vtkPVGridAxes3DActor Class Reference
ParaView extensions for vtkGridAxes3DActor. More...
#include <vtkPVGridAxes3DActor.h>
Inheritance diagram for vtkPVGridAxes3DActor:
Collaboration diagram for vtkPVGridAxes3DActor:
typedef vtkGridAxes3DActor Superclass
- Public Types inherited from vtkGridAxes3DActor
enum  FaceMasks {
  MIN_YZ = 0x01, MIN_ZX = 0x02, MIN_XY = 0x04, MAX_YZ = 0x08,
  MAX_ZX = 0x010, MAX_XY = 0x020
 Values for FaceMask. More...
enum  LabelMasks {
  MIN_X = vtkGridAxesHelper::MIN_X, MIN_Y = vtkGridAxesHelper::MIN_Y, MIN_Z = vtkGridAxesHelper::MIN_Z, MAX_X = vtkGridAxesHelper::MAX_X,
  MAX_Y = vtkGridAxesHelper::MAX_Y, MAX_Z = vtkGridAxesHelper::MAX_Z
typedef vtkProp3D Superclass
- Public Types inherited from vtkProp3D
typedef vtkProp Superclass
void ShallowCopy (vtkProp *prop) override
 Shallow copy from another vtkPVGridAxes3DActor. More...
virtual void SetDataPosition (double, double, double)
virtual void SetDataPosition (double [3])
virtual double * GetDataPosition ()
virtual void GetDataPosition (double &, double &, double &)
virtual void GetDataPosition (double [3])
virtual void SetUseModelTransform (bool)
virtual bool GetUseModelTransform ()
virtual void UseModelTransformOn ()
virtual void UseModelTransformOff ()
virtual void SetModelBounds (double, double, double, double, double, double)
virtual void SetModelBounds (double [6])
virtual double * GetModelBounds ()
virtual void GetModelBounds (double &, double &, double &, double &, double &, double &)
virtual void GetModelBounds (double [6])
void SetModelTransformMatrix (double *matrix)
double * GetBounds () override
 Overridden to ensure that the transform information is passed on the superclass. More...
virtual void SetDataScale (double, double, double)
 Specify transformation used by the data. More...
virtual void SetDataScale (double [3])
virtual double * GetDataScale ()
virtual void GetDataScale (double &, double &, double &)
virtual void GetDataScale (double [3])
virtual void SetDataBoundsScaleFactor (double)
 Specify the scale factor used to proportionally scale each axis. More...
virtual double GetDataBoundsScaleFactor ()
virtual void SetTransformedBounds (double, double, double, double, double, double)
 Another way for specifying grid bounds except here the bounds are considered to be pre-transformed. More...
virtual void SetTransformedBounds (double [6])
virtual double * GetTransformedBounds ()
virtual void GetTransformedBounds (double &, double &, double &, double &, double &, double &)
virtual void GetTransformedBounds (double [6])
virtual void SetUseCustomTransformedBounds (bool)
 If set to true, CustomTransformedBounds are used instead of TransformedBounds. More...
virtual bool GetUseCustomTransformedBounds ()
virtual void SetCustomTransformedBounds (double, double, double, double, double, double)
 Same as TransformedBounds, except used only when UseCustomTransformedBounds is set. More...
virtual void SetCustomTransformedBounds (double [6])
virtual double * GetCustomTransformedBounds ()
virtual void GetCustomTransformedBounds (double &, double &, double &, double &, double &, double &)
virtual void GetCustomTransformedBounds (double [6])
- Public Member Functions inherited from vtkGridAxes3DActor
void GetActors (vtkPropCollection *) override
 For some exporters and other other operations we must be able to collect all the actors or volumes. More...
void UpdateGeometry (vtkViewport *vp)
 Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
void SetUseCustomLabels (int axis, bool val)
 Set whether the specified axis should use custom labels instead of automatically determined ones. More...
