pqColorMapEditor is a widget that can be used to edit the active color-map, if any.
#include <pqColorMapEditor.h>
Inherits QWidget.
The panel is implemented as an auto-generated panel (similar to the Properties panel) that shows the properties on the lookup-table proxy. Custom widgets such as pqColorOpacityEditorWidget, pqColorAnnotationsPropertyWidget, and others are used to control certain properties on the proxy.
Definition at line 49 of file pqColorMapEditor.h.
◆ pqColorMapEditor()
| pqColorMapEditor::pqColorMapEditor |
QWidget * |
parent = 0 | ) |
◆ ~pqColorMapEditor()
| pqColorMapEditor::~pqColorMapEditor |
◆ updateActive
| void pqColorMapEditor::updateActive |
protectedslot |
slot called to update the currently showing proxies.
◆ updatePanel
| void pqColorMapEditor::updatePanel |
protectedslot |
slot called to update the visible widgets.
◆ renderViews
| void pqColorMapEditor::renderViews |
protectedslot |
render's view when transfer function is modified.
◆ saveAsDefault
| void pqColorMapEditor::saveAsDefault |
protectedslot |
Save the current transfer function(s) as default.
◆ saveAsArrayDefault
| void pqColorMapEditor::saveAsArrayDefault |
protectedslot |
Save the current transfer function(s) as default for arrays with the same name as the selected array.
◆ restoreDefaults
| void pqColorMapEditor::restoreDefaults |
protectedslot |
◆ setAutoUpdate
| void pqColorMapEditor::setAutoUpdate |
bool |
protectedslot |
called when AutoUpdate button is toggled.
◆ updateIfNeeded
| void pqColorMapEditor::updateIfNeeded |
protectedslot |
◆ setDataRepresentation()
◆ setColorTransferFunction()
| void pqColorMapEditor::setColorTransferFunction |
vtkSMProxy * |
ctf | ) |
◆ updateScalarBarButtons
| void pqColorMapEditor::updateScalarBarButtons |
protectedslot |
update the enabled state for show/edit scalar bar buttons.
◆ pqInternals
