This page describes the details of Python modules intended for use in Catalyst. This page covers features supported by ParaView 5.9 and later i.e. version 2.0.
Basics
Catalyst Python modules are simply Python scripts that use the paraview package to define data analysis and visualization pipelines. You use these modules to define the analysis pipelines to be executed in a Catalyst-instrumented simulation code, for example.
Python defines a module as a file containing Python definitions and statements. The file name for a module is the name of the module suffixed by extension .py. Thus a module named foo will be in a file named foo.py.
Packages are a mechanism for structuring multiple modules. Essentially, if you place a bunch of .py files (aka modules) in a directory structure, that becomes a package! Of course, there's a little more to that and the Python docs are a highly recommended read. Similar to the convection to name a module using the file name, the name of the directory representing a Python package becomes the name of the package. A package can contain multiple directories (sub-packages) and Python files.
When a Python module is imported into the application, the Python statements in the module are executed. Since a Python module is a file, the execution starts with the first statement in the file and continues till the end of the file is reached or an error is encountered.
When a Python package is imported, the entry-point is defined by a file named __init__.py with in the package. Statements in this file are executed. In the simplest case, __init__.py can be an empty file, but it can also execute initialization code, including importing other modules, packages, sub-packages etc.
Catalyst Python code can be structured as modules or packages. In either case, the module (or package) is imported and then functions or variables defined on the module (or package) are checked and invoked as described in following sections.
Catalyst adaptors should use vtkCPPythonScriptV2Pipeline to execute scripts as described in this document. For older Catalyst Python scripts, i.e. those that use RequestDataDescription and DoCoProcess functions, should continue to use vtkCPPythonScriptPipeline and vtkCPPythonStringPipeline at this time. It is conceivable that we provide a wrapper that lets us use vtkCPPythonScriptV2Pipeline for these older script too, however, that has not been implemented at this time.
vtkCPPythonPipeline::DetectScriptVersion may be used to detect the version number for the script. The logic relies on the file type and presence of certain comments in the header of the file to determine which version it may be.
Adaptors may use vtkCPPythonPipeline::CreatePipeline to create appropriate vtkCPPythonPipeline subclass based on the script version.
Structure
Now, let's look at the structure of a Catalyst Python module. The same is applicable to a Python package as well.
Visualization Pipeline
ParaView Python API, exposed via the paraview.simple module, is used to define the visualization and data analysis pipeline. The API mimics actions one would take the GUI. For example, simple script to create a Wavelet source and slice it, looks as follows:
from paraview.simple import *
from paraview import print_info
print_info("begin '%s'", __name__)
wavelet1 = Wavelet(registrationName='Wavelet1')
slice1 = Slice(registrationName='Slice1', Input=wavelet1)
slice1.SliceType = 'Plane'
slice1.SliceType.Normal = [0, 0, 1]
print_info("end '%s'", __name__)
This same code can be used in a Catalyst Python script to setup the visualization pipeline. The only thing to note is that we need a mechanism to indicate which of the data-producers in the pipeline should be replaced by the data generated by the simulation. In Catalyst, the data produced by the simulation is available on named channels. Thus, we need to identify which named-channel corresponds to which data data-producer in the pipeline. For that, we use the registrationName attribute. In the Python script, when creating a source or a filter, one can pass in an optional argument registrationName. When the script is being executed within Catalyst, Catalyst looks to see if the registrationName matches the name of a known channel. If so, the data producer type requested (in this case Wavelet) is ignored and instead is replaced by a producer that provides simulation data as the output.
The paraview.demos.wavelet_miniapp is a miniapp that acts as a simulation producing a time value vtkImageData dataset. So we can use it to run the above script as follows:
> pvbatch -m paraview.demos.wavelet_miniapp
--script .../sample1.py
--script-version 2
--timesteps 2
( 0.550s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.830s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/2
( 1.897s) [pvbatch ] sample1.py:6 INFO| begin 'sample1'
( 1.933s) [pvbatch ] sample1.py:16 INFO| end 'sample1'
( 1.933s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample1' missing Catalyst 'options', will use a default options object
( 1.936s) [pvbatch ]vtkCPPythonScriptV2Help:432 WARN| script may not depend on simulation data; is that expected?
( 1.937s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/2
( 1.985s) [pvbatch ]vtkCPPythonScriptV2Help:432 WARN| script may not depend on simulation data; is that expected?
Let's inspect the warnings to understand what's going on.
bridge.py:17 warning can be ignored for now. The INFO messages are produced by wavelet_miniapp.py to provide information about the timestep as it progresses through the mock-simulation timesteps.
