vtkGridAxes3DActor Class Reference
actor for a cube-axes like prop in the 3D view. More...
#include <vtkGridAxes3DActor.h>
Inheritance diagram for vtkGridAxes3DActor:
Collaboration diagram for vtkGridAxes3DActor:
enum  FaceMasks {
  MIN_YZ = 0x01, MIN_ZX = 0x02, MIN_XY = 0x04, MAX_YZ = 0x08,
  MAX_ZX = 0x010, MAX_XY = 0x020
 Values for FaceMask. More...
enum  LabelMasks {
  MIN_X = vtkGridAxesHelper::MIN_X, MIN_Y = vtkGridAxesHelper::MIN_Y, MIN_Z = vtkGridAxesHelper::MIN_Z, MAX_X = vtkGridAxesHelper::MAX_X,
  MAX_Y = vtkGridAxesHelper::MAX_Y, MAX_Z = vtkGridAxesHelper::MAX_Z
typedef vtkProp3D Superclass
- Public Types inherited from vtkProp3D
typedef vtkProp Superclass
void ShallowCopy (vtkProp *prop) override
 Shallow copy from another vtkGridAxes3DActor. More...
void GetActors (vtkPropCollection *) override
 For some exporters and other other operations we must be able to collect all the actors or volumes. More...
void UpdateGeometry (vtkViewport *vp)
 Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
void SetUseCustomLabels (int axis, bool val)
 Set whether the specified axis should use custom labels instead of automatically determined ones. More...
void SetXUseCustomLabels (bool val)
void SetYUseCustomLabels (bool val)
void SetZUseCustomLabels (bool val)
void SetNumberOfLabels (int axis, vtkIdType val)
void SetNumberOfXLabels (vtkIdType val)
void SetNumberOfYLabels (vtkIdType val)
void SetNumberOfZLabels (vtkIdType val)
void SetLabel (int axis, vtkIdType index, double value)
void SetXLabel (vtkIdType index, double value)
void SetYLabel (vtkIdType index, double value)
void SetZLabel (vtkIdType index, double value)
virtual void GetRenderedBounds (double bounds[6])
 Get an bounding box that is expected to contain all rendered elements, since GetBounds() returns the bounding box the grid axes describes. More...
int RenderOpaqueGeometry (vtkViewport *) override
int RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override
int RenderOverlay (vtkViewport *viewport) override
int HasTranslucentPolygonalGeometry () override
void ReleaseGraphicsResources (vtkWindow *) override
virtual void SetGridBounds (double, double, double, double, double, double)
 Set the bounding box defining the grid space. More...
virtual void SetGridBounds (double [6])
virtual double * GetGridBounds ()
virtual void GetGridBounds (double &, double &, double &, double &, double &, double &)
virtual void GetGridBounds (double [6])
virtual void SetFaceMask (unsigned int mask)
 Set the mask to select faces. More...
virtual unsigned int GetFaceMask ()
virtual void SetLabelMask (unsigned int mask)
 Set the axis to label. More...
unsigned int GetLabelMask ()
virtual void SetLabelUniqueEdgesOnly (bool)
 Set to true to only label edges shared with 1 face. More...
virtual bool GetLabelUniqueEdgesOnly ()
void SetGenerateGrid (bool val)
 Turn off to not generate polydata for the plane's grid. More...
bool GetGenerateGrid ()
virtual void GenerateGridOn ()
virtual void GenerateGridOff ()
void SetGenerateEdges (bool val)
 Turn off to not generate the polydata for the plane's edges. More...
bool GetGenerateEdges ()
virtual void GenerateEdgesOn ()
virtual void GenerateEdgesOff ()
void SetGenerateTicks (bool val)
 Turn off to not generate the markers for the tick positions. More...
bool GetGenerateTicks ()
virtual void GenerateTicksOn ()
virtual void GenerateTicksOff ()
void SetProperty (vtkProperty *)
 Get/Set the property used to control the appearance of the rendered grid. More...
vtkProperty * GetProperty ()
void SetTitleTextProperty (int axis, vtkTextProperty *)
 Get/Set the vtkTextProperty for the title for each the axes. More...