void SetXUseCustomLabels (bool val)
void SetYUseCustomLabels (bool val)
void SetZUseCustomLabels (bool val)
void SetNumberOfLabels (int axis, vtkIdType val)
void SetNumberOfXLabels (vtkIdType val)
void SetNumberOfYLabels (vtkIdType val)
void SetNumberOfZLabels (vtkIdType val)
void SetLabel (int axis, vtkIdType index, double value)
void SetXLabel (vtkIdType index, double value)
void SetYLabel (vtkIdType index, double value)
void SetZLabel (vtkIdType index, double value)
virtual void GetRenderedBounds (double bounds[6])
 Get an bounding box that is expected to contain all rendered elements, since GetBounds() returns the bounding box the grid axes describes. More...
int RenderOpaqueGeometry (vtkViewport *) override
int RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override
int RenderOverlay (vtkViewport *viewport) override
int HasTranslucentPolygonalGeometry () override
void ReleaseGraphicsResources (vtkWindow *) override
virtual void SetGridBounds (double, double, double, double, double, double)
 Set the bounding box defining the grid space. More...
virtual void SetGridBounds (double [6])
virtual double * GetGridBounds ()
virtual void GetGridBounds (double &, double &, double &, double &, double &, double &)
virtual void GetGridBounds (double [6])
virtual void SetFaceMask (unsigned int mask)
 Set the mask to select faces. More...
virtual unsigned int GetFaceMask ()
virtual void SetLabelMask (unsigned int mask)
 Set the axis to label. More...
unsigned int GetLabelMask ()
virtual void SetLabelUniqueEdgesOnly (bool)
 Set to true to only label edges shared with 1 face. More...
virtual bool GetLabelUniqueEdgesOnly ()
void SetGenerateGrid (bool val)
 Turn off to not generate polydata for the plane's grid. More...
bool GetGenerateGrid ()
virtual void GenerateGridOn ()
virtual void GenerateGridOff ()
void SetGenerateEdges (bool val)
 Turn off to not generate the polydata for the plane's edges. More...
bool GetGenerateEdges ()
virtual void GenerateEdgesOn ()
virtual void GenerateEdgesOff ()
void SetGenerateTicks (bool val)
 Turn off to not generate the markers for the tick positions. More...
bool GetGenerateTicks ()
virtual void GenerateTicksOn ()
virtual void GenerateTicksOff ()
void SetProperty (vtkProperty *)
 Get/Set the property used to control the appearance of the rendered grid. More...
vtkProperty * GetProperty ()
void SetTitleTextProperty (int axis, vtkTextProperty *)
 Get/Set the vtkTextProperty for the title for each the axes. More...
void SetXTitleTextProperty (vtkTextProperty *prop)
void SetYTitleTextProperty (vtkTextProperty *prop)
void SetZTitleTextProperty (vtkTextProperty *prop)
vtkTextProperty * GetTitleTextProperty (int axis)
void SetTitle (int axis, const std::string &title)
 Get/Set the text to use for titles for the axis. More...
void SetXTitle (const std::string &title)
void SetYTitle (const std::string &title)
void SetZTitle (const std::string &title)
const std::string & GetTitle (int axis)
void SetLabelTextProperty (int axis, vtkTextProperty *)
 Get/Set the vtkTextProperty that governs how the axis labels are displayed. More...
void SetXLabelTextProperty (vtkTextProperty *prop)
void SetYLabelTextProperty (vtkTextProperty *prop)
void SetZLabelTextProperty (vtkTextProperty *prop)
vtkTextProperty * GetLabelTextProperty (int axis)
void SetNotation (int axis, int notation)
 Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More...
void SetXNotation (int notation)
void SetYNotation (int notation)
void SetZNotation (int notation)
int GetNotation (int axis)
void SetPrecision (int axis, int val)
 Get/set the numerical precision to use, default is 2. More...
void SetXPrecision (int val)
void SetYPrecision (int val)
void SetZPrecision (int val)
int GetPrecision (int axis)
void SetTickLabelFunction (int axis, std::function< double(double)> func)
 Get/Set the function that will be applied to the tick label of each axis. More...
std::function< double(double)> GetTickLabelFunction (int axis)
virtual void SetForceOpaque (bool)
 If true, the actor will always be rendered during the opaque pass. More...