`Module 'sample1' missing Catalyst 'options', will use a default options object` warning lets us know that the Catalyst will default 'options'. More on that later.
script may not depend on simulation data; is that expected? tells us that the pipeline we've setup in this script does not use any data produced by the simulation at all. While there's nothing wrong with that, it's highly unlikely that that's the intent and hence this warning is posted.
In our case, we want the Wavelet source to be replaced by the simulation data. As mentioned, this means the registrationName should match the simulation channel name. wavelet_miniapp uses input as the default channel name. It can be changed using -c (or --channel) command line argument. Let's rename the channel using --channel.
--script-version 2
--timesteps 2
--channel Wavelet1
( 0.563s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.876s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/2
( 1.944s) [pvbatch ] sample1.py:6 INFO| begin 'sample1'
( 2.069s) [pvbatch ] sample1.py:16 INFO| end 'sample1'
( 2.069s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample1' missing Catalyst 'options', will use a default options object
( 2.072s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/2
Great! Now the warnings about simulation data have disappeared.
The pipeline, however, still doesn't do anything significant.
Also, the code in the module seems to execute only once, for the first timestep. This is confirmed by the fact that the print_info statements in sample.py only show up once in the output. This is because the code in the module gets executed only when its imported for the first time. Once imported, which happens on first timestep, the module is not re-imported and hence the code is not re-executed.
To add code that gets executed each iteration, you can define a catalyst_execute function. Likewise, catalyst_initialize and catalyst_finalize functions may be defined too and they will get called for the first and after the last timestep respectively. Here's an example script to see that in action.
w = Wavelet(registrationName="Wavelet1")
def catalyst_initialize():
print_info("in '%s::catalyst_initialize'", __name__)
def catalyst_execute(info):
print_info("in '%s::catalyst_execute'", __name__)
def catalyst_finalize():
print_info("in '%s::catalyst_finalize'", __name__)
When executed using the wavelet_miniapp (this time, let's execute for 3 timesteps just to make things a little clearer), we get the following:
> ./bin/pvbatch -m paraview.demos.wavelet_miniapp
--script /tmp/sample2.py
--script-version 2
--timesteps 3
--channel Wavelet1
( 0.559s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.865s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/3
( 1.933s) [pvbatch ] sample2.py:6 INFO| begin 'sample2'
( 1.939s) [pvbatch ] sample2.py:20 INFO| end 'sample2'
( 1.939s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample2' missing Catalyst 'options', will use a default options object
( 1.943s) [pvbatch ] sample2.py:11 INFO| in 'sample2::catalyst_initialize'
( 1.943s) [pvbatch ] sample2.py:14 INFO| in 'sample2::catalyst_execute'
( 1.943s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/3
( 1.994s) [pvbatch ] sample2.py:14 INFO| in 'sample2::catalyst_execute'
( 1.994s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 3/3
( 2.043s) [pvbatch ] sample2.py:14 INFO| in 'sample2::catalyst_execute'
( 2.044s) [pvbatch ] sample2.py:17 INFO| in 'sample2::catalyst_finalize'
Note that catalyst_initialize and catalyst_finalize only gets called once while catalyst_execute gets called for each iteration.
The info object passed to catalyst_initialize can be used to obtain information about the current invocation which may be useful when writing code to execute per iteration.
> help(info)
Help on Information in module paraview.catalyst.v2_internals object:
class Information(builtins.object)
| Information(dataDescription)
| Provides information to the current `catalyst_execute` call.
| Methods defined here:
| __init__(self, dataDescription)
| Initialize self. See help(type(self)) for accurate signature.
| Readonly properties defined here:
| cycle
| returns the current simulation cycle or timestep index
| dataDescription
| avoid using this unless absolutely sure what you're doing
| time
| returns the current simulation time
| timestep
Here's a sample script that saves out an image each iteration.
view = CreateRenderView()
wavelet1 = Wavelet(registrationName="Wavelet1")
sliceDisplay = Show(slice1)
fname = "/tmp/output-%d.png" % info.timestep
ResetCamera()
print_info("time=%f, saving file: %s", info.time, fname)
SaveScreenshot(fname)
Here's the result of executing this script with wavelet_miniapp:
-s .../sample3.py
--script-version 2
--timesteps 3
-c Wavelet1
( 0.558s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.840s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/3
( 2.725s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample3' missing Catalyst 'options', will use a default options object
( 2.923s) [pvbatch ] sample3.py:23 INFO| time=0.000000, saving file: /tmp/output-0.png
( 2.997s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/3
( 3.278s) [pvbatch ] sample3.py:23 INFO| time=0.333333, saving file: /tmp/output-1.png
( 3.327s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 3/3
( 3.610s) [pvbatch ] sample3.py:23 INFO| time=0.666667, saving file: /tmp/output-2.png
Using Extractors
In ParaView 5.9, we introduced a new pipeline object called Extractors. Extractors are items in the visualization pipeline that can save data or images per timestep. Extractors make it largely unnecessary to have any custom code to execute per iteration since one can simply use extracts to save out image extracts from views or data extracts from filters and other data producers.
