creates all standard ParaView behaviourspqParaViewBehaviors creates all the behaviors used by ParaView. More...
#include <pqParaViewBehaviors.h>
Inherits QObject.
| pqParaViewBehaviors (QMainWindow *window, QObject *parent=NULL) | |
| ~pqParaViewBehaviors () override | |
If your client is merely a branded version of ParaView, then you may want to simply use this behavior. You can also enable/disable behaviors created by pqParaViewBehaviors before instantiating the pqParaViewBehaviors instance by using static methods of the form pqParaViewBehaviors::setEnable<behavior name>(bool) e.g. pqParaViewBehaviors::setEnableStandardPropertyWidgets(false).
Since ParaView 5.1, ObjectPickingBehavior is disabled by default in ParaView.
Definition at line 78 of file pqParaViewBehaviors.h.
| pqParaViewBehaviors::pqParaViewBehaviors | ( | QMainWindow * | window, |
| QObject * | parent = NULL |
inlinestatic |
Definition at line 84 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 85 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 86 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 87 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 88 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 89 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 90 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 91 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 92 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 93 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 94 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 95 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 96 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 97 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 98 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 99 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 100 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 101 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 102 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 103 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 104 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 105 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 106 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 107 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 108 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 109 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Definition at line 110 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Controls whether pqUsageLoggingBehavior is created.
Disabled by default (except in the ParaView application itself).
Definition at line 118 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
Controls whether pqLiveSourceBehavior is created.
Definition at line 126 of file pqParaViewBehaviors.h.
inlinestatic |
inlinestatic |
By default, widgets like QComboBox, QSlider handle wheel event even when the widget doesn't have the focus.
While that's handy, in many use-cases, in several where these are embedded in scrollable panels, they can interrupt the scrolling of the panel. Hence, this behavior has been added since ParaView 5.5 default. When enabled, this is enabled for QComboBox, QSlider, QAbstractSpinBox and subclasses.
Definition at line 138 of file pqParaViewBehaviors.h.
inlinestatic |
