| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| virtual int | IsInDomain (vtkSMSourceProxy *oldProxy, vtkSMSourceProxy *newProxy) |
| | Returns true if old and new source proxies have the same output data type, false otherwise. More...
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMFixedTypeDomain () |
| | ~vtkSMFixedTypeDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
restricts the proxy to have the same type as previous proxy
vtkSMFixedTypeDomain is used by input properties of filters that can not have different input types after input is set the first time. For example, a sub-class vtkDataSetToDataSetFilter, once connected in a pipeline can not change it's input type, say, from vtkImageData to vtkUnstructuredGrid because it's output can not change.
- See also
- vtkSMDomain
Definition at line 36 of file vtkSMFixedTypeDomain.h.
