vtkAMRConnectivity Class Reference
Identify fragments in the grid. More...
#include <vtkAMRConnectivity.h>
Inheritance diagram for vtkAMRConnectivity:
Collaboration diagram for vtkAMRConnectivity:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
void AddInputVolumeArrayToProcess (const char *name)
 Add to list of volume arrays to find connected fragments. More...
void ClearInputVolumeArrayToProcess ()
virtual double GetVolumeFractionSurfaceValue ()
 Get / Set volume fraction value. More...
virtual void SetVolumeFractionSurfaceValue (double)
virtual bool GetResolveBlocks ()
 Get / Set where to resolve the regions between blocks. More...
virtual void SetResolveBlocks (bool)
virtual bool GetPropagateGhosts ()
virtual void SetPropagateGhosts (bool)
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAMRConnectivitySafeDownCast (vtkObject *o)
static vtkAMRConnectivityNew ()
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkAMRConnectivity ()
 ~vtkAMRConnectivity () override
int DoRequestData (vtkNonOverlappingAMR *, const char *)
int WavePropagation (vtkIdType cellIdStart, vtkUniformGrid *grid, vtkIdTypeArray *regionId, vtkDataArray *volArray, vtkUnsignedCharArray *ghostArray)
vtkAMRDualGridHelperBlockGetBlockNeighbor (vtkAMRDualGridHelperBlock *block, int dir)
void ProcessBoundaryAtBlock (vtkNonOverlappingAMR *volume, vtkAMRDualGridHelperBlock *block, vtkAMRDualGridHelperBlock *neighbor, int dir)
int ExchangeBoundaries (vtkMPIController *controller)
int ExchangeEquivPairs (vtkMPIController *controller)
void ProcessBoundaryAtNeighbor (vtkNonOverlappingAMR *volume, vtkIdTypeArray *array)
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
double VolumeFractionSurfaceValue
vtkAMRDualGridHelperHelper
vtkAMRConnectivityEquivalence * Equivalence
bool ResolveBlocks
bool PropagateGhosts
std::string RegionName
vtkIdType NextRegionId
std::vector< std::stringVolumeArrays
std::vector< std::vector< vtkSmartPointer< vtkIdTypeArray > > > BoundaryArrays
std::vector< std::vector< int > > ReceiveList
std::vector< bool > ValidNeighbor
std::vector< std::vector< std::vector< int > > > NeighborList
std::vector< vtkSmartPointer< vtkIntArray > > EquivPairs
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
.SEE vtkAMRConnectivity
Definition at line 43 of file vtkAMRConnectivity.h.
Definition at line 46 of file vtkAMRConnectivity.h.
◆ vtkAMRConnectivity()
vtkAMRConnectivity::vtkAMRConnectivity ( )
◆ ~vtkAMRConnectivity()
vtkAMRConnectivity::~vtkAMRConnectivity ( )
virtual const char* vtkAMRConnectivity::GetClassName ( )
static int vtkAMRConnectivity::IsTypeOf ( const char *  type)
virtual int vtkAMRConnectivity::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkAMRConnectivity* vtkAMRConnectivity::SafeDownCast ( vtkObject o)
void vtkAMRConnectivity::PrintSelf ( ostream &  os,
static vtkAMRConnectivity* vtkAMRConnectivity::New ( )
◆ AddInputVolumeArrayToProcess()
void vtkAMRConnectivity::AddInputVolumeArrayToProcess ( const char *  name)
◆ ClearInputVolumeArrayToProcess()
void vtkAMRConnectivity::ClearInputVolumeArrayToProcess ( )
◆ GetVolumeFractionSurfaceValue()
virtual double vtkAMRConnectivity::GetVolumeFractionSurfaceValue ( )
◆ SetVolumeFractionSurfaceValue()
