| void | Initialize (vtkAMRInformation *amr) |
| | Initializes the queue. More...
| void | Reinitialize () |
| | Re-initializes the priority queue using the amr structure given to the most recent call to Initialize(). More...
| bool | IsEmpty () |
| | Returns if the queue is empty. More...
| unsigned int | Pop () |
| | Pops and returns of composite id for the block at the top of the queue. More...
| void | SetController (vtkMultiProcessController *) |
| | If the controller is specified, the queue can be used in parallel. More...
| virtual vtkMultiProcessController * | GetController () |
| void | Update (const double view_planes[24], const double clamp_bounds[6]) |
| | Updates the priorities of blocks based on the new view frustum planes. More...
| void | Update (const double view_planes[24]) |
implements a coverage based priority queue for vtkOverlappingAMR dataset.
vtkAMRStreamingPriorityQueue is used by representations supporting streaming of AMR datasets to determine the priorities for blocks in the dataset. This class relies on the bounds information provided by the AMR meta-data i.e. vtkAMRInformation. This class support view-based priority computation. Simply provide the view planes (returned by vtkCamera::GetFrustumPlanes()) to the vtkAMRStreamingPriorityQueue::Update() call to update the prorities for the blocks currently in the queue.
- See also
- vtkAMROutlineRepresentation, vtkAMRStreamingVolumeRepresentation.
Definition at line 40 of file vtkAMRStreamingPriorityQueue.h.