void SetXTitleTextProperty (vtkTextProperty *prop)
void SetYTitleTextProperty (vtkTextProperty *prop)
void SetZTitleTextProperty (vtkTextProperty *prop)
vtkTextProperty * GetTitleTextProperty (int axis)
void SetTitle (int axis, const std::string &title)
 Get/Set the text to use for titles for the axis. More...
void SetXTitle (const std::string &title)
void SetYTitle (const std::string &title)
void SetZTitle (const std::string &title)
const std::string & GetTitle (int axis)
void SetLabelTextProperty (int axis, vtkTextProperty *)
 Get/Set the vtkTextProperty that governs how the axis labels are displayed. More...
void SetXLabelTextProperty (vtkTextProperty *prop)
void SetYLabelTextProperty (vtkTextProperty *prop)
void SetZLabelTextProperty (vtkTextProperty *prop)
vtkTextProperty * GetLabelTextProperty (int axis)
void SetNotation (int axis, int notation)
 Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More...
void SetXNotation (int notation)
void SetYNotation (int notation)
void SetZNotation (int notation)
int GetNotation (int axis)
void SetPrecision (int axis, int val)
 Get/set the numerical precision to use, default is 2. More...
void SetXPrecision (int val)
void SetYPrecision (int val)
void SetZPrecision (int val)
int GetPrecision (int axis)
void SetTickLabelFunction (int axis, std::function< double(double)> func)
 Get/Set the function that will be applied to the tick label of each axis. More...
std::function< double(double)> GetTickLabelFunction (int axis)
double * GetBounds () override
 Returns the prop bounds. More...
virtual void SetForceOpaque (bool)
 If true, the actor will always be rendered during the opaque pass. More...
virtual bool GetForceOpaque ()
virtual void ForceOpaqueOn ()
virtual void ForceOpaqueOff ()
- Public Member Functions inherited from vtkProp3D
vtkProp3D * NewInstance () const
virtual void SetPosition (double pos[3])
virtual double * GetPosition ()
virtual void GetPosition (double data[3])
void AddPosition (double deltaPosition[3])
void AddPosition (double deltaX, double deltaY, double deltaZ)
double * GetCenter ()
double * GetXRange ()
double * GetYRange ()
double * GetZRange ()
double GetLength ()
void RotateX (double)
void RotateY (double)
void RotateZ (double)
void RotateWXYZ (double w, double x, double y, double z)
void SetOrientation (double x, double y, double z)
void SetOrientation (double orientation[3])
double * GetOrientationWXYZ ()
void AddOrientation (double x, double y, double z)
void AddOrientation (double orentation[3])
void PokeMatrix (vtkMatrix4x4 *matrix)
void InitPathTraversal ()
vtkMTimeType GetMTime ()
vtkMTimeType GetUserTransformMatrixMTime ()
virtual void ComputeMatrix ()
virtual void SetPosition (double x, double y, double z)
virtual void SetOrigin (double x, double y, double z)
virtual void SetOrigin (const double pos[3])
virtual double * GetOrigin ()
virtual void GetOrigin (double data[3])
virtual void SetScale (double x, double y, double z)
virtual void SetScale (double scale[3])
virtual double * GetScale ()
virtual void GetScale (double data[3])
void SetScale (double s)
void SetUserTransform (vtkLinearTransform *transform)
virtual vtkLinearTransform * GetUserTransform ()
void SetUserMatrix (vtkMatrix4x4 *matrix)
vtkMatrix4x4 * GetUserMatrix ()
virtual void GetMatrix (vtkMatrix4x4 *m)
virtual void GetMatrix (double m[16])
void GetBounds (double bounds[6])
double * GetOrientation ()
void GetOrientation (double orentation[3])
vtkMatrix4x4 * GetMatrix ()
virtual int GetIsIdentity ()