virtual void vtkAMRConnectivity::SetVolumeFractionSurfaceValue ( double  )
◆ GetResolveBlocks()
virtual bool vtkAMRConnectivity::GetResolveBlocks ( )
◆ SetResolveBlocks()
virtual void vtkAMRConnectivity::SetResolveBlocks ( bool  )
◆ GetPropagateGhosts()
virtual bool vtkAMRConnectivity::GetPropagateGhosts ( )
◆ SetPropagateGhosts()
virtual void vtkAMRConnectivity::SetPropagateGhosts ( bool  )
◆ FillInputPortInformation()
int vtkAMRConnectivity::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ FillOutputPortInformation()
int vtkAMRConnectivity::FillOutputPortInformation ( int  port,
vtkInformation info
◆ RequestData()
int vtkAMRConnectivity::RequestData ( vtkInformation ,
vtkInformationVector **  ,
◆ DoRequestData()
int vtkAMRConnectivity::DoRequestData ( vtkNonOverlappingAMR ,
const char *
◆ WavePropagation()
int vtkAMRConnectivity::WavePropagation ( vtkIdType  cellIdStart,
vtkUniformGrid grid,
vtkIdTypeArray regionId,
vtkDataArray volArray,
vtkUnsignedCharArray ghostArray
◆ GetBlockNeighbor()
vtkAMRDualGridHelperBlock* vtkAMRConnectivity::GetBlockNeighbor ( vtkAMRDualGridHelperBlock block,
int  dir
◆ ProcessBoundaryAtBlock()
void vtkAMRConnectivity::ProcessBoundaryAtBlock ( vtkNonOverlappingAMR volume,
vtkAMRDualGridHelperBlock neighbor,
int  dir
◆ ExchangeBoundaries()
int vtkAMRConnectivity::ExchangeBoundaries ( vtkMPIController controller)
◆ ExchangeEquivPairs()
int vtkAMRConnectivity::ExchangeEquivPairs ( vtkMPIController controller)
◆ ProcessBoundaryAtNeighbor()
void vtkAMRConnectivity::ProcessBoundaryAtNeighbor ( vtkNonOverlappingAMR volume,
vtkIdTypeArray array
◆ VolumeFractionSurfaceValue
double vtkAMRConnectivity::VolumeFractionSurfaceValue
Definition at line 86 of file vtkAMRConnectivity.h.
◆ Helper
vtkAMRDualGridHelper* vtkAMRConnectivity::Helper
Definition at line 87 of file vtkAMRConnectivity.h.
◆ Equivalence
vtkAMRConnectivityEquivalence* vtkAMRConnectivity::Equivalence
Definition at line 88 of file vtkAMRConnectivity.h.
◆ ResolveBlocks
bool vtkAMRConnectivity::ResolveBlocks
Definition at line 90 of file vtkAMRConnectivity.h.
◆ PropagateGhosts
bool vtkAMRConnectivity::PropagateGhosts
Definition at line 91 of file vtkAMRConnectivity.h.
◆ RegionName
std::string vtkAMRConnectivity::RegionName
Definition at line 93 of file vtkAMRConnectivity.h.
◆ NextRegionId
vtkIdType vtkAMRConnectivity::NextRegionId
Definition at line 94 of file vtkAMRConnectivity.h.
◆ VolumeArrays
std::vector<std::string> vtkAMRConnectivity::VolumeArrays
Definition at line 96 of file vtkAMRConnectivity.h.
◆ BoundaryArrays
std::vector<std::vector<vtkSmartPointer<vtkIdTypeArray> > > vtkAMRConnectivity::BoundaryArrays
Definition at line 98 of file vtkAMRConnectivity.h.
◆ ReceiveList
std::vector<std::vector<int> > vtkAMRConnectivity::ReceiveList
Definition at line 99 of file vtkAMRConnectivity.h.
◆ ValidNeighbor
std::vector<bool> vtkAMRConnectivity::ValidNeighbor
Definition at line 101 of file vtkAMRConnectivity.h.
◆ NeighborList
std::vector<std::vector<std::vector<int> > > vtkAMRConnectivity::NeighborList
Definition at line 102 of file vtkAMRConnectivity.h.
◆ EquivPairs
std::vector<vtkSmartPointer<vtkIntArray> > vtkAMRConnectivity::EquivPairs
Definition at line 103 of file vtkAMRConnectivity.h.
