorator ( )
static vtkGenericPropertyDecorator* vtkGenericPropertyDecorator::New ( )
virtual const char* vtkGenericPropertyDecorator::GetClassName ( )
Reimplemented from vtkPropertyDecorator.
static int vtkGenericPropertyDecorator::IsTypeOf ( const char *  type)
virtual int vtkGenericPropertyDecorator::IsA ( const char *  type)
static vtkGenericPropertyDecorator* vtkGenericPropertyDecorator::SafeDownCast ( vtkObject o)
void vtkGenericPropertyDecorator::PrintSelf ( ostream &  os,
◆ Initialize()
void vtkGenericPropertyDecorator::Initialize ( vtkPVXMLElement xml,
vtkSMProxy proxy
Constructor.
Parameters
xmlThe XML element from the <Hints/> section for the proxy/property that resulted in the creation of the decorator. Decorators can be provided configuration parameters from the XML.
proxyThe proxy that owns the property of this decorator
◆ CanShow()
bool vtkGenericPropertyDecorator::CanShow ( bool  showAdvanced) const
override
◆ Enable()
bool vtkGenericPropertyDecorator::Enable ( ) const
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
◆ UpdateState()
void vtkGenericPropertyDecorator::UpdateState ( )