virtual bool GetForceOpaque ()
virtual void ForceOpaqueOn ()
virtual void ForceOpaqueOff ()
- Public Member Functions inherited from vtkProp3D
vtkProp3D * NewInstance () const
virtual void SetPosition (double pos[3])
virtual double * GetPosition ()
virtual void GetPosition (double data[3])
void AddPosition (double deltaPosition[3])
void AddPosition (double deltaX, double deltaY, double deltaZ)
double * GetCenter ()
double * GetXRange ()
double * GetYRange ()
double * GetZRange ()
double GetLength ()
void RotateX (double)
void RotateY (double)
void RotateZ (double)
void RotateWXYZ (double w, double x, double y, double z)
void SetOrientation (double x, double y, double z)
void SetOrientation (double orientation[3])
double * GetOrientationWXYZ ()
void AddOrientation (double x, double y, double z)
void AddOrientation (double orentation[3])
void PokeMatrix (vtkMatrix4x4 *matrix)
void InitPathTraversal ()
vtkMTimeType GetMTime ()
vtkMTimeType GetUserTransformMatrixMTime ()
virtual void ComputeMatrix ()
virtual void SetPosition (double x, double y, double z)
virtual void SetOrigin (double x, double y, double z)
virtual void SetOrigin (const double pos[3])
virtual double * GetOrigin ()
virtual void GetOrigin (double data[3])
virtual void SetScale (double x, double y, double z)
virtual void SetScale (double scale[3])
virtual double * GetScale ()
virtual void GetScale (double data[3])
void SetScale (double s)
void SetUserTransform (vtkLinearTransform *transform)
virtual vtkLinearTransform * GetUserTransform ()
void SetUserMatrix (vtkMatrix4x4 *matrix)
vtkMatrix4x4 * GetUserMatrix ()
virtual void GetMatrix (vtkMatrix4x4 *m)
virtual void GetMatrix (double m[16])
void GetBounds (double bounds[6])
double * GetOrientation ()
void GetOrientation (double orentation[3])
vtkMatrix4x4 * GetMatrix ()
virtual int GetIsIdentity ()
vtkProp * NewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors2D (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual vtkMTimeType GetRedrawMTime ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual vtkAssemblyPath * GetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkInformation * GetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual bool GetSupportsSelection ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObject * GetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkPVGridAxes3DActor * New ()
static vtkPVGridAxes3DActor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkGridAxes3DActor
static vtkGridAxes3DActor * New ()
static vtkGridAxes3DActor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkProp3D
static vtkProp3D * SafeDownCast (vtkObjectBase *o)
static vtkProp * SafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKey * GeneralTextureUnit ()
static vtkInformationDoubleVectorKey * GeneralTextureTransform ()
 vtkPVGridAxes3DActor ()
 ~vtkPVGridAxes3DActor () override
void Update (vtkViewport *viewport) override
void UpdateGridBounds ()
void UpdateGridBoundsUsingDataBounds ()
void UpdateGridBoundsUsingModelTransform ()
- Protected Member Functions inherited from vtkGridAxes3DActor
 vtkGridAxes3DActor ()
 ~vtkGridAxes3DActor () override
- Protected Member Functions inherited from vtkProp3D
 vtkProp3D ()
 ~vtkProp3D ()
 vtkProp ()
 ~vtkProp ()
double DataScale [3]
double DataPosition [3]
double DataBoundsScaleFactor
double TransformedBounds [6]
bool UseModelTransform
double ModelBounds [6]
vtkNew< vtkMatrix4x4 > ModelTransformMatrix
bool UseCustomTransformedBounds
double CustomTransformedBounds [6]
- Protected Attributes inherited from vtkGridAxes3DActor
double GridBounds [6]
unsigned int FaceMask
unsigned int LabelMask
bool LabelUniqueEdgesOnly
vtkTuple< bool, 3 > UseCustomLabels
vtkTuple< vtkNew< vtkDoubleArray >, 3 > CustomLabels
vtkMTimeType CustomLabelsMTime
vtkTuple< vtkNew< vtkGridAxes2DActor >, 6 > GridAxes2DActors
bool ForceOpaque
- Protected Attributes inherited from vtkProp3D
vtkLinearTransform * UserTransform
vtkMatrix4x4 * UserMatrix
vtkMatrix4x4 * Matrix
vtkTimeStamp MatrixMTime
double Origin [3]
double Position [3]
double Orientation [3]
double Scale [3]
double Center [3]
vtkTransform * Transform
double Bounds [6]
vtkProp3D * CachedProp3D
int IsIdentity
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPaths * Paths
vtkInformation * PropertyKeys
vtkPVGridAxes3DActor adds support for ParaView-specific use-cases to vtkGridAxes3DActor. The special use-cases are:
Definition at line 34 of file vtkPVGridAxes3DActor.h.
