| void | Reset () |
| | To restart the incremental resample process, call this method. More...
| void | UpdateResampledVolume (vtkOverlappingAMR *) |
| | Updates the volume. More...
| bool | NeedsInitialization () const |
| | Returns true if the resampler will reinitialize the volume in the next call to UpdateResampledVolume(). More...
| virtual void | SetMaxDimensions (int, int, int) |
| | Get/Set the maximum number of samples along each axis. More...
| virtual void | SetMaxDimensions (int [3]) |
| virtual int * | GetMaxDimensions () |
| virtual void | GetMaxDimensions (int &, int &, int &) |
| virtual void | GetMaxDimensions (int [3]) |
| virtual void | SetSpatialBounds (double, double, double, double, double, double) |
| | When provided, the resampled image is set up to cover these bounds. More...
| virtual void | SetSpatialBounds (double [6]) |
| virtual double * | GetSpatialBounds () |
| virtual void | GetSpatialBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetSpatialBounds (double [6]) |
| vtkTrivialProducer * | NewInstance () const |
| virtual void | SetOutput (vtkDataObject *output) |
| virtual void | SetWholeExtent (int, int, int, int, int, int) |
| virtual void | SetWholeExtent (int[6]) |
| virtual int * | GetWholeExtent () |
| virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetWholeExtent (int[6]) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkResampledAMRImageSource () |
| | ~vtkResampledAMRImageSource () override |
| bool | Initialize (vtkOverlappingAMR *amr) |
| bool | UpdateResampledVolume (const unsigned int &level, const unsigned &index, const vtkAMRBox &box, vtkImageData *data) |
| | vtkTrivialProducer () |
| | ~vtkTrivialProducer () |
| virtual int | FillInputPortInformation (int, vtkInformation *) |
| virtual int | FillOutputPortInformation (int, vtkInformation *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
image data source that resamples an AMR dataset to produce the image data.
vtkResampledAMRImageSource is a image data source that resamples a vtkOverlappingAMR dataset to produce an image data. The output AMR will have both the point data and cell data from the input AMR grids passed along as point data for the output image data. This filter assumes that all blocks in the input AMR have exactly the same point/cell arrays in same order. If they are different we will end up with weird runtime issues that may be hard to debug.
- Attention
- We subclass vtkTrivialProducer since it deals with all the meta-data that needs to be passed down the pipeline for image data, keeping the code here simple.
Definition at line 47 of file vtkResampledAMRImageSource.h.
