representation used for volume rendering AMR datasets with ability to stream blocks.
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetNumberOfSamples (int x, int y, int z) |
| | Get/Set the resample buffer size. More...
| void | SetOrientation (double, double, double) |
| void | SetOrigin (double, double, double) |
| void | SetPickable (int val) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetInterpolationType (int val) |
| void | SetColor (vtkColorTransferFunction *lut) |
| void | SetScalarOpacity (vtkPiecewiseFunction *pwf) |
| void | SetScalarOpacityUnitDistance (double val) |
| void | SetAmbient (double) |
| void | SetDiffuse (double) |
| void | SetSpecular (double) |
| void | SetSpecularPower (double) |
| void | SetShade (bool) |
| void | SetIndependantComponents (bool) |
| void | SetRequestedRenderMode (int) |
| void | SetResamplingMode (int val) |
| | This control the logic used to determine how to place the resampling grid within the AMR bounds. More...
| virtual int | GetResamplingMode () |
| virtual void | SetStreamingRequestSize (int) |
| | Set the number of blocks to request at a given time on a single process when streaming. More...
| virtual int | GetStreamingRequestSize () |
| void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override |
| | Set the input data arrays that this algorithm will process. More...
| void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override |
| void | SetInputArrayToProcess (int idx, vtkInformation *info) override |
| void | SetInputArrayToProcess (int idx, int port, int connection, const char *fieldAssociation, const char *attributeTypeorName) override |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAMRStreamingVolumeRepresentation () |
| | ~vtkAMRStreamingVolumeRepresentation () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | Overridden to check if the input pipeline is streaming capable. More...
| | Setup the block request. More...
| | Process the current input for volume rendering (if anything). More...
| bool | StreamingUpdate (vtkPVRenderView *view, const double view_planes[24]) |
| | Returns true if this representation has a "next piece" that it streamed. More...
| virtual bool | GetStreamingCapablePipeline () |
| | Returns true when the input pipeline supports streaming. More...
| virtual bool | GetInStreamingUpdate () |
| | Returns true when StreamingUpdate() is being processed. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
