vtkSMAnimationSceneGeometryWriter Class Reference
helper class to write animation geometry in a data file. More...
#include <vtkSMAnimationSceneGeometryWriter.h>
Inheritance diagram for vtkSMAnimationSceneGeometryWriter:
Collaboration diagram for vtkSMAnimationSceneGeometryWriter:
typedef vtkSMAnimationSceneWriter Superclass
- Public Types inherited from vtkSMAnimationSceneWriter
virtual vtkSMProxy * GetViewModule ()
void SetViewModule (vtkSMProxy *)
- Public Member Functions inherited from vtkSMAnimationSceneWriter
virtual void SetAnimationScene (vtkSMProxy *)
 Convenience method to set the proxy. More...
bool Save ()
 Begin the saving. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Get/Set the animation scene that this writer will write. More...
virtual vtkSMAnimationScene * GetAnimationScene ()
 Get/Set the filename. More...
virtual char * GetFileName ()
virtual void SetStartFileCount (int)
 Get/Set the start file count. More...
virtual int GetStartFileCount ()
virtual void SetPlaybackTimeWindow (double, double)
 Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
void SetPlaybackTimeWindow (double [2])
virtual double * GetPlaybackTimeWindow ()
virtual void GetPlaybackTimeWindow (double &, double &)
virtual void GetPlaybackTimeWindow (double [2])
virtual void SetStride (int)
 Set/Get The stride which is used to extract the next frame. More...
virtual int GetStride ()
virtual void SetSession (vtkSMSession *)
static vtkSMAnimationSceneGeometryWriter * New ()
static vtkSMAnimationSceneGeometryWriter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMAnimationSceneWriter
static vtkSMAnimationSceneWriter * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMAnimationSceneGeometryWriter ()
 ~vtkSMAnimationSceneGeometryWriter () override
bool SaveInitialize (int startCount) override
 Called to initialize saving. More...
bool SaveFrame (double time) override
 Called to save a particular frame. More...
bool SaveFinalize () override
 Called to finalize saving. More...
- Protected Member Functions inherited from vtkSMAnimationSceneWriter
 vtkSMAnimationSceneWriter ()
 ~vtkSMAnimationSceneWriter () override
void ExecuteEvent (vtkObject *caller, unsigned long eventid, void *calldata)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxy * GeometryWriter
vtkSMProxy * ViewModule
- Protected Attributes inherited from vtkSMAnimationSceneWriter
unsigned long ObserverID
vtkSMAnimationScene * AnimationScene
bool Saving
bool SaveFailed
char * FileName
double PlaybackTimeWindow [2]
int StartFileCount
int Stride = 1
vtkSMAnimationSceneGeometryWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write the geometry as a data file. This writer can only write the visible geometry in one view.
Definition at line 21 of file vtkSMAnimationSceneGeometryWriter.h.
Definition at line 26 of file vtkSMAnimationSceneGeometryWriter.h.
◆ vtkSMAnimationSceneGeometryWriter()
vtkSMAnimationSceneGeometryWriter::vtkSMAnimationSceneGeometryWriter ( )
◆ ~vtkSMAnimationSceneGeometryWriter()
vtkSMAnimationSceneGeometryWriter::~vtkSMAnimationSceneGeometryWriter ( )
static vtkSMAnimationSceneGeometryWriter* vtkSMAnimationSceneGeometryWriter::New ( )
virtual const char* vtkSMAnimationSceneGeometryWriter::GetClassName ( )
Reimplemented from vtkSMAnimationSceneWriter.
static int vtkSMAnimationSceneGeometryWriter::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationSceneGeometryWriter::IsA ( const char *  type)
static vtkSMAnimationSceneGeometryWriter* vtkSMAnimationSceneGeometryWriter::SafeDownCast ( vtkObject *  o)
void vtkSMAnimationSceneGeometryWriter::PrintSelf ( ostream &  os,
◆ GetViewModule()
virtual vtkSMProxy* vtkSMAnimationSceneGeometryWriter::GetViewModule ( )
◆ SetViewModule()
void vtkSMAnimationSceneGeometryWriter::SetViewModule ( vtkSMProxy *  )
◆ SaveInitialize()
bool vtkSMAnimationSceneGeometryWriter::SaveInitialize ( int  startCount)
overrideprotectedvirtual
Implements vtkSMAnimationSceneWriter.
◆ SaveFrame()
bool vtkSMAnimationSceneGeometryWriter::SaveFrame ( double  time)
◆ SaveFinalize()
bool vtkSMAnimationSceneGeometryWriter::SaveFinalize ( )
◆ GeometryWriter
vtkSMProxy* vtkSMAnimationSceneGeometryWriter::GeometryWriter
Definition at line 53 of file vtkSMAnimationSceneGeometryWriter.h.
◆ ViewModule
vtkSMProxy* vtkSMAnimationSceneGeometryWriter::ViewModule
Definition at line 54 of file vtkSMAnimationSceneGeometryWriter.h.
