| bool | Copy (vtkSMProxy *source) |
| | Put a proxy's state on the clipboard. More...
| bool | CanPaste (vtkSMProxy *target) |
| | Returns true of the proxy state on the clipboard can be pasted on to the specified target. More...
| bool | Paste (vtkSMProxy *target) |
| | Paste the state on the clipboard on to the target proxy. More...
| void | Clear () |
| | Clears the clipboard. More...
helper class to help copy/paste properties on proxies.
vtkSMProxyClipboard is a helper class used to enable copy/paste for properties on proxies. Copy/Paste is more that simply copying values from a proxy to another (for which one should simply use vtkSMProxy::Copy()). This has several extra smarts including the following:
- Skips input properties.
- Skips properties that are hidden by setting vtkSMProperty::PanelVisibility to "never".
- Specially handles properties with vtkSMProxyListDomain to select the same type of proxy from the target domain when pasting and then loading the state for the value proxy separately.
- For other vtkSMProxyProperty instances (e.g. LookupTable, ScalarOpacityFunction, etc.) on Paste, it tries to locate the requested proxy value on the session.
Definition at line 46 of file vtkSMProxyClipboard.h.
