| virtual vtkSMProxy * | Show (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view) |
| | Show the output data in the view. More...
| virtual vtkSMProxy * | Show (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view, const char *representationType) |
| void | ShowAll (vtkSMViewProxy *view) |
| | Show all source output ports in provided view. More...
| virtual vtkSMProxy * | Hide (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view) |
| | Opposite of Show(). More...
| virtual void | Hide (vtkSMProxy *repr, vtkSMViewProxy *view) |
| | Same as above, except that when we already have the representation located. More...
| virtual void | HideAll (vtkSMViewProxy *view) |
| | Hide all visible sources output ports in provided view. More...
| vtkSMProxy * | SetVisibility (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view, bool visible) |
| | Alternative method to call Show and Hide using a visibility flag. More...
| virtual bool | GetVisibility (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view) |
| | Returns whether the producer/port are shown in the given view. More...
| virtual vtkSMViewProxy * | ShowInPreferredView (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view) |
| | Same as Show() except that if the view is NULL or not the preferred view for the producer's output, this method will create a new view and show the data in that new view. More...
| virtual const char * | GetPreferredViewType (vtkSMSourceProxy *producer, int outputPort) |
| | Returns the name for the preferred view type, if there is any. More...
| virtual const char * | GetPipelineIcon (vtkSMSourceProxy *producer, int outputPort) |
| | Return the pipeline icon to use with the provided producer. More...
| bool | RegisterRepresentationProxy (vtkSMProxy *proxy) override |
| | Overridden to create color and opacity transfer functions if applicable. More...
| bool | PostInitializeProxy (vtkSMProxy *proxy) override |
| | Overridden to handle default ColorArrayName for representations correctly. More...
| virtual bool | RegisterLayoutProxy (vtkSMProxy *proxy, const char *proxyname=NULL) |
| | Register layout proxy. More...
| virtual void | AssignViewToLayout (vtkSMViewProxy *view, vtkSMViewLayoutProxy *layout=nullptr, int hint=0) |
| | Assigns the view to any cell in the layout. More...
| virtual bool | InitializeSession (vtkSMSession *session) |
| | Call this method to setup a branch new session with state considered essential for ParaView session. More...
| virtual vtkSMProxy * | FindTimeKeeper (vtkSMSession *session) |
| | Returns the TimeKeeper proxy associated with the session. More...
| virtual vtkSMProxy * | FindMaterialLibrary (vtkSMSession *session) |
| | Returns the MaterialLibrary proxy associated with the session. More...
| virtual bool | PreInitializeProxy (vtkSMProxy *proxy) |
| | Pre-initializes a proxy i.e. More...
| bool | InitializeProxy (vtkSMProxy *proxy) |
| | Convenience method to call PreInitializeProxy and PostInitializeProxy. More...
| virtual bool | FinalizeProxy (vtkSMProxy *proxy) |
| | Cleans up any helper proxies registered for the proxy in PreInitializeProxy/PostInitializeProxy. More...
| virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a pipeline proxy with the proxy manager. More...
| virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy) |
| virtual bool | UnRegisterPipelineProxy (vtkSMProxy *proxy) |
| | Unregisters a pipeline proxy. More...
| virtual bool | RegisterViewProxy (vtkSMProxy *proxy) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a view proxy with the proxy manager. More...
| virtual bool | RegisterViewProxy (vtkSMProxy *proxy, const char *proxyname) |
| virtual bool | UnRegisterViewProxy (vtkSMProxy *proxy, bool unregister_representations=true) |
| | Inverse of RegisterViewProxy. More...
| virtual bool | UnRegisterRepresentationProxy (vtkSMProxy *proxy) |
| | Unregisters a representation proxy. More...
| virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Registration method for color transfer function proxies to be used after PreInitializeProxy() and PostInitializeProxy() calls. More...
| virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy) |
| virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy, const char *proxyname) |
| | Registration method for opacity transfer function proxies. More...
| virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy) |
| virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view, const char *proxyname) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a light proxy with the proxy manager. More...
| virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view) |
| virtual bool | RegisterTextureProxy (vtkSMProxy *proxy, const char *filename) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a texture proxy with the proxy manager. More...
| virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Registers an extractor. More...
| virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy) |
| virtual vtkSMProxy * | FindAnimationScene (vtkSMSession *session) |
| | Returns the animation scene, if any. More...
| virtual vtkSMProxy * | GetAnimationScene (vtkSMSession *session) |
| | Returns the animation scene for the session. More...
| virtual vtkSMProxy * | FindTimeAnimationTrack (vtkSMProxy *scene) |
| | Return the animation track for time, if any. More...
| virtual vtkSMProxy * | GetTimeAnimationTrack (vtkSMProxy *scene) |
| | Return the animation track for time. More...
| virtual bool | RegisterAnimationProxy (vtkSMProxy *proxy) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register an animation proxy with the proxy manager. More...
| virtual bool | UnRegisterAnimationProxy (vtkSMProxy *proxy) |
| | Inverse of RegisterAnimationProxy. More...
| virtual void | UpdateSettingsProxies (vtkSMSession *session) |
| | Initializes and registers proxies in the "settings" group that haven't been already. More...
| virtual bool | UnRegisterProxy (vtkSMProxy *proxy) |
| | A catch-all method do cleanup and unregister any proxies that were registered using Register..Proxy() APIs on this class. More...
| | vtkSMParaViewPipelineControllerWithRendering () |
| | ~vtkSMParaViewPipelineControllerWithRendering () override |
| virtual void | UpdatePipelineBeforeDisplay (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view) |
| virtual bool | AlsoShowInCurrentView (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *currentView) |
| | Checks if the output from producer needs to be shown in the current view also. More...
| virtual void | DoMaterialSetup (vtkSMProxy *proxy) override |
| | Overridden here where the library has link access to rendering classes. More...
| | vtkSMParaViewPipelineController () |
| | ~vtkSMParaViewPipelineController () override |
| vtkSMProxy * | FindProxy (vtkSMSessionProxyManager *pxm, const char *reggroup, const char *xmlgroup, const char *xmltype) |
| | Find proxy of the group type (xmlgroup, xmltype) registered under a particular group (reggroup). More...
| virtual bool | SetupGlobalPropertiesLinks (vtkSMProxy *proxy) |
| | Setup global properties links based on hints for properties in the XML. More...
| virtual bool | CreateAnimationHelpers (vtkSMProxy *proxy) |
| | To help animation representation properties such as visibility, opacity, we create animation helpers. More...
| virtual bool | UnRegisterDependencies (vtkSMProxy *proxy) |
| | Unregisters know proxy dependencies that must be removed when the proxy is to be deleted e.g animation cues, representations, etc. More...
| vtkMTimeType | GetInitializationTime (vtkSMProxy *) |
| | Returns the initialization timestamp for the proxy, if available. More...
| void | ProcessInitializationHelperRegistration (vtkSMProxy *) |
| | If the proxy has initialization helpers, let those classes also handle registration tasks, if any. More...
| virtual bool | CreateProxiesForProxyListDomains (vtkSMProxy *proxy) |
| | Creates new proxies for proxies referred in vtkSMProxyListDomain for any of the properties for the given proxy. More...
| virtual void | RegisterProxiesForProxyListDomains (vtkSMProxy *proxy) |
| void | ProcessInitializationHelper (vtkSMProxy *, vtkMTimeType initializationTimeStamp) |
| | Proxies can specify custom initialization using XML hints. More...
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
vtkSMParaViewPipelineControllerWithRendering overrides vtkSMParaViewPipelineController to add support for initializing rendering proxies appropriately.
vtkSMParaViewPipelineControllerWithRendering uses vtkObjectFactory mechanisms to override vtkSMParaViewPipelineController's creation. One should not need to create or use this class directly (excepting when needing to subclass). Simply create vtkSMParaViewPipelineController. If the application is linked with the rendering module, then this class will be instantiated instead of vtkSMParaViewPipelineController automatically.
vtkSMParaViewPipelineControllerWithRendering also adds new API to control representation visibility and manage creation of views. To use that API clients can instantiate vtkSMParaViewPipelineControllerWithRendering. Just like vtkSMParaViewPipelineController, this class also uses vtkObjectFactory mechanisms to enable overriding by clients at compile time.
Definition at line 44 of file vtkSMParaViewPipelineControllerWithRendering.h.