vtkProp * NewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors2D (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual vtkMTimeType GetRedrawMTime ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual vtkAssemblyPath * GetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkInformation * GetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual bool GetSupportsSelection ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObject * GetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkGridAxes3DActor * New ()
static vtkGridAxes3DActor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkProp3D
static vtkProp3D * SafeDownCast (vtkObjectBase *o)
static vtkProp * SafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKey * GeneralTextureUnit ()
static vtkInformationDoubleVectorKey * GeneralTextureTransform ()
 vtkGridAxes3DActor ()
 ~vtkGridAxes3DActor () override
virtual void Update (vtkViewport *viewport)
- Protected Member Functions inherited from vtkProp3D
 vtkProp3D ()
 ~vtkProp3D ()
 vtkProp ()
 ~vtkProp ()
double GridBounds [6]
unsigned int FaceMask
unsigned int LabelMask
bool LabelUniqueEdgesOnly
vtkTuple< bool, 3 > UseCustomLabels
vtkTuple< vtkNew< vtkDoubleArray >, 3 > CustomLabels
vtkMTimeType CustomLabelsMTime
vtkTuple< vtkNew< vtkGridAxes2DActor >, 6 > GridAxes2DActors
bool ForceOpaque
- Protected Attributes inherited from vtkProp3D
vtkLinearTransform * UserTransform
vtkMatrix4x4 * UserMatrix
vtkMatrix4x4 * Matrix
vtkTimeStamp MatrixMTime
double Origin [3]
double Position [3]
double Orientation [3]
double Scale [3]
double Center [3]
vtkTransform * Transform
double Bounds [6]
vtkProp3D * CachedProp3D
int IsIdentity
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPaths * Paths
vtkInformation * PropertyKeys
vtkGridAxes3DActor is an alternate implementation for something like the vtkCubeAxesActor which can be used to render a 3D grid in a scene. It uses vtkGridAxes2DActor to render individual axes planes for the box.
Definition at line 30 of file vtkGridAxes3DActor.h.
Definition at line 34 of file vtkGridAxes3DActor.h.
◆ FaceMasks
Developer note: these are deliberately in the same order as vtkGridAxesHelper::Faces which is same order as faces in vtkVoxel.
Enumerator
MIN_YZ
MIN_ZX
MIN_XY
MAX_YZ
MAX_ZX
MAX_XY
Definition at line 57 of file vtkGridAxes3DActor.h.
◆ LabelMasks
Enumerator
MIN_X
MIN_Y
MIN_Z
MAX_X
MAX_Y
MAX_Z
Definition at line 77 of file vtkGridAxes3DActor.h.
◆ vtkGridAxes3DActor()
vtkGridAxes3DActor::vtkGridAxes3DActor ( )
◆ ~vtkGridAxes3DActor()
vtkGridAxes3DActor::~vtkGridAxes3DActor ( )
static vtkGridAxes3DActor* vtkGridAxes3DActor::New ( )
virtual const char* vtkGridAxes3DActor::GetClassName ( )
Reimplemented in vtkPVGridAxes3DActor.
static int vtkGridAxes3DActor::IsTypeOf ( const char *  type)
virtual int vtkGridAxes3DActor::IsA ( const char *  type)
Reimplemented from vtkProp3D.
static vtkGridAxes3DActor* vtkGridAxes3DActor::SafeDownCast ( vtkObject *  o)
void vtkGridAxes3DActor::PrintSelf ( ostream &  os,
◆ ShallowCopy()
void vtkGridAxes3DActor::ShallowCopy ( vtkProp *  prop)
◆ SetGridBounds() [1/2]
virtual void vtkGridAxes3DActor::SetGridBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
This, together with the Face identify which planar surface this class is interested in. This class is designed to work with a single planar surface.
◆ SetGridBounds() [2/2]
virtual void vtkGridAxes3DActor::SetGridBounds ( double  [6])
◆ GetGridBounds() [1/3]
virtual double* vtkGridAxes3DActor::GetGridBounds ( )
◆ GetGridBounds() [2/3]
virtual void vtkGridAxes3DActor::GetGridBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetGridBounds() [3/3]
virtual void vtkGridAxes3DActor::GetGridBounds ( double  [6])
◆ SetFaceMask()
virtual void vtkGridAxes3DActor::SetFaceMask ( unsigned int  mask)
The faces rendered can be a subset of the faces selected using the FaceMask based on the BackfaceCulling and FrontfaceCulling flags set on the Property.