Definition at line 38 of file vtkPVGridAxes3DActor.h.
◆ vtkPVGridAxes3DActor()
vtkPVGridAxes3DActor::vtkPVGridAxes3DActor ( )
◆ ~vtkPVGridAxes3DActor()
vtkPVGridAxes3DActor::~vtkPVGridAxes3DActor ( )
static vtkPVGridAxes3DActor* vtkPVGridAxes3DActor::New ( )
virtual const char* vtkPVGridAxes3DActor::GetClassName ( )
Reimplemented from vtkGridAxes3DActor.
static int vtkPVGridAxes3DActor::IsTypeOf ( const char *  type)
virtual int vtkPVGridAxes3DActor::IsA ( const char *  type)
static vtkPVGridAxes3DActor* vtkPVGridAxes3DActor::SafeDownCast ( vtkObject *  o)
void vtkPVGridAxes3DActor::PrintSelf ( ostream &  os,
◆ ShallowCopy()
void vtkPVGridAxes3DActor::ShallowCopy ( vtkProp *  prop)
◆ SetDataScale() [1/2]
virtual void vtkPVGridAxes3DActor::SetDataScale ( double  ,
double  ,
double
◆ SetDataScale() [2/2]
virtual void vtkPVGridAxes3DActor::SetDataScale ( double  [3])
◆ GetDataScale() [1/3]
virtual double* vtkPVGridAxes3DActor::GetDataScale ( )
◆ GetDataScale() [2/3]
virtual void vtkPVGridAxes3DActor::GetDataScale ( double &  ,
double &  ,
double &
◆ GetDataScale() [3/3]
virtual void vtkPVGridAxes3DActor::GetDataScale ( double  [3])
◆ SetDataPosition() [1/2]
virtual void vtkPVGridAxes3DActor::SetDataPosition ( double  ,
double  ,
double
◆ SetDataPosition() [2/2]
virtual void vtkPVGridAxes3DActor::SetDataPosition ( double  [3])
◆ GetDataPosition() [1/3]
virtual double* vtkPVGridAxes3DActor::GetDataPosition ( )
◆ GetDataPosition() [2/3]
virtual void vtkPVGridAxes3DActor::GetDataPosition ( double &  ,
double &  ,
double &
◆ GetDataPosition() [3/3]
virtual void vtkPVGridAxes3DActor::GetDataPosition ( double  [3])
◆ SetDataBoundsScaleFactor()
virtual void vtkPVGridAxes3DActor::SetDataBoundsScaleFactor ( double  )
1 means no change.
◆ GetDataBoundsScaleFactor()
virtual double vtkPVGridAxes3DActor::GetDataBoundsScaleFactor ( )
1 means no change.
◆ SetTransformedBounds() [1/2]
virtual void vtkPVGridAxes3DActor::SetTransformedBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
Using the DataPosition, DataScale, and DataBoundsScaleFactor, the provided bounds will un-transformed before calling this->SetGridBounds() and then position and scale are instead passed on the vtkActor. This results in display scaling rather than data scaling.
◆ SetTransformedBounds() [2/2]
virtual void vtkPVGridAxes3DActor::SetTransformedBounds ( double  [6])
◆ GetTransformedBounds() [1/3]
virtual double* vtkPVGridAxes3DActor::GetTransformedBounds ( )
◆ GetTransformedBounds() [2/3]
virtual void vtkPVGridAxes3DActor::GetTransformedBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetTransformedBounds() [3/3]
virtual void vtkPVGridAxes3DActor::GetTransformedBounds ( double  [6])
◆ SetUseCustomTransformedBounds()
virtual void vtkPVGridAxes3DActor::SetUseCustomTransformedBounds ( bool  )
Default is false.