For example, sample3.py can be modified to use extractors as follows:
extractor1 = CreateExtractor('PNG', view, registrationName='PNG1')
extractor1.Writer.FileName = '/tmp/output-%ts.png'
extractor1.Writer.ImageResolution = [800, 880]
This will produce an output like follows:
-s .../sample3.py
--script-version 2
--timesteps 3
-c Wavelet1
( 0.554s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.835s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/3
( 2.823s) [pvbatch ] v2_internals.py:150 WARN| Module 'sample4' missing Catalyst 'options', will use a default options object
( 3.208s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/3
( 3.652s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 3/3
If you look at the generated results, /tmp/output-0.png, /tmp/output-1.png, etc. will be generated as with sample3.py. However, this time, we didn't need to add an explicit code to execute per iteration by providing catalyst_execute. The extractor achieve the same effect.
Such Catalyst scripts that use extractors can be easily exported from the ParaView GUI using File > Save Catalyst State. Such an exported script will often how the following trailer:
from paraview import catalyst
options = catalyst.Options()
options.GenerateCinemaSpecification = 1
options.ExtractsOutputDirectory = "/tmp"
if __name__ == '__main__':
from paraview.simple import SaveExtractsUsingCatalystOptions
SaveExtractsUsingCatalystOptions(options)
The options variable is setup with values chosen in the Save Catalyst State dialog. This is the options variable that we have been seeing warnings for in our runs so far. If present, options must be of the type paraview.catalyst.Options. This is used to specify parameters that control how the code is executed e.g. location of output directory, Catalyst Live connection information etc. If not present, a default one is created.
The following lists several of the important properties on options and their default values.
from paraview.catalyst import Options
options = Options()
options.ExtractsOutputDirectory = "...."
options.GenerateCinemaSpecification = ...
options.GlobalTrigger.UseStartTimeStep = ...
options.GlobalTrigger.StartTimeStep = ...
options.GlobalTrigger.UseEndTimeStep = ..
options.GlobalTrigger.EndTimeStep = ...
options.GlobalTrigger.Frequency = ...
options.EnableCatalystLive = ...
options.CatalystLiveURL = ...
options.CatalystLiveTrigger.UseStartTimeStep = ...
options.CatalystLiveTrigger.StartTimeStep = ...
options.CatalystLiveTrigger.UseEndTimeStep = ...
options.CatalystLiveTrigger.EndTimeStep = ...
options.CatalystLiveTrigger.Frequency = ...
options.ExtractsOutputDirectory is handy to place all generated extracts under a specific directory. To use it, ensure that all extractor use a relative filename. The filename is then evaluated to be relative to the directory provided for options.ExtractsOutputDirectory
Using Python Package
In previous section, we used a single .py file to demonstrate various aspects of Catalyst Python module. The same is applicable to a Python package. Take a simple package with directory structure as follows:
..../sample/
/ __init__.py
The contents of __init__.py as sample2.py described earlier. Now, you can use this package together with the wavelet_miniapp as follows:
--script .../sample
--script-version 2
--timesteps 3
--channel Wavelet1
( 0.570s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.856s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/3
( 1.923s) [pvbatch ] __init__.py:6 INFO| begin 'sample'
( 1.929s) [pvbatch ] __init__.py:20 INFO| end 'sample'
( 1.929s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample' missing Catalyst 'options', will use a default options object
( 1.932s) [pvbatch ] __init__.py:11 INFO| in 'sample::catalyst_initialize'
( 1.932s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 1.933s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/3
( 1.982s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 1.982s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 3/3
( 2.030s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 2.030s) [pvbatch ] __init__.py:17 INFO| in 'sample::catalyst_finalize'
As you can see, it produces a very similar result to using sample2.py. This is of course a very simple script. For complex scripts, a package allows better code organization and reusability and hence can be very handy in those situations.
The __init__.py file is the entry point. You can import other modules, packages, or sub-packages in it as needed.
