vtkSMChartSeriesSelectionDomain.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
41 #ifndef vtkSMChartSeriesSelectionDomain_h
42 #define vtkSMChartSeriesSelectionDomain_h
43
44 #include "vtkRemotingViewsModule.h" // needed for exports
45 #include "vtkSMStringListDomain.h"
46
47 #include <set> // For std::set
48
52
53 class VTKREMOTINGVIEWS_EXPORT vtkSMChartSeriesSelectionDomain : public vtkSMStringListDomain
54 {
55 public:
58  void PrintSelf(ostream& os, vtkIndent indent) override;
59
64  void Update(vtkSMProperty*) override;
65
67  {
72  VALUE
73  };
74
79  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
80
82
85  vtkGetMacro(DefaultMode, int);
87
91  static void AddSeriesVisibilityDefault(const char* regex, bool value);
92
97  static void SetLoadNoChartVariables(bool choice)
98  {
100  }
102
103  vtkSetStringMacro(DefaultValue);
104
105 protected:
108
112  vtkPVDataInformation* GetInputInformation();
113
117  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
118
122  virtual bool GetDefaultSeriesVisibility(const char*);
123
128  virtual std::vector<std::string> GetDefaultValue(const char* series);
129
135  virtual void PopulateAvailableArrays(const std::string& blockName,
136  std::vector<std::string>& strings, vtkPVDataInformation* dataInfo, int fieldAssociation,
137  bool flattenTable);
138
144  virtual void PopulateArrayComponents(vtkChartRepresentation* chartRepr,
145  const std::string& blockName, std::vector<std::string>& strings,
146  std::set<std::string>& unique_strings, vtkPVArrayInformation* dataInfo, bool flattenTable);
147
153  virtual void SetDefaultVisibilityOverride(const std::string& arrayname, bool visibility);
154
156
158
163
168
173
174  static bool LoadNoVariables;
175
176 private:
178  void operator=(const vtkSMChartSeriesSelectionDomain&) = delete;
179
180  class vtkInternals;
181  vtkInternals* Internals;
182
183  // The EXPERIMENTAL feature: everytime domain is modified we update the
184  // property's value.
185  void OnDomainModified();
186  void UpdateDefaultValues(vtkSMProperty*, bool preserve_previous_values);
187 };
188
189 #endif
Light object for holding data information.
char * DefaultValue
Value used when DefaultMode==VALUE.
extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-p...
Global flag to toggle between (a) the default behavior and (b) setting default visibility to off...
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
bool HidePartialArrays
Specify if Partial Arrays should be hidden.
void Update(vtkSMProperty *) override
Update self checking the "unchecked" values of all required properties.
vtkSMDomainInternals * Internals
Definition: vtkSMDomain.h:281
Data array information like type.
vtkChartRepresentation is the base representation for charting representations.
static vtkSMStringListDomain * New()
bool FlattenTable
Specify if table components should be split.
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
