Public Types | Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
vtkPVAMRDualContour Class Reference
Generates a contour surface given one or more cell arrays and a volume fraction value. More...
#include <vtkPVAMRDualContour.h>
Inheritance diagram for vtkPVAMRDualContour:
Collaboration diagram for vtkPVAMRDualContour:
typedef vtkAMRDualContour Superclass
- Public Types inherited from vtkAMRDualContour
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
 vtkPVAMRDualContour ()
 ~vtkPVAMRDualContour () override
void AddInputCellArrayToProcess (const char *name)
 Add to list of cell arrays which are used for generating contours. More...
void ClearInputCellArrayToProcess ()
virtual double GetVolumeFractionSurfaceValue ()
 Get / Set volume fraction value. More...
virtual void SetVolumeFractionSurfaceValue (double)
- Public Member Functions inherited from vtkAMRDualContour
virtual void SetIsoValue (double)
virtual double GetIsoValue ()
virtual vtkMultiProcessControllerGetController ()
virtual void SetController (vtkMultiProcessController *)
virtual void SetEnableCapping (int)
 These are to evaluate performances. More...
virtual int GetEnableCapping ()
virtual void EnableCappingOn ()
virtual void EnableCappingOff ()
virtual void SetEnableDegenerateCells (int)
virtual int GetEnableDegenerateCells ()
virtual void EnableDegenerateCellsOn ()
virtual void EnableDegenerateCellsOff ()
virtual void SetEnableMultiProcessCommunication (int)
virtual int GetEnableMultiProcessCommunication ()
virtual void EnableMultiProcessCommunicationOn ()
virtual void EnableMultiProcessCommunicationOff ()
virtual void SetEnableMergePoints (int)
 This flag causes blocks to share locators so there are no boundary edges between blocks. More...
virtual int GetEnableMergePoints ()
virtual void EnableMergePointsOn ()
virtual void EnableMergePointsOff ()
virtual void SetTriangulateCap (int)
 A flag that causes the polygons on the capping surfaces to be triagulated. More...
virtual int GetTriangulateCap ()
virtual void TriangulateCapOn ()
virtual void TriangulateCapOff ()
virtual void SetSkipGhostCopy (int)
 An option to turn off copying ghost values across process boundaries. More...
virtual int GetSkipGhostCopy ()
virtual void SkipGhostCopyOn ()
virtual void SkipGhostCopyOff ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVAMRDualContourNew ()
static vtkPVAMRDualContourSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAMRDualContour
static vtkAMRDualContourNew ()
static vtkAMRDualContourSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
double VolumeFractionSurfaceValue
vtkPVAMRDualContourInternal * Implementation
- Protected Attributes inherited from vtkAMRDualContour
double IsoValue
int EnableDegenerateCells
int EnableCapping
int EnableMultiProcessCommunication
int EnableMergePoints
int TriangulateCap
int SkipGhostCopy
vtkIntArrayBlockIdCellArray
vtkFloatArrayTemperatureArray
vtkAMRDualGridHelperHelper
vtkPolyDataMesh
vtkPointsPoints
vtkCellArrayFaces
vtkMultiProcessControllerController
intMessageBuffer
intMessageBufferLength
vtkAMRDualContourEdgeLocator * BlockLocator
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Member Functions inherited from vtkAMRDualContour
 vtkAMRDualContour ()
 ~vtkAMRDualContour () override
void InitializeRequest (vtkNonOverlappingAMR *input)
 This should be called before any number of calls to DoRequestData. More...
void FinalizeRequest ()
 This should be called after any number of calls to DoRequestData. More...
vtkMultiBlockDataSetDoRequestData (vtkNonOverlappingAMR *input, const char *arrayNameToProcess)
 Not a pipeline function. More...
void ShareBlockLocatorWithNeighbors (vtkAMRDualGridHelperBlock *block)
void ProcessBlock (vtkAMRDualGridHelperBlock *block, int blockId, const char *arrayName)
void ProcessDualCell (vtkAMRDualGridHelperBlock *block, int blockId, int x, int y, int z, vtkIdType cornerOffsets[8], vtkDataArray *volumeFractionArray)
void AddCapPolygon (int ptCount, vtkIdType *pointIds, int blockId)
void CapCell (int cellX, int cellY, int cellZ, unsigned char cubeBoundaryBits, int cubeCase, vtkIdType edgePtIds[12], double cornerPoints[32], vtkIdType cornerOffsets[8], int blockId, vtkDataSet *inData)
void InitializeCopyAttributes (vtkNonOverlappingAMR *hbdsInput, vtkDataSet *mesh)
void InterpolateAttributes (vtkDataSet *uGrid, vtkIdType offset0, vtkIdType offset1, double k, vtkDataSet *mesh, vtkIdType outId)
void CopyAttributes (vtkDataSet *uGrid, vtkIdType inId, vtkDataSet *mesh, vtkIdType outId)
void FinalizeCopyAttributes (vtkDataSet *mesh)
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
.SEE vtkAMRDualContour
Definition at line 35 of file vtkPVAMRDualContour.h.
Definition at line 39 of file vtkPVAMRDualContour.h.
◆ vtkPVAMRDualContour()
vtkPVAMRDualContour::vtkPVAMRDualContour ( )
◆ ~vtkPVAMRDualContour()
vtkPVAMRDualContour::~vtkPVAMRDualContour ( )
override
static vtkPVAMRDualContour* vtkPVAMRDualContour::New ( )
virtual const char* vtkPVAMRDualContour::GetClassName ( )
Reimplemented from vtkAMRDualContour.
static int vtkPVAMRDualContour::IsTypeOf ( const char *  type)
virtual int vtkPVAMRDualContour::IsA ( const char *  type)
static vtkPVAMRDualContour* vtkPVAMRDualContour::SafeDownCast ( vtkObject o)
void vtkPVAMRDualContour::PrintSelf ( ostream &  os,
◆ AddInputCellArrayToProcess()
void vtkPVAMRDualContour::AddInputCellArrayToProcess ( const char *  name)
◆ ClearInputCellArrayToProcess()
void vtkPVAMRDualContour::ClearInputCellArrayToProcess ( )
◆ GetVolumeFractionSurfaceValue()
virtual double vtkPVAMRDualContour::GetVolumeFractionSurfaceValue ( )
◆ SetVolumeFractionSurfaceValue()
virtual void vtkPVAMRDualContour::SetVolumeFractionSurfaceValue ( double  )
◆ RequestData()
int vtkPVAMRDualContour::RequestData ( vtkInformation ,
vtkInformationVector **  ,
◆ VolumeFractionSurfaceValue
double vtkPVAMRDualContour::VolumeFractionSurfaceValue
Definition at line 68 of file vtkPVAMRDualContour.h.
◆ Implementation
vtkPVAMRDualContourInternal* vtkPVAMRDualContour::Implementation
Definition at line 69 of file vtkPVAMRDualContour.h.
