Public Types | Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
vtkPVAMRFragmentIntegration Class Reference
Generates fragment analysis from an amr volume and a previously run contour on that volume. More...
#include <vtkPVAMRFragmentIntegration.h>
Inheritance diagram for vtkPVAMRFragmentIntegration:
Collaboration diagram for vtkPVAMRFragmentIntegration:
typedef vtkAMRFragmentIntegration Superclass
- Public Types inherited from vtkAMRFragmentIntegration
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
 vtkPVAMRFragmentIntegration ()
 ~vtkPVAMRFragmentIntegration () override
void SetContourConnection (vtkAlgorithmOutput *)
void AddInputVolumeArrayToProcess (const char *name)
 Add to list of volume arrays which are used for generating contours. More...
void ClearInputVolumeArrayToProcess ()
void AddInputMassArrayToProcess (const char *name)
 Add to list of mass arrays. More...
void ClearInputMassArrayToProcess ()
void AddInputVolumeWeightedArrayToProcess (const char *name)
 Add to list of volume weighted arrays. More...
void ClearInputVolumeWeightedArrayToProcess ()
void AddInputMassWeightedArrayToProcess (const char *name)
 Add to list of mass weighted arrays. More...
void ClearInputMassWeightedArrayToProcess ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVAMRFragmentIntegrationNew ()
static vtkPVAMRFragmentIntegrationSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAMRFragmentIntegration
static vtkAMRFragmentIntegrationNew ()
static vtkAMRFragmentIntegrationSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
double VolumeFractionSurfaceValue
vtkPVAMRFragmentIntegrationInternal * Implementation
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Member Functions inherited from vtkAMRFragmentIntegration
 vtkAMRFragmentIntegration ()
 ~vtkAMRFragmentIntegration () override
vtkTableDoRequestData (vtkNonOverlappingAMR *volume, const char *volumeArray, const char *massArray, std::vector< std::string > volumeWeightedNames, std::vector< std::string > massWeightedNames)
 Pipeline helper. More...
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
.SEE vtkAMRFragmentIntegration
Definition at line 35 of file vtkPVAMRFragmentIntegration.h.
Definition at line 39 of file vtkPVAMRFragmentIntegration.h.
◆ vtkPVAMRFragmentIntegration()
vtkPVAMRFragmentIntegration::vtkPVAMRFragmentIntegration ( )
◆ ~vtkPVAMRFragmentIntegration()
vtkPVAMRFragmentIntegration::~vtkPVAMRFragmentIntegration ( )
override
static vtkPVAMRFragmentIntegration* vtkPVAMRFragmentIntegration::New ( )
virtual const char* vtkPVAMRFragmentIntegration::GetClassName ( )
Reimplemented from vtkAMRFragmentIntegration.
static int vtkPVAMRFragmentIntegration::IsTypeOf ( const char *  type)
virtual int vtkPVAMRFragmentIntegration::IsA ( const char *  type)
static vtkPVAMRFragmentIntegration* vtkPVAMRFragmentIntegration::SafeDownCast ( vtkObject o)
void vtkPVAMRFragmentIntegration::PrintSelf ( ostream &  os,
◆ AddInputVolumeArrayToProcess()
void vtkPVAMRFragmentIntegration::AddInputVolumeArrayToProcess ( const char *  name)
◆ ClearInputVolumeArrayToProcess()
void vtkPVAMRFragmentIntegration::ClearInputVolumeArrayToProcess ( )
◆ AddInputMassArrayToProcess()
void vtkPVAMRFragmentIntegration::AddInputMassArrayToProcess ( const char *  name)
◆ ClearInputMassArrayToProcess()
void vtkPVAMRFragmentIntegration::ClearInputMassArrayToProcess ( )
◆ AddInputVolumeWeightedArrayToProcess()
void vtkPVAMRFragmentIntegration::AddInputVolumeWeightedArrayToProcess ( const char *  name)
◆ ClearInputVolumeWeightedArrayToProcess()
void vtkPVAMRFragmentIntegration::ClearInputVolumeWeightedArrayToProcess ( )
◆ AddInputMassWeightedArrayToProcess()
void vtkPVAMRFragmentIntegration::AddInputMassWeightedArrayToProcess ( const char *  name)
◆ ClearInputMassWeightedArrayToProcess()
void vtkPVAMRFragmentIntegration::ClearInputMassWeightedArrayToProcess ( )
◆ SetContourConnection()
void vtkPVAMRFragmentIntegration::SetContourConnection ( vtkAlgorithmOutput )
◆ RequestData()
int vtkPVAMRFragmentIntegration::RequestData ( vtkInformation ,
vtkInformationVector **  ,
◆ VolumeFractionSurfaceValue
double vtkPVAMRFragmentIntegration::VolumeFractionSurfaceValue
Definition at line 86 of file vtkPVAMRFragmentIntegration.h.
◆ Implementation
vtkPVAMRFragmentIntegrationInternal* vtkPVAMRFragmentIntegration::Implementation
Definition at line 87 of file vtkPVAMRFragmentIntegration.h.
