vtkGridAxes2DActor Class Reference
actor for an axes plane in a 3D view. More...
#include <vtkGridAxes2DActor.h>
Inheritance diagram for vtkGridAxes2DActor:
Collaboration diagram for vtkGridAxes2DActor:
enum  Faces {
  MIN_YZ = vtkGridAxesHelper::MIN_YZ, MIN_ZX = vtkGridAxesHelper::MIN_ZX, MIN_XY = vtkGridAxesHelper::MIN_XY, MAX_YZ = vtkGridAxesHelper::MAX_YZ,
  MAX_ZX = vtkGridAxesHelper::MAX_ZX, MAX_XY = vtkGridAxesHelper::MAX_XY
enum  LabelMasks {
  MIN_X = vtkGridAxesHelper::MIN_X, MIN_Y = vtkGridAxesHelper::MIN_Y, MIN_Z = vtkGridAxesHelper::MIN_Z, MAX_X = vtkGridAxesHelper::MAX_X,
  MAX_Y = vtkGridAxesHelper::MAX_Y, MAX_Z = vtkGridAxesHelper::MAX_Z
 Valid values for LabelMask. More...
typedef vtkProp3D Superclass
- Public Types inherited from vtkProp3D
typedef vtkProp Superclass
void GetActors (vtkPropCollection *) override
 For some exporters and other other operations we must be able to collect all the actors or volumes. More...
void UpdateGeometry (vtkViewport *viewport, bool doRegularUpdate)
 Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
void SetCustomTickPositions (int axis, vtkDoubleArray *positions)
 Set custom tick positions for each of the axes. More...
int RenderOpaqueGeometry (vtkViewport *) override
int RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override
int RenderOverlay (vtkViewport *viewport) override
int HasTranslucentPolygonalGeometry () override
void ReleaseGraphicsResources (vtkWindow *) override
vtkMTimeType GetMTime () override
 Overridden to include the mtime for the text properties. More...
virtual void SetGridBounds (double, double, double, double, double, double)
 Set the bounding box defining the grid space. More...
virtual void SetGridBounds (double [6])
virtual double * GetGridBounds ()
virtual void GetGridBounds (double &, double &, double &, double &, double &, double &)
virtual void GetGridBounds (double [6])
virtual void SetFace (int)
 Indicate which face of the specified bounds is this class operating with. More...
virtual int GetFace ()
virtual void SetLabelMask (unsigned int)
 Set the axes to label. More...
virtual unsigned int GetLabelMask ()
void SetProperty (vtkProperty *)
 Get/Set the property used to control the appearance of the rendered grid, including edges. More...
vtkProperty * GetProperty ()
void SetTitleTextProperty (int axis, vtkTextProperty *)
 Get/Set the title text properties for each of the coordinate axes. More...
vtkTextProperty * GetTitleTextProperty (int axis)
void SetLabelTextProperty (int axis, vtkTextProperty *)
 Get/Set the label text properties for each of the coordinate axes. More...
vtkTextProperty * GetLabelTextProperty (int axis)
void SetTitle (int axis, const std::string &title)
 Set titles for each of the axes. More...
const std::string & GetTitle (int axis)
void SetNotation (int axis, int notation)
 Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More...
int GetNotation (int axis)
void SetPrecision (int axis, int val)
 Get/set the numerical precision to use, default is 2. More...
int GetPrecision (int axis)
void SetTickLabelFunction (int axis, std::function< double(double)> func)
 Get/Set the function that will be applied to the tick label of each axis. More...
std::function< double(double)> GetTickLabelFunction (int axis)
void SetGenerateGrid (bool val)
 Turn off to not generate polydata for the plane's grid. More...
bool GetGenerateGrid ()
virtual void GenerateGridOn ()
virtual void GenerateGridOff ()
void SetGenerateEdges (bool val)
 Turn off to not generate the polydata for the plane's edges. More...
bool GetGenerateEdges ()
virtual void GenerateEdgesOn ()
virtual void GenerateEdgesOff ()
void SetGenerateTicks (bool val)
 Turn off to not generate the markers for the tick positions. More...
bool GetGenerateTicks ()
virtual void GenerateTicksOn ()
virtual void GenerateTicksOff ()
double * GetBounds () override
 Returns the prop bounds. More...
