vtkWeakPointer< vtkSMSourceProxy > Source
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
vtkPVDataInformation * LastInformation
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
represents the possible values a property can have
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
vtkPVDataInformation * Information
static vtkSMDomain * New()
int IsInDomain(vtkSMProperty *vtkNotUsed(property)) override
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
domain used to restrict an vtkSMIntVectorProperty values to valid flat-index for a vtkCompositeDataSe...
