| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (vtkSMSourceProxy *proxy, int outputport=0) |
| | Returns true if all parts of the source proxy are in the domain. More...
| unsigned int | GetNumberOfDataTypes () |
| | Returns the number of acceptable data types. More...
| const char * | GetDataTypeName (unsigned int idx) |
| | Returns a data type. More...
| bool | DataTypeHasChildren (unsigned int idx) |
| | Returns if the data type is composite. More...
| const char * | GetDataTypeChildMatchTypeAsString (unsigned int idx) |
| | Returns if the child match type of a composite data type. More...
| const std::vector< std::string > & | GetDataTypeChildren (unsigned int idx) |
| | Returns the allowed child types of a composite data type. More...
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMDataTypeDomain () |
| | ~vtkSMDataTypeDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| virtual void | SetCompositeDataSupported (int) |
| virtual int | GetCompositeDataSupported () |
| virtual void | SetCompositeDataRequired (int) |
| virtual int | GetCompositeDataRequired () |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
restricts the input proxies to one or more data types
vtkSMDataTypeDomain restricts the input proxies to one or more data types. These data types are specified in the XML with the <DataType> element. VTK class names are used. It is possible to specify a superclass (i.e. vtkDataSet) for a more general domain. Works with vtkSMSourceProxy only. Valid XML elements are:
* * <DataType value=""> where value is the classname for the data type
* for example: vtkDataSet, vtkImageData,...
Optional XML attributes for composite datasets only:
child_match : Value can be "any" or "all". This is used if specific types of child datasets are required. "any" indicates that composite datasets with any child matching the nested data types are in the domain. "all" indicates that all the child datasets must match the nested data types(can be mix-match). Example: <DataType
value=
"vtkCompositeDataSet" child_match=
"any">
<DataType value="vtkImageData" />
</DataType>
<DataType value="vtkMultiBlockDataSet" child_match="all">
<DataType value="vtkUnstructuredGrid" />
</DataType>
The first element accepts vtkCompositeDataSet with at least one child dataset of vtkImageData. The second element accepts vtkMultiBlockDataSet with all the child datasets being either vtkImageData or vtkUnstructuredGrid.
- See also
- vtkSMDomain vtkSMSourceProxy
Definition at line 64 of file vtkSMDataTypeDomain.h.
