pqAnimationCue.h
3  Program: ParaView
4  Module: pqAnimationCue.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqAnimationCue_h
33 #define pqAnimationCue_h
35 #include "pqProxy.h"
36
37 class vtkSMProxy;
38 class vtkSMProperty;
40 class PQCORE_EXPORT pqAnimationCue : public pqProxy
41 {
42  Q_OBJECT
43  typedef pqProxy Superclass;
45 public:
46  pqAnimationCue(const QString& group, const QString& name, vtkSMProxy* proxy, pqServer* server,
47  QObject* parent = NULL);
48  ~pqAnimationCue() override;
49
50  // Returns the number of keyframes in this cue.
51  int getNumberOfKeyFrames() const;
52
53  // Returns a list of the keyframes.
54  QList<vtkSMProxy*> getKeyFrames() const;
55
56  // Insert a new keyframe at the given index.
57  // The time for the key frame is computed using the times
58  // for the neighbouring keyframes if any.
59  // Returns the newly created keyframe proxy on success,
60  // NULL otherwise.
61  vtkSMProxy* insertKeyFrame(int index);
62
63  // Deletes the keyframe at the given index.
64  // Consequently, the keyframesModified() signal will get fired.
65  void deleteKeyFrame(int index);
66
67  // Returns keyframe at a given index, if one exists,
68  // NULL otherwise.
69  vtkSMProxy* getKeyFrame(int index) const;
70
71  // Returns the animated proxy, if any.
72  vtkSMProxy* getAnimatedProxy() const;
73
74  // Returns the property that is animated by this cue, if any.
75  vtkSMProperty* getAnimatedProperty() const;
76
77  // Returns the index of the property being animated.
78  int getAnimatedPropertyIndex() const;
79
84  void setKeyFrameType(const QString& type) { this->KeyFrameType = type; }
85
90  void triggerKeyFramesModified() { Q_EMIT this->keyframesModified(); }
91
95  void setEnabled(bool enable);
96  bool isEnabled() const;
97
98 Q_SIGNALS:
99  // emitted when something about the keyframes changes.
100  void keyframesModified();
101
102  // Fired when the animated proxy/property/index
103  // changes.
104  void modified();
105
109  void enabled(bool);
110
111 private Q_SLOTS:
115  void onEnabledModified();
116
117 private:
118  Q_DISABLE_COPY(pqAnimationCue)
119
120
123  void addKeyFrameInternal(vtkSMProxy*);
124  void removeKeyFrameInternal(vtkSMProxy*);
125  QString KeyFrameType;
126 };
127 #endif
void setKeyFrameType(const QString &type)
Set the type of the keyframe created by default.
name
Used by editors to trigger keyframesModified() signal after bulk of modifications have been made to t...
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
Definition: vtkSMProxy.h:152
enabled
index
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
