vtkSMProxyClipboard Class Reference
helper class to help copy/paste properties on proxies. More...
#include <vtkSMProxyClipboard.h>
Inheritance diagram for vtkSMProxyClipboard:
Collaboration diagram for vtkSMProxyClipboard:
bool Copy (vtkSMProxy *source)
 Put a proxy's state on the clipboard. More...
bool CanPaste (vtkSMProxy *target)
 Returns true of the proxy state on the clipboard can be pasted on to the specified target. More...
bool Paste (vtkSMProxy *target)
 Paste the state on the clipboard on to the target proxy. More...
void Clear ()
 Clears the clipboard. More...
- Public Member Functions inherited from vtkSMObject
static vtkSMProxyClipboard * New ()
static vtkSMProxyClipboard * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyClipboard ()
 ~vtkSMProxyClipboard () override
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyClipboard is a helper class used to enable copy/paste for properties on proxies. Copy/Paste is more that simply copying values from a proxy to another (for which one should simply use vtkSMProxy::Copy()). This has several extra smarts including the following:
Definition at line 34 of file vtkSMProxyClipboard.h.
Definition at line 38 of file vtkSMProxyClipboard.h.
◆ vtkSMProxyClipboard()
vtkSMProxyClipboard::vtkSMProxyClipboard ( )
◆ ~vtkSMProxyClipboard()
vtkSMProxyClipboard::~vtkSMProxyClipboard ( )
static vtkSMProxyClipboard* vtkSMProxyClipboard::New ( )
virtual const char* vtkSMProxyClipboard::GetClassName ( )
static int vtkSMProxyClipboard::IsTypeOf ( const char *  type)
virtual int vtkSMProxyClipboard::IsA ( const char *  type)
static vtkSMProxyClipboard* vtkSMProxyClipboard::SafeDownCast ( vtkObject *  o)
void vtkSMProxyClipboard::PrintSelf ( ostream &  os,
◆ Copy()
bool vtkSMProxyClipboard::Copy ( vtkSMProxy *  source)
Return true if the operation was successful.
◆ CanPaste()
bool vtkSMProxyClipboard::CanPaste ( vtkSMProxy *  target)
Current implementation doesn't check for the types of the proxies. In future, we can make this type-aware or add other criteria.
◆ Paste()
bool vtkSMProxyClipboard::Paste ( vtkSMProxy *  target)
◆ Clear()
void vtkSMProxyClipboard::Clear ( void  )
inline
Same as calling Copy(nullptr).
Definition at line 62 of file vtkSMProxyClipboard.h.
