vtkCPPythonScriptV2Helper Class Reference
an internal class encapsulating logic for Catalyst Python scripts. More...
#include <vtkCPPythonScriptV2Helper.h>
Inheritance diagram for vtkCPPythonScriptV2Helper:
Collaboration diagram for vtkCPPythonScriptV2Helper:
bool PrepareFromScript (const std::string &fname)
 Prepares the Python package/module for import. More...
bool IsImported () const
 Returns if the package/module has been imported. More...
bool Import ()
 Imports the module/package. More...
bool CatalystInitialize ()
 Calls catalyst_initialize. More...
bool CatalystFinalize ()
 Calls catalyst_finalize. More...
bool CatalystExecute (int timestep, double time)
 Calls catalyst_execute. More...
bool Import (vtkCPDataDescription *desc)
 There are overloads intended for vtkCPPythonScriptV2Pipeline i.e. More...
bool CatalystInitialize (vtkCPDataDescription *desc)
bool RequestDataDescription (vtkCPDataDescription *desc)
bool CatalystExecute (vtkCPDataDescription *desc)
static vtkCPPythonScriptV2HelperNew ()
static vtkCPPythonScriptV2HelperSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPPythonScriptV2Helper ()
 ~vtkCPPythonScriptV2Helper ()
bool IsActivated (int timestep, double time)
bool IsLiveActivated ()
void DoLive (int, double)
static vtkCPPythonScriptV2HelperGetActiveInstance ()
 Internal methods. More...
void RegisterExtractor (vtkSMProxy *extractor)
void RegisterView (vtkSMProxy *view)
void SetOptions (vtkSMProxy *catalystOptions)
virtual vtkSMProxyGetOptions ()
vtkCPDataDescriptionGetDataDescription () const
vtkSMProxyGetTrivialProducer (const char *inputname)
This class is an internal helper to share code between vtkInSituPipelinePython and vtkCPPythonScriptV2Pipeline.
Definition at line 32 of file vtkCPPythonScriptV2Helper.h.
Definition at line 36 of file vtkCPPythonScriptV2Helper.h.
◆ vtkCPPythonScriptV2Helper()
vtkCPPythonScriptV2Helper::vtkCPPythonScriptV2Helper ( )
◆ ~vtkCPPythonScriptV2Helper()
vtkCPPythonScriptV2Helper::~vtkCPPythonScriptV2Helper ( )
static vtkCPPythonScriptV2Helper* vtkCPPythonScriptV2Helper::New ( )
virtual const char* vtkCPPythonScriptV2Helper::GetClassName ( )
static int vtkCPPythonScriptV2Helper::IsTypeOf ( const char *  type)
virtual int vtkCPPythonScriptV2Helper::IsA ( const char *  type)
static vtkCPPythonScriptV2Helper* vtkCPPythonScriptV2Helper::SafeDownCast ( vtkObject o)
void vtkCPPythonScriptV2Helper::PrintSelf ( ostream &  os,
◆ PrepareFromScript()
bool vtkCPPythonScriptV2Helper::PrepareFromScript ( const std::string fname)
This doesn't actually import it yet. Returns false if the prep failed for some reason.
◆ IsImported()
bool vtkCPPythonScriptV2Helper::IsImported ( ) const
◆ Import() [1/2]
bool vtkCPPythonScriptV2Helper::Import ( )
This overload is used by vtkInSituPipelinePython which in turn is used in ParaView-Catalyst, the ParaView-based implementation of the Catalyst In Situ API.
Returns true on success.
◆ CatalystInitialize() [1/2]
bool vtkCPPythonScriptV2Helper::CatalystInitialize ( )
◆ CatalystFinalize()
bool vtkCPPythonScriptV2Helper::CatalystFinalize ( )
◆ CatalystExecute() [1/2]
bool vtkCPPythonScriptV2Helper::CatalystExecute ( int  timestep,
double  time
◆ Import() [2/2]
bool vtkCPPythonScriptV2Helper::Import ( vtkCPDataDescription desc)
legacy Catalyst adaptors that don't use Conduit.
◆ CatalystInitialize() [2/2]
bool vtkCPPythonScriptV2Helper::CatalystInitialize ( vtkCPDataDescription desc)
◆ RequestDataDescription()
bool vtkCPPythonScriptV2Helper::RequestDataDescription ( vtkCPDataDescription desc)
◆ CatalystExecute() [2/2]
bool vtkCPPythonScriptV2Helper::CatalystExecute ( vtkCPDataDescription desc)
◆ GetActiveInstance()
static vtkCPPythonScriptV2Helper* vtkCPPythonScriptV2Helper::GetActiveInstance ( )
Internal methods.
These are called by Python modules internal to ParaView and may change without notice. Should not be considered as part of ParaView API.
◆ RegisterExtractor()
void vtkCPPythonScriptV2Helper::RegisterExtractor ( vtkSMProxy extractor)
Internal methods.
◆ RegisterView()
void vtkCPPythonScriptV2Helper::RegisterView ( vtkSMProxy view)
Internal methods.
◆ SetOptions()
void vtkCPPythonScriptV2Helper::SetOptions ( vtkSMProxy catalystOptions)
Internal methods.
◆ GetOptions()
virtual vtkSMProxy* vtkCPPythonScriptV2Helper::GetOptions ( )
Internal methods.
◆ GetDataDescription()
vtkCPDataDescription* vtkCPPythonScriptV2Helper::GetDataDescription ( ) const
inline
Internal methods.
Definition at line 96 of file vtkCPPythonScriptV2Helper.h.
◆ GetTrivialProducer()
vtkSMProxy* vtkCPPythonScriptV2Helper::GetTrivialProducer ( const char *  inputname)
Internal methods.
◆ IsActivated()
bool vtkCPPythonScriptV2Helper::IsActivated ( int  timestep,
double  time
◆ IsLiveActivated()
bool vtkCPPythonScriptV2Helper::IsLiveActivated ( )
◆ DoLive()
void vtkCPPythonScriptV2Helper::DoLive ( int  ,
double
