Abstract class that takes care of initializing Catalyst Python pipelines for all concrete implementations and adds in some useful helper methods. More...
#include <vtkCPPythonPipeline.h>
| typedef vtkCPPipeline | Superclass |
Public Types inherited from vtkCPPipeline | |
Public Member Functions inherited from vtkCPPipeline | |
| virtual int | RequestDataDescription (vtkCPDataDescription *dataDescription)=0 |
| Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More... | |
| virtual int | CoProcess (vtkCPDataDescription *dataDescription)=0 |
| Execute the pipeline. Returns 1 for success and 0 for failure. More... | |
| virtual int | Finalize () |
| Finalize the pipeline before deleting it. More... | |
| static vtkCPPythonPipeline * | SafeDownCast (vtkObject *o) |
| static int | DetectScriptVersion (const char *fname) |
| Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More... | |
| static vtkSmartPointer< vtkCPPythonPipeline > | CreatePipeline (const char *fname, int default_version=1) |
| Detects the script version, if possible and created appropriate subclass. More... | |
| static vtkSmartPointer< vtkCPPythonPipeline > | CreateAndInitializePipeline (const char *fname, int default_version=1) |
Same as CreatePipeline, except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More... | |
| static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewPipeline (const char *fname, int default_version=1) |
These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More... | |
| static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewAndInitializePipeline (const char *fname, int default_version=1) |
Static Public Member Functions inherited from vtkCPPipeline | |
| static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
| void | FixEOL (std::string &) |
| For things like programmable filters that have a ' ' in their strings, we need to fix them to have \n so that everything works smoothly. More... | |
| std::string | GetPythonAddress (void *pointer) |
| Return the address of Pointer for the python script. More... | |
| vtkCPPythonPipeline () | |
| ~vtkCPPythonPipeline () override | |
Protected Member Functions inherited from vtkCPPipeline | |
| vtkCPPipeline () | |
| virtual | ~vtkCPPipeline () |
Definition at line 29 of file vtkCPPythonPipeline.h.
Definition at line 32 of file vtkCPPythonPipeline.h.
Reimplemented from vtkCPPipeline.
Reimplemented in vtkCPPythonScriptV2Pipeline, vtkCPPythonScriptPipeline, and vtkCPPythonStringPipeline.
Use this method to detect which version it is. Returns 1, 2 to indicate script version or 0 on failure.
If the version cannot be determined, the default_version is assumed.
CreateAndInitializePipeline.
If the Initialize failed, this will return nullptr.
C++ code should avoid using these. Use the Create* variants instead.