◆ GetFaceMask()
virtual unsigned int vtkGridAxes3DActor::GetFaceMask ( )
◆ SetLabelMask()
virtual void vtkGridAxes3DActor::SetLabelMask ( unsigned int  mask)
◆ GetLabelMask()
unsigned int vtkGridAxes3DActor::GetLabelMask ( )
◆ GetActors()
void vtkGridAxes3DActor::GetActors ( vtkPropCollection *  )
These methods are used in that process. In case the viewport is not a consumer of this prop: call UpdateGeometry() first for updated viewport-specific billboard geometry.
Reimplemented from vtkProp.
◆ UpdateGeometry()
void vtkGridAxes3DActor::UpdateGeometry ( vtkViewport *  vp)
◆ SetLabelUniqueEdgesOnly()
virtual void vtkGridAxes3DActor::SetLabelUniqueEdgesOnly ( bool  )
Note that if all faces are being rendered, this will generate no labels.
◆ GetLabelUniqueEdgesOnly()
virtual bool vtkGridAxes3DActor::GetLabelUniqueEdgesOnly ( )
◆ SetGenerateGrid()
void vtkGridAxes3DActor::SetGenerateGrid ( bool  val)
◆ GetGenerateGrid()
bool vtkGridAxes3DActor::GetGenerateGrid ( )
◆ GenerateGridOn()
virtual void vtkGridAxes3DActor::GenerateGridOn ( )
◆ GenerateGridOff()
virtual void vtkGridAxes3DActor::GenerateGridOff ( )
◆ SetGenerateEdges()
void vtkGridAxes3DActor::SetGenerateEdges ( bool  val)
Which edges are rendered is defined by the EdgeMask.
◆ GetGenerateEdges()
bool vtkGridAxes3DActor::GetGenerateEdges ( )
◆ GenerateEdgesOn()
virtual void vtkGridAxes3DActor::GenerateEdgesOn ( )
◆ GenerateEdgesOff()
virtual void vtkGridAxes3DActor::GenerateEdgesOff ( )
◆ SetGenerateTicks()
void vtkGridAxes3DActor::SetGenerateTicks ( bool  val)
Which edges are rendered is defined by the TickMask.
◆ GetGenerateTicks()
bool vtkGridAxes3DActor::GetGenerateTicks ( )
◆ GenerateTicksOn()
virtual void vtkGridAxes3DActor::GenerateTicksOn ( )
◆ GenerateTicksOff()
virtual void vtkGridAxes3DActor::GenerateTicksOff ( )
◆ SetProperty()
void vtkGridAxes3DActor::SetProperty ( vtkProperty *  )
◆ GetProperty()
vtkProperty* vtkGridAxes3DActor::GetProperty ( )
◆ SetTitleTextProperty()
void vtkGridAxes3DActor::SetTitleTextProperty ( int  axis,
vtkTextProperty *
Note that the alignment properties are not used.
◆ SetXTitleTextProperty()
void vtkGridAxes3DActor::SetXTitleTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 166 of file vtkGridAxes3DActor.h.
◆ SetYTitleTextProperty()
void vtkGridAxes3DActor::SetYTitleTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 167 of file vtkGridAxes3DActor.h.
◆ SetZTitleTextProperty()
void vtkGridAxes3DActor::SetZTitleTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 168 of file vtkGridAxes3DActor.h.
◆ GetTitleTextProperty()
vtkTextProperty* vtkGridAxes3DActor::GetTitleTextProperty ( int  axis)
◆ SetTitle()
void vtkGridAxes3DActor::SetTitle ( int  axis,
const std::string &  title
Setting the title to an empty string will hide the title label for that axis.
◆ SetXTitle()
void vtkGridAxes3DActor::SetXTitle ( const std::string &  title)
inline
Definition at line 178 of file vtkGridAxes3DActor.h.
◆ SetYTitle()
void vtkGridAxes3DActor::SetYTitle ( const std::string &  title)
inline
Definition at line 179 of file vtkGridAxes3DActor.h.
