| | Update the domain. More...
| virtual bool | GetUseTrueParentForRepresentatedDataInformation () |
| | Set this to true (default) to let this domain use the represented-data-information from the outer most representation proxy. More...
Public Member Functions inherited from vtkSMArrayListDomain |
| int | IsArrayPartial (unsigned int idx) |
| | Returns true if the array with the given idx is partial false otherwise. More...
| int | GetFieldAssociation (unsigned int idx) |
| | Get field association for the array. More...
| int | GetDomainAssociation (unsigned int idx) |
| | Get the true field association for the array. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| unsigned int | RemoveInformationKey (const char *location, const char *name) |
| | Removes an InformationKey from this domain. More...
| unsigned int | GetNumberOfInformationKeys () |
| | Returns the number of InformationKeys in this domain. More...
| void | RemoveAllInformationKeys () |
| | Removes all InformationKeys from this domain. More...
| virtual int | GetAttributeType () |
| | Return the attribute type. More...
| virtual unsigned int | AddInformationKey (const char *location, const char *name, int strategy) |
| | Adds a new InformationKey to the domain. More...
| virtual unsigned int | AddInformationKey (const char *location, const char *name) |
| const char * | GetInformationKeyLocation (unsigned int) |
| | Returns the location/name/strategy of a given InformationKey. More...
| const char * | GetInformationKeyName (unsigned int) |
| int | GetInformationKeyStrategy (unsigned int) |
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMRepresentedArrayListDomain () |
| | ~vtkSMRepresentedArrayListDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override |
| | Overridden to process "use_true_parent". More...
| bool | IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName) override |
| | Returns true if an array should be filtered out based on its name or number of tuples (for field data arrays). More...
| vtkPVDataInformation * | GetExtraDataInformation () override |
| | HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More...
| void | SetRepresentationProxy (vtkSMRepresentationProxy *) |
| void | OnRepresentationDataUpdated () |
| virtual void | SetUseTrueParentForRepresentatedDataInformation (bool) |
Protected Member Functions inherited from vtkSMArrayListDomain |
| | vtkSMArrayListDomain () |
| | ~vtkSMArrayListDomain () override |
| virtual char * | GetInputDomainName () |
| | InputDomainName refers to a input property domain that describes the type of array is needed by this property. More...
| virtual void | SetInputDomainName (const char *) |
| virtual void | SetAttributeType (int) |
| | Set to an attribute type defined in vtkDataSetAttributes. More...
Protected Member Functions inherited from vtkSMStringListDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
extends vtkSMArrayListDomain to add support for arrays from represented data information.
Representations often add new arrays on top of the ones provided by the inputs to the representations. In that case, the domains for properties that allow users to pick one of those newly added arrays need to show those arrays e.g. "ColorArrayName" property of geometry representations. This domain extends vtkSMArrayListDomain to add arrays from represented data for representations. If the chosen attribute type is not present on the data, no array (or none_string if available) will be chosen.
Definition at line 38 of file vtkSMRepresentedArrayListDomain.h.