Using ZIP archives
Python supports importing modules and packages from within a ZIP archive without having to unzip the contents. This can be a very handy feature for Catalyst Python scripts. You can simply archive a package directory using the same name as the directory (adding extension .zip) and then use that instead of the .py file.
For example, we can zip the sample directory as sample.zip use it as follows to produce almost identical result:
> pvbatch -m paraview.demos.wavelet_miniapp -s /tmp/sample.zip --script-version 2 --timesteps 3 -c Wavelet1
( 0.551s) [pvbatch ] bridge.py:17 WARN| Warning: ParaView has been initialized before `initialize` is called
( 1.992s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 1/3
( 2.061s) [pvbatch ] __init__.py:6 INFO| begin 'sample'
( 2.066s) [pvbatch ] __init__.py:20 INFO| end 'sample'
( 2.066s) [pvbatch ] v2_internals.py:145 WARN| Module 'sample' missing Catalyst 'options', will use a default options object
( 2.070s) [pvbatch ] __init__.py:11 INFO| in 'sample::catalyst_initialize'
( 2.070s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 2.070s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 2/3
( 2.121s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 2.121s) [pvbatch ] wavelet_miniapp.py:97 INFO| timestep: 3/3
( 2.172s) [pvbatch ] __init__.py:14 INFO| in 'sample::catalyst_execute'
( 2.172s) [pvbatch ] __init__.py:17 INFO| in 'sample::catalyst_finalize'
Note, currently it is required that the name of the zip archive and the name of the package directory must match.
Testing and Debugging
The pvpython/pvbatch executables can be launched with a -l argument to generate detailed logs as follows:
> pvbatch -l=/tmp/log.txt,TRACE -m paraview.demos.wavelet_miniapp ...
Here, a /tmp/log.txt will all logging output will be generated. You can also elevate Catalyst-generated log to a higher level and log that, for example, the following will elevate catalyst log level to INFO and log all INFO messages to /tmp/infolog.txt
> env PARAVIEW_LOG_CATALYST_VERBOSITY=INFO \
pvbatch -l=/tmp/infolog.txt,INFO -m paraview.demos.wavelet_miniapp ...
Mini-App: paraview.demos.wavelet_miniapp
The wavelet_miniapp that we used in several of the examples here is a simple stand-in for a simulation code. It uses the Wavelet (vtkRTAnalyticSource) internally to produce time-varying uniform rectilinear grid (vtkImageData). Command line options can be used to customize the run, including number of timesteps, etc.
> ./bin/pvbatch -m paraview.demos.wavelet_miniapp --help
usage: wavelet_miniapp.py [-h] [-t TIMESTEPS] [--size SIZE] -s SCRIPT [--script-version SCRIPT_VERSION] [-d DELAY] [-c CHANNEL]
Wavelet MiniApp for Catalyst testing
optional arguments:
-h, --help show this help message and exit
-t TIMESTEPS, --timesteps TIMESTEPS
number of timesteps to run the miniapp for (default: 100)
--size SIZE number of samples in each coordinate direction (default: 101)
-s SCRIPT, --script SCRIPT
path(s) to the Catalyst script(s) to use for in situ processing.
Can be a .py file or a Python package zip or directory
choose Catalyst analysis script version explicitly, otherwise it
will be determined automatically. When specifying multiple scripts,
this setting applies to all scripts.
-d DELAY, --delay DELAY
delay (in seconds) between timesteps (default: 0.0)
-c CHANNEL, --channel CHANNEL
Catalyst channel name (default: input)
To run in parallel using mpi, make sure that you use pvbatch in symmetric mode as follows:
> mpirun -np [num ranks] .../pvbatch -sym -m paraview.demos.wavelet_miniapp ....
Mini-App: paraview.demos.filedriver_minapp
The wavelet_miniapp is a good miniapp to use as stand-in for a simulation code to debug issues with the Catalyst scripts. Another useful miniapp is the filedriver_miniapp. Unlike the wavelet_miniapp which can only produce a specific type of dataset, filedriver_miniapp uses files on disk and serves them as if they are being generated by a simulation.
> ./bin/pvbatch -m paraview.demos.filedriver_miniapp --help
usage: filedriver_miniapp.py [-h] -s SCRIPT [--script-version SCRIPT_VERSION] [-d DELAY] [-c CHANNEL] -g GLOB
File-based MiniApp for Catalyst testing
optional arguments:
will be determined automatically. When specifying multiple scripts, this setting
-g GLOB, --glob GLOB Pattern to use to locate input filenames.