◆ GetUseCustomTransformedBounds()
virtual bool vtkPVGridAxes3DActor::GetUseCustomTransformedBounds ( )
Default is false.
◆ SetCustomTransformedBounds() [1/2]
virtual void vtkPVGridAxes3DActor::SetCustomTransformedBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
◆ SetCustomTransformedBounds() [2/2]
virtual void vtkPVGridAxes3DActor::SetCustomTransformedBounds ( double  [6])
◆ GetCustomTransformedBounds() [1/3]
virtual double* vtkPVGridAxes3DActor::GetCustomTransformedBounds ( )
◆ GetCustomTransformedBounds() [2/3]
virtual void vtkPVGridAxes3DActor::GetCustomTransformedBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetCustomTransformedBounds() [3/3]
virtual void vtkPVGridAxes3DActor::GetCustomTransformedBounds ( double  [6])
◆ SetUseModelTransform()
virtual void vtkPVGridAxes3DActor::SetUseModelTransform ( bool  )
◆ GetUseModelTransform()
virtual bool vtkPVGridAxes3DActor::GetUseModelTransform ( )
◆ UseModelTransformOn()
virtual void vtkPVGridAxes3DActor::UseModelTransformOn ( )
◆ UseModelTransformOff()
virtual void vtkPVGridAxes3DActor::UseModelTransformOff ( )
◆ SetModelBounds() [1/2]
virtual void vtkPVGridAxes3DActor::SetModelBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
◆ SetModelBounds() [2/2]
virtual void vtkPVGridAxes3DActor::SetModelBounds ( double  [6])
◆ GetModelBounds() [1/3]
virtual double* vtkPVGridAxes3DActor::GetModelBounds ( )
◆ GetModelBounds() [2/3]
virtual void vtkPVGridAxes3DActor::GetModelBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetModelBounds() [3/3]
virtual void vtkPVGridAxes3DActor::GetModelBounds ( double  [6])
◆ SetModelTransformMatrix()
void vtkPVGridAxes3DActor::SetModelTransformMatrix ( double *  matrix)
◆ GetBounds()
double* vtkPVGridAxes3DActor::GetBounds ( )
◆ Update()
void vtkPVGridAxes3DActor::Update ( vtkViewport *  viewport)
overrideprotectedvirtual
◆ UpdateGridBounds()
void vtkPVGridAxes3DActor::UpdateGridBounds ( )
◆ UpdateGridBoundsUsingDataBounds()
void vtkPVGridAxes3DActor::UpdateGridBoundsUsingDataBounds ( )
◆ UpdateGridBoundsUsingModelTransform()
void vtkPVGridAxes3DActor::UpdateGridBoundsUsingModelTransform ( )
◆ DataScale
double vtkPVGridAxes3DActor::DataScale[3]
Definition at line 119 of file vtkPVGridAxes3DActor.h.
◆ DataPosition
double vtkPVGridAxes3DActor::DataPosition[3]
Definition at line 120 of file vtkPVGridAxes3DActor.h.
◆ DataBoundsScaleFactor
double vtkPVGridAxes3DActor::DataBoundsScaleFactor
Definition at line 121 of file vtkPVGridAxes3DActor.h.
◆ TransformedBounds
double vtkPVGridAxes3DActor::TransformedBounds[6]
Definition at line 122 of file vtkPVGridAxes3DActor.h.
◆ UseModelTransform
bool vtkPVGridAxes3DActor::UseModelTransform
Definition at line 124 of file vtkPVGridAxes3DActor.h.
◆ ModelBounds
double vtkPVGridAxes3DActor::ModelBounds[6]
Definition at line 125 of file vtkPVGridAxes3DActor.h.
◆ ModelTransformMatrix
vtkNew<vtkMatrix4x4> vtkPVGridAxes3DActor::ModelTransformMatrix
Definition at line 126 of file vtkPVGridAxes3DActor.h.
◆ UseCustomTransformedBounds
bool vtkPVGridAxes3DActor::UseCustomTransformedBounds
Definition at line 128 of file vtkPVGridAxes3DActor.h.
◆ CustomTransformedBounds
double vtkPVGridAxes3DActor::CustomTransformedBounds[6]
Definition at line 129 of file vtkPVGridAxes3DActor.h.