virtual void SetForceOpaque (bool)
 If true, the actor will always be rendered during the opaque pass. More...
virtual bool GetForceOpaque ()
virtual void ForceOpaqueOn ()
virtual void ForceOpaqueOff ()
- Public Member Functions inherited from vtkProp3D
vtkProp3D * NewInstance () const
void ShallowCopy (vtkProp *prop)
virtual void SetPosition (double pos[3])
virtual double * GetPosition ()
virtual void GetPosition (double data[3])
void AddPosition (double deltaPosition[3])
void AddPosition (double deltaX, double deltaY, double deltaZ)
double * GetCenter ()
double * GetXRange ()
double * GetYRange ()
double * GetZRange ()
double GetLength ()
void RotateX (double)
void RotateY (double)
void RotateZ (double)
void RotateWXYZ (double w, double x, double y, double z)
void SetOrientation (double x, double y, double z)
void SetOrientation (double orientation[3])
double * GetOrientationWXYZ ()
void AddOrientation (double x, double y, double z)
void AddOrientation (double orentation[3])
void PokeMatrix (vtkMatrix4x4 *matrix)
void InitPathTraversal ()
vtkMTimeType GetUserTransformMatrixMTime ()
virtual void ComputeMatrix ()
virtual void SetPosition (double x, double y, double z)
virtual void SetOrigin (double x, double y, double z)
virtual void SetOrigin (const double pos[3])
virtual double * GetOrigin ()
virtual void GetOrigin (double data[3])
virtual void SetScale (double x, double y, double z)
virtual void SetScale (double scale[3])
virtual double * GetScale ()
virtual void GetScale (double data[3])
void SetScale (double s)
void SetUserTransform (vtkLinearTransform *transform)
virtual vtkLinearTransform * GetUserTransform ()
void SetUserMatrix (vtkMatrix4x4 *matrix)
vtkMatrix4x4 * GetUserMatrix ()
virtual void GetMatrix (vtkMatrix4x4 *m)
virtual void GetMatrix (double m[16])
void GetBounds (double bounds[6])
double * GetOrientation ()
void GetOrientation (double orentation[3])
vtkMatrix4x4 * GetMatrix ()
virtual int GetIsIdentity ()
vtkProp * NewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors2D (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual vtkMTimeType GetRedrawMTime ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual vtkAssemblyPath * GetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkInformation * GetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual bool GetSupportsSelection ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObject * GetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkGridAxes2DActor * New ()
static vtkGridAxes2DActor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkProp3D
static vtkProp3D * SafeDownCast (vtkObjectBase *o)
static vtkProp * SafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKey * GeneralTextureUnit ()
static vtkInformationDoubleVectorKey * GeneralTextureTransform ()
 vtkGridAxes2DActor ()
 ~vtkGridAxes2DActor () override
bool Update (vtkViewport *viewport)
void UpdateTextProperties (vtkViewport *viewport)
void UpdateLabelPositions (vtkViewport *viewport)
void UpdateTextActors (vtkViewport *viewport)
- Protected Member Functions inherited from vtkProp3D
 vtkProp3D ()
 ~vtkProp3D ()
 vtkProp ()
 ~vtkProp ()
double GridBounds [6]
int Face
unsigned int LabelMask
vtkTuple< vtkSmartPointer< vtkTextProperty >, 3 > TitleTextProperty
vtkTuple< vtkSmartPointer< vtkTextProperty >, 3 > LabelTextProperty
vtkTuple< std::string, 3 > Titles
vtkNew< vtkGridAxesHelper > Helper
vtkSmartPointer< vtkGridAxesPlane2DActor > PlaneActor
vtkNew< vtkAxis > AxisHelpers [3]
vtkNew< vtkContextScene > AxisHelperScene
vtkTimeStamp UpdateLabelTextPropertiesMTime
bool ForceOpaque
std::function< double(double)> TickLabelFunction [3] = { nullptr, nullptr, nullptr }
- Protected Attributes inherited from vtkProp3D
vtkLinearTransform * UserTransform
vtkMatrix4x4 * UserMatrix
vtkMatrix4x4 * Matrix
vtkTimeStamp MatrixMTime
double Origin [3]
double Position [3]
double Orientation [3]
double Scale [3]
double Center [3]
vtkTransform * Transform
double Bounds [6]
vtkProp3D * CachedProp3D
int IsIdentity
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPaths * Paths
vtkInformation * PropertyKeys
Friends
class vtkGridAxes3DActor
class vtkLabels
vtkGridAxes2DActor is a vtkProp3D that renders a single axes plane (or face). Despite the name, it renders a prop in 3D with ability to render lines for the axes bounds along with labels on them.
