This class provides the description of the data for the coprocessor pipelines.
| void | SetTimeData (double time, vtkIdType timeStep) |
| | Set the time step and current simulation time. More...
| virtual vtkIdType | GetTimeStep () |
| | Get the current time step that should be set in the adaptor. More...
| virtual double | GetTime () |
| | Get the current time that should be set in the adaptor. More...
| virtual void | SetForceOutput (bool) |
| | Specify whether or not to force output of all coprocessing pipelines. More...
| virtual void | ForceOutputOn () |
| virtual void | ForceOutputOff () |
| virtual bool | GetForceOutput () |
| | Return whether or not output is forced for all coprocessing pipelines. More...
| void | AddInput (const char *gridName) |
| | Add names for grids produced by the simulation. More...
| unsigned int | GetNumberOfInputDescriptions () |
| | Returns the number of input descriptions. More...
| void | ResetInputDescriptions () |
| | Reset the names of the fields that are needed, the required meshes, etc. More...
| void | ResetAll () |
| vtkCPInputDataDescription * | GetInputDescription (unsigned int) |
| | Provides access to a grid description using the index. More...
| const char * | GetInputDescriptionName (unsigned int) |
| | Provides the name for the input description at the given index. More...
| vtkCPInputDataDescription * | GetInputDescriptionByName (const char *) |
| | Provides access to a grid description using the grid name. More...
| bool | GetIfGridIsNecessary (const char *) |
| | Returns true if the grid is necessary, given the grid's name. More...
| bool | GetIfAnyGridNecessary () |
| | Returns true if any of the grids is necessary. More...
| void | SetUserData (vtkFieldData *UserData) |
| | Set user defined information that can be passed from the adaptor to the coprocessing pipelines. More...
| virtual vtkFieldData * | GetUserData () |
| void | Copy (vtkCPDataDescription *) |
| | Copy of dataDescription. More...
Definition at line 27 of file vtkCPDataDescription.h.
