| virtual void | SetFileDescription (const char *) |
| virtual char * | GetFileDescription () |
| virtual void | SetFileExtension (const char *) |
| virtual char * | GetFileExtension () |
| virtual const char * | GetWriterVersion () |
| | Return the writer version string. More...
| virtual int | WriteConfiguration (ostream &os) |
| | Write the proxy's state to a stream, in PV state format. More...
| virtual void | SetProxy (vtkSMProxy *proxy) |
| | Set the proxy to write out. More...
| virtual vtkSMProxy * | GetProxy () |
| virtual void | SetPropertyIterator (vtkSMPropertyIterator *iter) |
| | Set the ieterator used to traverse properties during the write. More...
| virtual vtkSMPropertyIterator * | GetPropertyIterator () |
| virtual void | SetFileName (const char *) |
| | Set/Get the file name. More...
| virtual char * | GetFileName () |
| virtual void | SetFileIdentifier (const char *) |
| | Set/get file meta data. More...
| virtual char * | GetFileIdentifier () |
| virtual int | WriteConfiguration () |
| | Write the proxy's state directly to an XML file, in PV state format. More...
| virtual int | WriteConfiguration (const char *fileName) |
Base readers of a vtkSMProxy's vtkSMProperty's.
vtkSMProxyConfigurationWriter writes state for properties for a single proxy. Internally the ParaView state machinery is employed.
The notion of proxy configuration is similar to state but lighter as the proxy its domains and and its server side objects are assumed to already exist. Configuration also provides subseting mechanism so that properties may be excluded if needed.
Subsetting is achieved through a specialized iterator derived from vtkSMPropertyIterator.
- See also
- vtkSMProxyConfigurationReader, vtkSMPropertyIterator, vtkSMNamedPropertyIterator
- This class was contribued by SciberQuest Inc.
Definition at line 48 of file vtkSMProxyConfigurationWriter.h.
