| void | Update (vtkSMProperty *input) override |
| | Called when the 'required-property' is modified. More...
| vtkSMSourceProxy * | GetSource () |
| | Returns the source proxy whose data information is returned by GetInformation(). More...
| int | IsInDomain (vtkSMProperty *vtkNotUsed(property)) override |
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| virtual vtkPVDataInformation * | GetInformation () |
| | Get the vtkPVDataInformation which provides the tree structure for the composite dataset. More...
| virtual int | GetSourcePort () |
| | Returns the port for the source proxy from which the data information is obtained by GetInformation(). More...
| virtual int | GetMode () |
| | Mode indicates if the property is interested in all nodes, leaves only or non-leaves only. More...
| virtual void | SetMode (int) |
| virtual int | GetDefaultMode () |
| | DefaultMode controls how the default value for the property is set by SetDefaultValues(). More...
| virtual void | SetDefaultMode (int) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMCompositeTreeDomain () |
| | ~vtkSMCompositeTreeDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | Update (vtkSMInputProperty *iproperty) |
| | Internal implementation called by Update(vtkSMProperty*);. More...
| void | InvokeModifiedIfChanged () |
| void | SetInformation (vtkPVDataInformation *) |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain used to restrict an vtkSMIntVectorProperty values to valid flat-index for a vtkCompositeDataSet.
vtkSMCompositeTreeDomain can be added to a vtkSMIntVectorProperty. This domain requires a vtkSMInputProperty which is used to provide the input to the filter. This domain obtains data information from the input selected on the required input property and then decides the range for values the property can have.
Broadly speaking, there are two ways of identifying unique node in a composite dataset: flat-index (also called composite-index) and level-block-index. flat-index applies to all types of composite datasets while level-block-index (or just level-index) applies only to AMR datasets. flat-index for any node in an arbitrary composite-dataset is simply the index of that node in a pre-order traversal of the tree with the root composite-dataset getting the index 0. level-index for an AMR dataset is the AMR level number while level-block-index is a pair of the AMR level number and block number for the node in that level.
The type of index the property expects, is defined by the domain's mode. Supported modes are:
- vtkSMCompositeTreeDomain::ALL: (default)
The property uses flat-index and can accept index for any node (leaf or non-leaf). This can be specified in XML using the mode="all".
- vtkSMCompositeTreeDomain::LEAVES:
The property uses flat-index however can only accept flat-indices for leaf-nodes. This can be specified in XML using the mode="leaves".
- vtkSMCompositeTreeDomain::AMR:
The property uses level-index i.e. AMR level number or level-block-index. If the property has 2 elements (or for repeatable properties, if number of elements per command is 2) then level-block-index is used, otherwise simply the level-index is used. This only makes sense for filters dealing with AMR datasets. This can be specified in XML using the mode="amr".
- vtkSMCompositeTreeDomain::NON_LEAVES: (deprecated)
No longer supported (as of ParaView 5.4) and simply interpreted as vtkSMCompositeTreeDomain::ALL. This used to be specified in XML using the mode="non-leaves".
vtkSMCompositeTreeDomain also provides ability to set default value on the property. If mode is LEAVES, then the default value selected is the first non-null leaf node. If mode is ALL, the same behaviour for default value is possible by using default_mode="nonempty-leaf" in XML. e.g.
<CompositeTreeDomain name="tree" mode="all" default_mode="nonempty-leaf">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</CompositeTreeDomain>
Definition at line 86 of file vtkSMCompositeTreeDomain.h.
