vtkOSPRayHidingDecorator Class Reference
vtkOSPRayHidingDecorator's purpose is to prevent the GUI from showing any of the RayTracing specific rendering controls when Paraview is not configured with PARAVIEW_ENABLE_RAYTRACING More...
#include <vtkOSPRayHidingDecorator.h>
Inheritance diagram for vtkOSPRayHidingDecorator:
Collaboration diagram for vtkOSPRayHidingDecorator:
typedef vtkPropertyDecorator Superclass
- Public Types inherited from vtkPropertyDecorator
enum  { VisibilityChangedEvent = vtkCommand::UserEvent + 1000, EnableStateChangedEvent = vtkCommand::UserEvent + 1001 }
 This event is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
bool CanShow (bool showAdvanced) const override
 Overridden to hide the widget when OSPRay is not compiled in. More...
- Public Member Functions inherited from vtkPropertyDecorator
virtual void Initialize (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Constructor. More...
virtual bool CanShow (bool vtkNotUsed(showAdvanced)) const
 Override this method to override the visibility of the widget in the panel. More...
virtual bool Enable () const
 Override this method to override the enable state of the widget in the panel. More...
static vtkOSPRayHidingDecoratorNew ()
static vtkOSPRayHidingDecoratorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPropertyDecorator
static vtkPropertyDecoratorNew ()
static vtkPropertyDecoratorSafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkPropertyDecoratorCreate (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Creates a new decorator, given the xml config and the proxy containing the property For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). More...
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkOSPRayHidingDecorator ()=default
 ~vtkOSPRayHidingDecorator () override=default
- Protected Member Functions inherited from vtkPropertyDecorator
 vtkPropertyDecorator ()
 ~vtkPropertyDecorator () override
vtkPVXMLElementXML () const
vtkSMProxyProxy () const
void InvokeVisibilityChangedEvent ()
void InvokeEnableStateChangedEvent ()
Definition at line 14 of file vtkOSPRayHidingDecorator.h.
Definition at line 19 of file vtkOSPRayHidingDecorator.h.
◆ vtkOSPRayHidingDecorator()
vtkOSPRayHidingDecorator::vtkOSPRayHidingDecorator ( )
protecteddefault
◆ ~vtkOSPRayHidingDecorator()
vtkOSPRayHidingDecorator::~vtkOSPRayHidingDecorator ( )
overrideprotecteddefault
static vtkOSPRayHidingDecorator* vtkOSPRayHidingDecorator::New ( )
virtual const char* vtkOSPRayHidingDecorator::GetClassName ( )
Reimplemented from vtkPropertyDecorator.
static int vtkOSPRayHidingDecorator::IsTypeOf ( const char *  type)
virtual int vtkOSPRayHidingDecorator::IsA ( const char *  type)
static vtkOSPRayHidingDecorator* vtkOSPRayHidingDecorator::SafeDownCast ( vtkObject o)
void vtkOSPRayHidingDecorator::PrintSelf ( ostream &  os,
◆ CanShow()
bool vtkOSPRayHidingDecorator::CanShow ( bool  showAdvanced) const
override
