vtkAMRFragmentsFilter Class Reference
A meta filter that combines vtkAMRConnectivity, vtkAMRFragmentIntegration, vtkAMRDualContour, vtkExtractCTHPart to allow all the fragment analysis in one easy UI. More...
#include <vtkAMRFragmentsFilter.h>
Inheritance diagram for vtkAMRFragmentsFilter:
Collaboration diagram for vtkAMRFragmentsFilter:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
void AddInputVolumeArrayToProcess (const char *name)
 Add to list of volume arrays to find connected fragments. More...
void ClearInputVolumeArrayToProcess ()
void AddInputMassArrayToProcess (const char *name)
 Add to list of mass arrays. More...
void ClearInputMassArrayToProcess ()
void AddInputVolumeWeightedArrayToProcess (const char *name)
 Add to list of volume weighted arrays. More...
void ClearInputVolumeWeightedArrayToProcess ()
void AddInputMassWeightedArrayToProcess (const char *name)
 Add to list of mass weighted arrays. More...
void ClearInputMassWeightedArrayToProcess ()
virtual void SetExtractSurface (bool)
 Whether or not to extract a surface. More...
virtual bool GetExtractSurface ()
virtual void ExtractSurfaceOn ()
virtual void ExtractSurfaceOff ()
virtual void SetUseWatertightSurface (bool)
 Whether or not to use water-tight algorithm for the surface. More...
virtual bool GetUseWatertightSurface ()
virtual void UseWatertightSurfaceOn ()
virtual void UseWatertightSurfaceOff ()
virtual void SetIntegrateFragments (bool)
 Whether or not to perform fragment integration. More...
virtual bool GetIntegrateFragments ()
virtual void IntegrateFragmentsOn ()
virtual void IntegrateFragmentsOff ()
virtual double GetVolumeFractionSurfaceValue ()
 Get / Set volume fraction value. More...
virtual void SetVolumeFractionSurfaceValue (double)
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAMRFragmentsFilterNew ()
static vtkAMRFragmentsFilterSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkAMRFragmentsFilter ()
 ~vtkAMRFragmentsFilter () override
int FillInputPortInformation (int, vtkInformation *) override
int FillOutputPortInformation (int, vtkInformation *) override
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
bool ExtractSurface
bool UseWatertightSurface
bool IntegrateFragments
double VolumeFractionSurfaceValue
vtkTrivialProducerProducer
vtkExtractCTHPartExtract
vtkPVAMRDualContourContour
vtkAMRConnectivityConnectivity
vtkPVAMRFragmentIntegrationIntegration
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Input 0: The AMR Volume
Output 0: A multiblock containing tables of fragments, one block for each requested material
Definition at line 40 of file vtkAMRFragmentsFilter.h.
Definition at line 44 of file vtkAMRFragmentsFilter.h.
◆ vtkAMRFragmentsFilter()
vtkAMRFragmentsFilter::vtkAMRFragmentsFilter ( )
◆ ~vtkAMRFragmentsFilter()
vtkAMRFragmentsFilter::~vtkAMRFragmentsFilter ( )
static vtkAMRFragmentsFilter* vtkAMRFragmentsFilter::New ( )
virtual const char* vtkAMRFragmentsFilter::GetClassName ( )
static int vtkAMRFragmentsFilter::IsTypeOf ( const char *  type)
virtual int vtkAMRFragmentsFilter::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkAMRFragmentsFilter* vtkAMRFragmentsFilter::SafeDownCast ( vtkObject o)
void vtkAMRFragmentsFilter::PrintSelf ( ostream &  os,
◆ AddInputVolumeArrayToProcess()
void vtkAMRFragmentsFilter::AddInputVolumeArrayToProcess ( const char *  name)
◆ ClearInputVolumeArrayToProcess()