To use this, one sets the GridBounds and then the Face which identifies the face of the cube defined by the GridBounds along which this prop will render the grid. Parameters available allow additional controls including labeling, grid rendering, edge rendering etc.
See also
vtkGridAxes3DActor
Definition at line 39 of file vtkGridAxes2DActor.h.
Definition at line 43 of file vtkGridAxes2DActor.h.
◆ Faces
Enumerator
MIN_YZ
MIN_ZX
MIN_XY
MAX_YZ
MAX_ZX
MAX_XY
Definition at line 57 of file vtkGridAxes2DActor.h.
◆ LabelMasks
Enumerator
MIN_X
MIN_Y
MIN_Z
MAX_X
MAX_Y
MAX_Z
Definition at line 78 of file vtkGridAxes2DActor.h.
◆ vtkGridAxes2DActor()
vtkGridAxes2DActor::vtkGridAxes2DActor ( )
◆ ~vtkGridAxes2DActor()
vtkGridAxes2DActor::~vtkGridAxes2DActor ( )
static vtkGridAxes2DActor* vtkGridAxes2DActor::New ( )
virtual const char* vtkGridAxes2DActor::GetClassName ( )
static int vtkGridAxes2DActor::IsTypeOf ( const char *  type)
virtual int vtkGridAxes2DActor::IsA ( const char *  type)
Reimplemented from vtkProp3D.
static vtkGridAxes2DActor* vtkGridAxes2DActor::SafeDownCast ( vtkObject *  o)
void vtkGridAxes2DActor::PrintSelf ( ostream &  os,
◆ SetGridBounds() [1/2]
virtual void vtkGridAxes2DActor::SetGridBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
This, together with the Face identify which planar surface this class is interested in. This class is designed to work with a single planar surface.
◆ SetGridBounds() [2/2]
virtual void vtkGridAxes2DActor::SetGridBounds ( double  [6])
◆ GetGridBounds() [1/3]
virtual double* vtkGridAxes2DActor::GetGridBounds ( )
◆ GetGridBounds() [2/3]
virtual void vtkGridAxes2DActor::GetGridBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetGridBounds() [3/3]
virtual void vtkGridAxes2DActor::GetGridBounds ( double  [6])
◆ SetFace()
virtual void vtkGridAxes2DActor::SetFace ( int  )
◆ GetFace()
virtual int vtkGridAxes2DActor::GetFace ( )
◆ SetLabelMask()
virtual void vtkGridAxes2DActor::SetLabelMask ( unsigned  int)
The mask can be generated by or-ing values in vtkGridAxes2DActor::LabelMasks to label multiple axes. Any request to label an axes not present on the selected Face is ignored e.g. if Face is MIN_YZ, then LabelMask set to MIN_X will have no effect.
◆ GetLabelMask()
virtual unsigned int vtkGridAxes2DActor::GetLabelMask ( )
◆ GetActors()
void vtkGridAxes2DActor::GetActors ( vtkPropCollection *  )
These methods are used in that process. In case the viewport is not a consumer of this prop: call UpdateGeometry() first for updated viewport-specific billboard geometry.
Reimplemented from vtkProp.
◆ UpdateGeometry()
void vtkGridAxes2DActor::UpdateGeometry ( vtkViewport *  viewport,
◆ SetProperty()
void vtkGridAxes2DActor::SetProperty ( vtkProperty *  )
◆ GetProperty()
vtkProperty* vtkGridAxes2DActor::GetProperty ( )
◆ SetTitleTextProperty()
void vtkGridAxes2DActor::SetTitleTextProperty ( int  axis,
vtkTextProperty *
Which properties will be used depends on the selected Face being rendered.
