vtkCPPipeline for Catalyst Python script / package version 2.0 More...
#include <vtkCPPythonScriptV2Pipeline.h>
| typedef vtkCPPythonPipeline | Superclass |
Public Types inherited from vtkCPPythonPipeline | |
| typedef vtkCPPipeline | Superclass |
Public Types inherited from vtkCPPipeline | |
| bool | Initialize (const char *filename) |
| Initialize from a zip archive. More... | |
| int | RequestDataDescription (vtkCPDataDescription *dataDescription) override |
| Implementation for vtkCPPipeline API. More... | |
| int | CoProcess (vtkCPDataDescription *dataDescription) override |
| int | Finalize () override |
| static vtkCPPythonScriptV2Pipeline * | New () |
| static vtkCPPythonScriptV2Pipeline * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkCPPythonPipeline | |
| static vtkCPPythonPipeline * | SafeDownCast (vtkObject *o) |
| static int | DetectScriptVersion (const char *fname) |
| Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More... | |
| static vtkSmartPointer< vtkCPPythonPipeline > | CreatePipeline (const char *fname, int default_version=1) |
| Detects the script version, if possible and created appropriate subclass. More... | |
| static vtkSmartPointer< vtkCPPythonPipeline > | CreateAndInitializePipeline (const char *fname, int default_version=1) |
Same as CreatePipeline, except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More... | |
| static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewPipeline (const char *fname, int default_version=1) |
These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More... | |
| static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewAndInitializePipeline (const char *fname, int default_version=1) |
Static Public Member Functions inherited from vtkCPPipeline | |
| static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
| vtkCPPythonScriptV2Pipeline () | |
| ~vtkCPPythonScriptV2Pipeline () | |
Protected Member Functions inherited from vtkCPPythonPipeline | |
| void | FixEOL (std::string &) |
| For things like programmable filters that have a ' ' in their strings, we need to fix them to have \n so that everything works smoothly. More... | |
| std::string | GetPythonAddress (void *pointer) |
| Return the address of Pointer for the python script. More... | |
| vtkCPPythonPipeline () | |
| ~vtkCPPythonPipeline () override | |
Protected Member Functions inherited from vtkCPPipeline | |
| vtkCPPipeline () | |
| virtual | ~vtkCPPipeline () |
vtkCPPythonScriptV2Pipeline is intended to use with ParaView Python scripts introduced in ParaView version 5.9. These Python scripts typically use extract generators to define the extracts to be generated. This class is used to use such packages in Catalyst.
For details on the supported Python scripts and how to use them to write in situ analysis, refer to 'Anatomy of Catalyst Python Module (Version 2.0)'.
Definition at line 38 of file vtkCPPythonScriptV2Pipeline.h.
Definition at line 42 of file vtkCPPythonScriptV2Pipeline.h.
Reimplemented from vtkCPPythonPipeline.
Reimplemented from vtkCPPipeline.
| bool vtkCPPythonScriptV2Pipeline::Initialize | ( | const char * | filename | ) |
If the packagename is not specified, then the it is assumed to be the same as the filename for the zip archive without the extension.
For HPC use-cases, this is the preferred approach since we ensure that only the root node makes disk access thus avoid thrashing the IO subsystem and improving load times.
Implements vtkCPPipeline.