void vtkAMRFragmentsFilter::ClearInputVolumeArrayToProcess ( )
◆ AddInputMassArrayToProcess()
void vtkAMRFragmentsFilter::AddInputMassArrayToProcess ( const char *  name)
◆ ClearInputMassArrayToProcess()
void vtkAMRFragmentsFilter::ClearInputMassArrayToProcess ( )
◆ AddInputVolumeWeightedArrayToProcess()
void vtkAMRFragmentsFilter::AddInputVolumeWeightedArrayToProcess ( const char *  name)
◆ ClearInputVolumeWeightedArrayToProcess()
void vtkAMRFragmentsFilter::ClearInputVolumeWeightedArrayToProcess ( )
◆ AddInputMassWeightedArrayToProcess()
void vtkAMRFragmentsFilter::AddInputMassWeightedArrayToProcess ( const char *  name)
◆ ClearInputMassWeightedArrayToProcess()
void vtkAMRFragmentsFilter::ClearInputMassWeightedArrayToProcess ( )
◆ SetExtractSurface()
virtual void vtkAMRFragmentsFilter::SetExtractSurface ( bool  )
◆ GetExtractSurface()
virtual bool vtkAMRFragmentsFilter::GetExtractSurface ( )
◆ ExtractSurfaceOn()
virtual void vtkAMRFragmentsFilter::ExtractSurfaceOn ( )
◆ ExtractSurfaceOff()
virtual void vtkAMRFragmentsFilter::ExtractSurfaceOff ( )
◆ SetUseWatertightSurface()
virtual void vtkAMRFragmentsFilter::SetUseWatertightSurface ( bool  )
◆ GetUseWatertightSurface()
virtual bool vtkAMRFragmentsFilter::GetUseWatertightSurface ( )
◆ UseWatertightSurfaceOn()
virtual void vtkAMRFragmentsFilter::UseWatertightSurfaceOn ( )
◆ UseWatertightSurfaceOff()
virtual void vtkAMRFragmentsFilter::UseWatertightSurfaceOff ( )
◆ SetIntegrateFragments()
virtual void vtkAMRFragmentsFilter::SetIntegrateFragments ( bool  )
◆ GetIntegrateFragments()
virtual bool vtkAMRFragmentsFilter::GetIntegrateFragments ( )
◆ IntegrateFragmentsOn()
virtual void vtkAMRFragmentsFilter::IntegrateFragmentsOn ( )
◆ IntegrateFragmentsOff()
virtual void vtkAMRFragmentsFilter::IntegrateFragmentsOff ( )
◆ GetVolumeFractionSurfaceValue()
virtual double vtkAMRFragmentsFilter::GetVolumeFractionSurfaceValue ( )
◆ SetVolumeFractionSurfaceValue()
virtual void vtkAMRFragmentsFilter::SetVolumeFractionSurfaceValue ( double  )
◆ FillInputPortInformation()
int vtkAMRFragmentsFilter::FillInputPortInformation ( int  ,
vtkInformation
overrideprotectedvirtual
◆ FillOutputPortInformation()
int vtkAMRFragmentsFilter::FillOutputPortInformation ( int  ,
vtkInformation
◆ RequestData()
int vtkAMRFragmentsFilter::RequestData ( vtkInformation ,
vtkInformationVector **  ,
◆ ExtractSurface
bool vtkAMRFragmentsFilter::ExtractSurface
Definition at line 118 of file vtkAMRFragmentsFilter.h.
bool vtkAMRFragmentsFilter::UseWatertightSurface
Definition at line 119 of file vtkAMRFragmentsFilter.h.
bool vtkAMRFragmentsFilter::IntegrateFragments
Definition at line 120 of file vtkAMRFragmentsFilter.h.
◆ VolumeFractionSurfaceValue
double vtkAMRFragmentsFilter::VolumeFractionSurfaceValue
Definition at line 121 of file vtkAMRFragmentsFilter.h.
◆ Producer
vtkTrivialProducer* vtkAMRFragmentsFilter::Producer
Definition at line 123 of file vtkAMRFragmentsFilter.h.
◆ Extract
vtkExtractCTHPart* vtkAMRFragmentsFilter::Extract
Definition at line 124 of file vtkAMRFragmentsFilter.h.
◆ Contour
vtkPVAMRDualContour* vtkAMRFragmentsFilter::Contour
Definition at line 125 of file vtkAMRFragmentsFilter.h.
◆ Connectivity
vtkAMRConnectivity* vtkAMRFragmentsFilter::Connectivity
Definition at line 126 of file vtkAMRFragmentsFilter.h.
◆ Integration
vtkPVAMRFragmentIntegration* vtkAMRFragmentsFilter::Integration
Definition at line 127 of file vtkAMRFragmentsFilter.h.
