vtkSMAnimationSceneWebWriter Class Reference
helper class to write animation geometry in a web archive. More...
#include <vtkSMAnimationSceneWebWriter.h>
Inheritance diagram for vtkSMAnimationSceneWebWriter:
Collaboration diagram for vtkSMAnimationSceneWebWriter:
typedef vtkSMAnimationSceneWriter Superclass
- Public Types inherited from vtkSMAnimationSceneWriter
virtual vtkSMRenderViewProxy * GetRenderView ()
 Get/Set the (render) View Module from which we are writing the geometry. More...
void SetRenderView (vtkSMRenderViewProxy *)
- Public Member Functions inherited from vtkSMAnimationSceneWriter
virtual void SetAnimationScene (vtkSMProxy *)
 Convenience method to set the proxy. More...
bool Save ()
 Begin the saving. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Get/Set the animation scene that this writer will write. More...
virtual vtkSMAnimationScene * GetAnimationScene ()
 Get/Set the filename. More...
virtual char * GetFileName ()
virtual void SetStartFileCount (int)
 Get/Set the start file count. More...
virtual int GetStartFileCount ()
virtual void SetPlaybackTimeWindow (double, double)
 Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
void SetPlaybackTimeWindow (double [2])
virtual double * GetPlaybackTimeWindow ()
virtual void GetPlaybackTimeWindow (double &, double &)
virtual void GetPlaybackTimeWindow (double [2])
virtual void SetStride (int)
 Set/Get The stride which is used to extract the next frame. More...
virtual int GetStride ()
virtual void SetSession (vtkSMSession *)
static vtkSMAnimationSceneWebWriter * New ()
static vtkSMAnimationSceneWebWriter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMAnimationSceneWriter
static vtkSMAnimationSceneWriter * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMAnimationSceneWebWriter ()
 ~vtkSMAnimationSceneWebWriter () override
bool SaveInitialize (int startCount) override
 Called to initialize saving. More...
bool SaveFrame (double time) override
 Called to save a particular frame. More...
bool SaveFinalize () override
 Called to finalize saving. More...
- Protected Member Functions inherited from vtkSMAnimationSceneWriter
 vtkSMAnimationSceneWriter ()
 ~vtkSMAnimationSceneWriter () override
void ExecuteEvent (vtkObject *caller, unsigned long eventid, void *calldata)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMRenderViewProxy * RenderView = nullptr
- Protected Attributes inherited from vtkSMAnimationSceneWriter
unsigned long ObserverID
vtkSMAnimationScene * AnimationScene
bool Saving
bool SaveFailed
char * FileName
double PlaybackTimeWindow [2]
int StartFileCount
int Stride = 1
vtkSMAnimationSceneWebWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write the geometry as a web archive. This writer can only write the visible geometry in one view.
Definition at line 22 of file vtkSMAnimationSceneWebWriter.h.
Definition at line 26 of file vtkSMAnimationSceneWebWriter.h.
◆ vtkSMAnimationSceneWebWriter()
vtkSMAnimationSceneWebWriter::vtkSMAnimationSceneWebWriter ( )
◆ ~vtkSMAnimationSceneWebWriter()
vtkSMAnimationSceneWebWriter::~vtkSMAnimationSceneWebWriter ( )
static vtkSMAnimationSceneWebWriter* vtkSMAnimationSceneWebWriter::New ( )
virtual const char* vtkSMAnimationSceneWebWriter::GetClassName ( )
Reimplemented from vtkSMAnimationSceneWriter.
static int vtkSMAnimationSceneWebWriter::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationSceneWebWriter::IsA ( const char *  type)
static vtkSMAnimationSceneWebWriter* vtkSMAnimationSceneWebWriter::SafeDownCast ( vtkObject *  o)
void vtkSMAnimationSceneWebWriter::PrintSelf ( ostream &  os,
◆ GetRenderView()
virtual vtkSMRenderViewProxy* vtkSMAnimationSceneWebWriter::GetRenderView ( )
◆ SetRenderView()
void vtkSMAnimationSceneWebWriter::SetRenderView ( vtkSMRenderViewProxy *  )
◆ SaveInitialize()
bool vtkSMAnimationSceneWebWriter::SaveInitialize ( int  startCount)
overrideprotectedvirtual
Implements vtkSMAnimationSceneWriter.
◆ SaveFrame()
bool vtkSMAnimationSceneWebWriter::SaveFrame ( double  time)
◆ SaveFinalize()
bool vtkSMAnimationSceneWebWriter::SaveFinalize ( )
◆ RenderView
vtkSMRenderViewProxy* vtkSMAnimationSceneWebWriter::RenderView = nullptr
Definition at line 55 of file vtkSMAnimationSceneWebWriter.h.
