vtkSMAnimationSceneWriter Class Referenceabstract
helper class used to write animations. More...
#include <vtkSMAnimationSceneWriter.h>
Inheritance diagram for vtkSMAnimationSceneWriter:
Collaboration diagram for vtkSMAnimationSceneWriter:
virtual void SetAnimationScene (vtkSMProxy *)
 Convenience method to set the proxy. More...
bool Save ()
 Begin the saving. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Get/Set the animation scene that this writer will write. More...
virtual vtkSMAnimationScene * GetAnimationScene ()
 Get/Set the filename. More...
virtual char * GetFileName ()
virtual void SetStartFileCount (int)
 Get/Set the start file count. More...
virtual int GetStartFileCount ()
virtual void SetPlaybackTimeWindow (double, double)
 Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
void SetPlaybackTimeWindow (double [2])
virtual double * GetPlaybackTimeWindow ()
virtual void GetPlaybackTimeWindow (double &, double &)
virtual void GetPlaybackTimeWindow (double [2])
virtual void SetStride (int)
 Set/Get The stride which is used to extract the next frame. More...
virtual int GetStride ()
virtual void SetSession (vtkSMSession *)
static vtkSMAnimationSceneWriter * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMAnimationSceneWriter ()
 ~vtkSMAnimationSceneWriter () override
virtual bool SaveInitialize (int countStart)=0
 Subclasses should override this method. More...
virtual bool SaveFrame (double time)=0
virtual bool SaveFinalize ()=0
void ExecuteEvent (vtkObject *caller, unsigned long eventid, void *calldata)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
unsigned long ObserverID
vtkSMAnimationScene * AnimationScene
bool Saving
bool SaveFailed
char * FileName
double PlaybackTimeWindow [2]
int StartFileCount
int Stride = 1
vtkSMAnimationSceneWriter is an abstract superclass for writers that can write animations out.
Definition at line 21 of file vtkSMAnimationSceneWriter.h.
Definition at line 24 of file vtkSMAnimationSceneWriter.h.
◆ vtkSMAnimationSceneWriter()
vtkSMAnimationSceneWriter::vtkSMAnimationSceneWriter ( )
◆ ~vtkSMAnimationSceneWriter()
vtkSMAnimationSceneWriter::~vtkSMAnimationSceneWriter ( )
virtual const char* vtkSMAnimationSceneWriter::GetClassName ( )
static int vtkSMAnimationSceneWriter::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationSceneWriter::IsA ( const char *  type)
static vtkSMAnimationSceneWriter* vtkSMAnimationSceneWriter::SafeDownCast ( vtkObject *  o)
void vtkSMAnimationSceneWriter::PrintSelf ( ostream &  os,
◆ SetAnimationScene() [1/2]
virtual void vtkSMAnimationSceneWriter::SetAnimationScene ( vtkSMProxy *  )
◆ SetAnimationScene() [2/2]
virtual void vtkSMAnimationSceneWriter::SetAnimationScene ( vtkSMAnimationScene *  )
◆ GetAnimationScene()
virtual vtkSMAnimationScene* vtkSMAnimationSceneWriter::GetAnimationScene ( )
◆ Save()
bool vtkSMAnimationSceneWriter::Save ( )
Begin the saving.
This will result in playing of the animation. Returns the status of the save.
◆ SetFileName()
virtual void vtkSMAnimationSceneWriter::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkSMAnimationSceneWriter::GetFileName ( )
◆ SetStartFileCount()
virtual void vtkSMAnimationSceneWriter::SetStartFileCount ( int  )
◆ GetStartFileCount()
virtual int vtkSMAnimationSceneWriter::GetStartFileCount ( )
◆ SetPlaybackTimeWindow() [1/2]
virtual void vtkSMAnimationSceneWriter::SetPlaybackTimeWindow ( double  ,
double
◆ SetPlaybackTimeWindow() [2/2]
void vtkSMAnimationSceneWriter::SetPlaybackTimeWindow ( double  [2])
◆ GetPlaybackTimeWindow() [1/3]
virtual double* vtkSMAnimationSceneWriter::GetPlaybackTimeWindow ( )
◆ GetPlaybackTimeWindow() [2/3]
virtual void vtkSMAnimationSceneWriter::GetPlaybackTimeWindow ( double &  ,
double &
◆ GetPlaybackTimeWindow() [3/3]
virtual void vtkSMAnimationSceneWriter::GetPlaybackTimeWindow ( double  [2])
◆ SetStride()
virtual void vtkSMAnimationSceneWriter::SetStride ( int  )
E.g. 1, 2, 3, would have stride = 1, while 1, 3, 5 would have stride = 2.
Default value is 1.
◆ GetStride()
virtual int vtkSMAnimationSceneWriter::GetStride ( )
Default value is 1.
◆ SaveInitialize()
virtual bool vtkSMAnimationSceneWriter::SaveInitialize ( int  countStart)
protectedpure virtual
Called to initialize saving.
Implemented in vtkSMAnimationSceneWebWriter, and vtkSMAnimationSceneGeometryWriter.
◆ SaveFrame()
virtual bool vtkSMAnimationSceneWriter::SaveFrame ( double  time)
Called to save a particular frame.
◆ SaveFinalize()
virtual bool vtkSMAnimationSceneWriter::SaveFinalize ( )
Called to finalize saving.
◆ ExecuteEvent()
void vtkSMAnimationSceneWriter::ExecuteEvent ( vtkObject *  caller,
void *  calldata
◆ ObserverID
unsigned long vtkSMAnimationSceneWriter::ObserverID
Definition at line 87 of file vtkSMAnimationSceneWriter.h.
◆ AnimationScene
vtkSMAnimationScene* vtkSMAnimationSceneWriter::AnimationScene
Definition at line 88 of file vtkSMAnimationSceneWriter.h.
◆ Saving
bool vtkSMAnimationSceneWriter::Saving
Definition at line 112 of file vtkSMAnimationSceneWriter.h.
◆ SaveFailed
bool vtkSMAnimationSceneWriter::SaveFailed
Definition at line 113 of file vtkSMAnimationSceneWriter.h.
◆ FileName
char* vtkSMAnimationSceneWriter::FileName
Definition at line 114 of file vtkSMAnimationSceneWriter.h.
◆ PlaybackTimeWindow
double vtkSMAnimationSceneWriter::PlaybackTimeWindow[2]
Definition at line 115 of file vtkSMAnimationSceneWriter.h.
◆ StartFileCount
int vtkSMAnimationSceneWriter::StartFileCount
Definition at line 116 of file vtkSMAnimationSceneWriter.h.
◆ Stride
int vtkSMAnimationSceneWriter::Stride = 1
Definition at line 117 of file vtkSMAnimationSceneWriter.h.
