Point tooltip mode enables the user to inspect points (coordinates, data array values) by hovering the mouse cursor over a point.
| bool | CanDisplayTooltip (bool &showTooltip) |
| | Return true if a tooltip can be displayed according to the context, otherwise return false. More...
| bool | GetTooltipInfo (int association, std::string &tooltipText) |
| | Get information about the tooltip to be displayed. More...
| bool | GetTooltipInfo (int association, double pos[2], std::string &tooltipText) |
| void | Hide (vtkSMRenderViewProxy *view) override |
| | Re-implemented from vtkSMPreselectionPipeline. More...
| void | Show (vtkSMSourceProxy *sourceRepresentation, vtkSMSourceProxy *selection, vtkSMRenderViewProxy *view) override |
| void | CopyLabels (vtkSMProxy *representation) |
| | Copies the labels for interactive selection from the selection labels in the representation parameter. More...
| virtual vtkSMProxy * | GetSelectionRepresentation () const |
| | Get/Create the interactive selection representation. More...
| virtual vtkSMProxy * | GetOrCreateSelectionRepresentation () |
| virtual vtkSMProxy * | CreateSelectionRepresentation (vtkSMSourceProxy *extract) |
| | vtkSMTooltipSelectionPipeline () |
| | ~vtkSMTooltipSelectionPipeline () override |
| void | ClearCache () override |
| vtkDataObject * | ConnectPVMoveSelectionToClient (vtkSMSourceProxy *source, unsigned int sourceOutputPort) |
| | Connect the ClientServerMoveData filter to the pipeline to get the selection on the client side. More...
| bool | GetCurrentSelectionId (vtkSMRenderViewProxy *view, vtkIdType &selId) |
| | Get the id of the selected point. More...
| vtkDataSet * | FindDataSet (vtkDataObject *dataObject, bool &compositeFound, std::string &compositeName) |
| | Extract dataset from the dataObject, which can be either directly a dataset or a composite dataset containing only one dataset. More...
| | vtkSMPreselectionPipeline () |
| | ~vtkSMPreselectionPipeline () override |
| vtkSMSourceProxy * | ConnectPVExtractSelection (vtkSMSourceProxy *source, unsigned int sourceOutputPort, vtkSMSourceProxy *selection) |
| | vtkObject () |
| | vtkObjectBase () |
This is a global object that holds the pipeline for showing the point tooltip mode.
- See also
- vtkSMPreselectionPipeline vtkSMInteractiveSelectionPipeline
Definition at line 39 of file vtkSMTooltipSelectionPipeline.h.