◆ SetZTitle()
void vtkGridAxes3DActor::SetZTitle ( const std::string &  title)
inline
Definition at line 180 of file vtkGridAxes3DActor.h.
◆ GetTitle()
const std::string& vtkGridAxes3DActor::GetTitle ( int  axis)
◆ SetUseCustomLabels()
void vtkGridAxes3DActor::SetUseCustomLabels ( int  axis,
bool  val
◆ SetXUseCustomLabels()
void vtkGridAxes3DActor::SetXUseCustomLabels ( bool  val)
inline
Definition at line 189 of file vtkGridAxes3DActor.h.
◆ SetYUseCustomLabels()
void vtkGridAxes3DActor::SetYUseCustomLabels ( bool  val)
inline
Definition at line 190 of file vtkGridAxes3DActor.h.
◆ SetZUseCustomLabels()
void vtkGridAxes3DActor::SetZUseCustomLabels ( bool  val)
inline
Definition at line 191 of file vtkGridAxes3DActor.h.
◆ SetNumberOfLabels()
void vtkGridAxes3DActor::SetNumberOfLabels ( int  axis,
vtkIdType  val
◆ SetNumberOfXLabels()
void vtkGridAxes3DActor::SetNumberOfXLabels ( vtkIdType  val)
inline
Definition at line 194 of file vtkGridAxes3DActor.h.
◆ SetNumberOfYLabels()
void vtkGridAxes3DActor::SetNumberOfYLabels ( vtkIdType  val)
inline
Definition at line 195 of file vtkGridAxes3DActor.h.
◆ SetNumberOfZLabels()
void vtkGridAxes3DActor::SetNumberOfZLabels ( vtkIdType  val)
inline
Definition at line 196 of file vtkGridAxes3DActor.h.
◆ SetLabel()
void vtkGridAxes3DActor::SetLabel ( int  axis,
vtkIdType  index,
double  value
◆ SetXLabel()
void vtkGridAxes3DActor::SetXLabel ( vtkIdType  index,
double  value
inline
Definition at line 199 of file vtkGridAxes3DActor.h.
◆ SetYLabel()
void vtkGridAxes3DActor::SetYLabel ( vtkIdType  index,
double  value
inline
Definition at line 200 of file vtkGridAxes3DActor.h.
◆ SetZLabel()
void vtkGridAxes3DActor::SetZLabel ( vtkIdType  index,
double  value
inline
Definition at line 201 of file vtkGridAxes3DActor.h.
◆ SetLabelTextProperty()
void vtkGridAxes3DActor::SetLabelTextProperty ( int  axis,
vtkTextProperty *
◆ SetXLabelTextProperty()
void vtkGridAxes3DActor::SetXLabelTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 212 of file vtkGridAxes3DActor.h.
◆ SetYLabelTextProperty()
void vtkGridAxes3DActor::SetYLabelTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 213 of file vtkGridAxes3DActor.h.
◆ SetZLabelTextProperty()
void vtkGridAxes3DActor::SetZLabelTextProperty ( vtkTextProperty *  prop)
inline
Definition at line 214 of file vtkGridAxes3DActor.h.
◆ GetLabelTextProperty()
vtkTextProperty* vtkGridAxes3DActor::GetLabelTextProperty ( int  axis)
◆ SetNotation()
void vtkGridAxes3DActor::SetNotation ( int  axis,
int  notation
Accepted values are vtkAxis::AUTO, vtkAxis::FIXED, vtkAxis::CUSTOM.
◆ SetXNotation()
void vtkGridAxes3DActor::SetXNotation ( int  notation)
inline
Definition at line 224 of file vtkGridAxes3DActor.h.
◆ SetYNotation()
void vtkGridAxes3DActor::SetYNotation ( int  notation)
inline
Definition at line 225 of file vtkGridAxes3DActor.h.
◆ SetZNotation()
void vtkGridAxes3DActor::SetZNotation ( int  notation)
inline
Definition at line 226 of file vtkGridAxes3DActor.h.
◆ GetNotation()
int vtkGridAxes3DActor::GetNotation ( int  axis)
◆ SetPrecision()
void vtkGridAxes3DActor::SetPrecision ( int  axis,
int  val
◆ SetXPrecision()
void vtkGridAxes3DActor::SetXPrecision ( int  val)
inline
Definition at line 235 of file vtkGridAxes3DActor.h.
