| virtual void | SetFieldAssociation (int) |
| | Select the attribute type. More...
| virtual int | GetFieldAssociation () |
| virtual void | SetAddMetaData (bool) |
| | It is possible for this filter to add additional meta-data to the field data such as point coordinates (when point attributes are selected and input is pointset) or structured coordinates etc. More...
| virtual bool | GetAddMetaData () |
| virtual void | AddMetaDataOn () |
| virtual void | AddMetaDataOff () |
| virtual void | SetGenerateOriginalIds (bool) |
| | When set (default) the vtkOriginalIndices array will be added to the output. More...
| virtual bool | GetGenerateOriginalIds () |
| virtual void | SetGenerateCellConnectivity (bool) |
| | When set (not the default) the connectivity of each cell will be added by adding a new column for each point. More...
| virtual bool | GetGenerateCellConnectivity () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAttributeDataToTableFilter () |
| | ~vtkAttributeDataToTableFilter () override |
| | Perform the data processing. More...
| void | Decorate (vtkTable *output, vtkDataObject *input) |
| | Called when AddMetaData is true. More...
| void | PassFieldData (vtkFieldData *output, vtkFieldData *input) |
| void | AddCellTypeAndConnectivity (vtkTable *output, vtkDataSet *ds) |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
this filter produces a vtkTable from the chosen attribute in the input data object.
vtkAttributeDataToTableFilter is a filter that produces a vtkTable from the chosen attribute in the input dataobject. This filter can accept composite datasets. If the input is a composite dataset, the output is a multiblock with vtkTable leaves.
Definition at line 36 of file vtkAttributeDataToTableFilter.h.
