pqApplyBehavior collects the logic that needs to happen after the user hits "Apply" on the pqPropertiesPanel. More...
#include <pqApplyBehavior.h>
Inherits QObject.
| pqApplyBehavior (QObject *parent=0) | |
| ~pqApplyBehavior () override | |
| void | registerPanel (pqPropertiesPanel *panel) |
| Register/unregister pqPropertiesPanel instances to monitor. More... | |
| void | unregisterPanel (pqPropertiesPanel *panel) |
Protected Slots | |
| virtual void | applied (pqPropertiesPanel *, pqProxy *) |
| virtual void | applied (pqPropertiesPanel *) |
| virtual void | showData (pqPipelineSource *source, pqView *view) |
| void | hideInputIfRequired (pqPipelineFilter *filter, pqView *view) |
Since "Apply" is an important concept in ParaView application, it gets its own behavior so applications can customize it, if needed.
For pqApplyBehavior to work, one needs to manually register pqPropertiesPanel instance(s). pqParaViewBehaviors does that automatically for pqPropertiesPanel instances available during the startup.
Definition at line 56 of file pqApplyBehavior.h.
| pqApplyBehavior::pqApplyBehavior | ( | QObject * | parent = 0 | ) |
| void pqApplyBehavior::registerPanel | ( | pqPropertiesPanel * | panel | ) |
| void pqApplyBehavior::unregisterPanel | ( | pqPropertiesPanel * | panel | ) |
protectedvirtualslot |
protectedvirtual |