◆ SetYPrecision()
void vtkGridAxes3DActor::SetYPrecision ( int  val)
inline
Definition at line 236 of file vtkGridAxes3DActor.h.
◆ SetZPrecision()
void vtkGridAxes3DActor::SetZPrecision ( int  val)
inline
Definition at line 237 of file vtkGridAxes3DActor.h.
◆ GetPrecision()
int vtkGridAxes3DActor::GetPrecision ( int  axis)
◆ SetTickLabelFunction()
void vtkGridAxes3DActor::SetTickLabelFunction ( int  axis,
If nothing is set, then the default is to use whatever was generated by vtkAxis.
The default it to use whatever was generated by vtkAxis.
◆ GetTickLabelFunction()
std::function<double(double)> vtkGridAxes3DActor::GetTickLabelFunction ( int  axis)
◆ GetBounds()
double* vtkGridAxes3DActor::GetBounds ( )
Implements vtkProp3D.
◆ GetRenderedBounds()
virtual void vtkGridAxes3DActor::GetRenderedBounds ( double  bounds[6])
◆ SetForceOpaque()
virtual void vtkGridAxes3DActor::SetForceOpaque ( bool  )
◆ GetForceOpaque()
virtual bool vtkGridAxes3DActor::GetForceOpaque ( )
◆ ForceOpaqueOn()
virtual void vtkGridAxes3DActor::ForceOpaqueOn ( )
◆ ForceOpaqueOff()
virtual void vtkGridAxes3DActor::ForceOpaqueOff ( )
◆ RenderOpaqueGeometry()
int vtkGridAxes3DActor::RenderOpaqueGeometry ( vtkViewport *  )
◆ RenderTranslucentPolygonalGeometry()
int vtkGridAxes3DActor::RenderTranslucentPolygonalGeometry ( vtkViewport *  viewport)
◆ RenderOverlay()
int vtkGridAxes3DActor::RenderOverlay ( vtkViewport *  viewport)
◆ HasTranslucentPolygonalGeometry()
int vtkGridAxes3DActor::HasTranslucentPolygonalGeometry ( )
◆ ReleaseGraphicsResources()
void vtkGridAxes3DActor::ReleaseGraphicsResources ( vtkWindow *  )
◆ Update()
virtual void vtkGridAxes3DActor::Update ( vtkViewport *  viewport)
protectedvirtual
◆ GridBounds
double vtkGridAxes3DActor::GridBounds[6]
Definition at line 291 of file vtkGridAxes3DActor.h.
◆ FaceMask
unsigned int vtkGridAxes3DActor::FaceMask
Definition at line 292 of file vtkGridAxes3DActor.h.
◆ LabelMask
unsigned int vtkGridAxes3DActor::LabelMask
Definition at line 293 of file vtkGridAxes3DActor.h.
◆ LabelUniqueEdgesOnly
bool vtkGridAxes3DActor::LabelUniqueEdgesOnly
Definition at line 294 of file vtkGridAxes3DActor.h.
◆ UseCustomLabels
vtkTuple<bool, 3> vtkGridAxes3DActor::UseCustomLabels
Definition at line 295 of file vtkGridAxes3DActor.h.
◆ CustomLabels
vtkTuple<vtkNew<vtkDoubleArray>, 3> vtkGridAxes3DActor::CustomLabels
Definition at line 296 of file vtkGridAxes3DActor.h.
◆ CustomLabelsMTime
vtkMTimeType vtkGridAxes3DActor::CustomLabelsMTime
Definition at line 297 of file vtkGridAxes3DActor.h.
◆ GridAxes2DActors
vtkTuple<vtkNew<vtkGridAxes2DActor>, 6> vtkGridAxes3DActor::GridAxes2DActors
Definition at line 299 of file vtkGridAxes3DActor.h.
◆ ForceOpaque
bool vtkGridAxes3DActor::ForceOpaque
Definition at line 301 of file vtkGridAxes3DActor.h.
