| void | Initialize (vtkPVXMLElement *config, vtkSMProxy *proxy) override |
| | Constructor. More...
| bool | Enable () const override |
| | Overridden to enable/disable the widget based on input data type. More...
| bool | CanShow (bool showAdvanced) const override |
| | Overriden to show or not the widget based on input data type. More...
| virtual bool | CanShow (bool vtkNotUsed(showAdvanced)) const |
| | Override this method to override the visibility of the widget in the panel. More...
vtkSessionTypeDecorator is a vtkPropertyDecorator subclass that can be used to control show/hide or enable/disable state based on the current session.
The XML config for this decorate takes two attributes 'requires' and 'mode'. 'mode' can have values 'visibility' or 'enabled_state' which dictates whether the decorator shows/hides or enables/disables the widget respectively.
'requires' can have values 'remote', 'parallel', 'parallel_data_server', or 'parallel_render_server' indicating if the session must be remote, or parallel with either data server or render server having more than 1 rank, or parallel data-server, or parallel render-server respectively.
Definition at line 23 of file vtkSessionTypeDecorator.h.
