pqScalarsToColors.h
3  Program: ParaView
4  Module: pqScalarsToColors.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef pqScalarsToColors_h
33 #define pqScalarsToColors_h
35 #include "pqProxy.h"
36 #include <QList>
37 #include <QPair>
38 #include <QVariant>
40 class pqRenderViewBase;
42 class pqScalarsToColorsInternal;
43
47 class PQCORE_EXPORT pqScalarsToColors : public pqProxy
48 {
49  Q_OBJECT
50 public:
51  pqScalarsToColors(const QString& group, const QString& name, vtkSMProxy* proxy, pqServer* server,
52  QObject* parent = NULL);
53  ~pqScalarsToColors() override;
54
59  pqScalarBarRepresentation* getScalarBar(pqRenderViewBase* ren) const;
60
64  bool getScalarRangeLock() const;
65
71  void setScalarRange(double min, double max);
72
78  QPair<double, double> getScalarRange() const;
79
83  bool getUseLogScale() const;
84
85  enum Mode
86  {
87  MAGNITUDE = 0,
88  COMPONENT = 1
89  };
90
91  // Set the color mode (component/magnitude) and
92  // component to color by. When mode is magnitude, component is ignored.
93  void setVectorMode(Mode mode, int component);
94
95  // Returns the vector mode and component used by the Lookup table.
96  // When vector mode is MAGNITUDE, value returned by
97  // getVectorComponent() is indeterminate.
98  Mode getVectorMode() const;
99  int getVectorComponent() const;
100
105  void updateScalarBarTitles(const QString& component);
106
108  {
109  GROW_ON_MODIFIED, /* only when a pipeline object is explicitly modified */
110  GROW_ON_UPDATED /* any time the pipeline updates */
111  };
112
125  static void setColorRangeScalingMode(int);
126  static int colorRangeScalingMode(int default_value = GROW_ON_MODIFIED);
127
128 Q_SIGNALS:
133  void componentOrModeChanged();
134
135 public Q_SLOTS:
136  // This method checks if this LUT is used by any display,
137  // if not, it hides all the scalars bar showing this LUT.
138  void hideUnusedScalarBars();
139
143  void setScalarRangeLock(bool lock);
144
148  void build();
149
150 protected Q_SLOTS:
155  void checkRange();
156
157 private:
158  pqScalarsToColorsInternal* Internal;
159 };
160
161 #endif
pqScalarsToColors is a represents a vtkScalarsToColors proxy.
name
pqScalarBarRepresentation is created for "ScalarBarWidgetRepresentation" proxies. ...
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
pqRenderViewBase is an abstract base class for all render-view based views.
Definition: vtkSMProxy.h:152
#define max(a, b)
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