◆ GetTitleTextProperty()
vtkTextProperty* vtkGridAxes2DActor::GetTitleTextProperty ( int  axis)
◆ SetLabelTextProperty()
void vtkGridAxes2DActor::SetLabelTextProperty ( int  axis,
vtkTextProperty *
◆ GetLabelTextProperty()
vtkTextProperty* vtkGridAxes2DActor::GetLabelTextProperty ( int  axis)
◆ SetTitle()
void vtkGridAxes2DActor::SetTitle ( int  axis,
const std::string &  title
◆ GetTitle()
const std::string& vtkGridAxes2DActor::GetTitle ( int  axis)
◆ SetNotation()
void vtkGridAxes2DActor::SetNotation ( int  axis,
int  notation
Accepted values are vtkAxis::AUTO, vtkAxis::FIXED, vtkAxis::CUSTOM.
◆ GetNotation()
int vtkGridAxes2DActor::GetNotation ( int  axis)
◆ SetPrecision()
void vtkGridAxes2DActor::SetPrecision ( int  axis,
int  val
◆ GetPrecision()
int vtkGridAxes2DActor::GetPrecision ( int  axis)
◆ SetTickLabelFunction()
void vtkGridAxes2DActor::SetTickLabelFunction ( int  axis,
If nothing is set, then the default is to use whatever was generated by vtkAxis.
The default it to use whatever was generated by vtkAxis.
◆ GetTickLabelFunction()
std::function<double(double)> vtkGridAxes2DActor::GetTickLabelFunction ( int  axis)
◆ SetCustomTickPositions()
void vtkGridAxes2DActor::SetCustomTickPositions ( int  axis,
vtkDoubleArray *  positions
The positions are deep copied. Set to nullptr to not use custom tick positions for the axis.
◆ SetGenerateGrid()
void vtkGridAxes2DActor::SetGenerateGrid ( bool  val)
inline
Definition at line 193 of file vtkGridAxes2DActor.h.
◆ GetGenerateGrid()
bool vtkGridAxes2DActor::GetGenerateGrid ( )
inline
Definition at line 194 of file vtkGridAxes2DActor.h.
◆ GenerateGridOn()
virtual void vtkGridAxes2DActor::GenerateGridOn ( )
◆ GenerateGridOff()
virtual void vtkGridAxes2DActor::GenerateGridOff ( )
◆ SetGenerateEdges()
void vtkGridAxes2DActor::SetGenerateEdges ( bool  val)
inline
Definition at line 202 of file vtkGridAxes2DActor.h.
◆ GetGenerateEdges()
bool vtkGridAxes2DActor::GetGenerateEdges ( )
inline
Definition at line 203 of file vtkGridAxes2DActor.h.
◆ GenerateEdgesOn()
virtual void vtkGridAxes2DActor::GenerateEdgesOn ( )
◆ GenerateEdgesOff()
virtual void vtkGridAxes2DActor::GenerateEdgesOff ( )
◆ SetGenerateTicks()
void vtkGridAxes2DActor::SetGenerateTicks ( bool  val)
inline
Which edges are rendered is defined by the TickMask.
Definition at line 212 of file vtkGridAxes2DActor.h.
◆ GetGenerateTicks()
bool vtkGridAxes2DActor::GetGenerateTicks ( )
inline
Definition at line 213 of file vtkGridAxes2DActor.h.
◆ GenerateTicksOn()
virtual void vtkGridAxes2DActor::GenerateTicksOn ( )
◆ GenerateTicksOff()
virtual void vtkGridAxes2DActor::GenerateTicksOff ( )
◆ GetBounds()
double* vtkGridAxes2DActor::GetBounds ( void  )
inlineoverridevirtual
Implements vtkProp3D.
Definition at line 225 of file vtkGridAxes2DActor.h.
◆ SetForceOpaque()
virtual void vtkGridAxes2DActor::SetForceOpaque ( bool  )
◆ GetForceOpaque()
virtual bool vtkGridAxes2DActor::GetForceOpaque ( )
◆ ForceOpaqueOn()
virtual void vtkGridAxes2DActor::ForceOpaqueOn ( )
◆ ForceOpaqueOff()
virtual void vtkGridAxes2DActor::ForceOpaqueOff ( )
◆ RenderOpaqueGeometry()
int vtkGridAxes2DActor::RenderOpaqueGeometry ( vtkViewport *  )
◆ RenderTranslucentPolygonalGeometry()
int vtkGridAxes2DActor::RenderTranslucentPolygonalGeometry ( vtkViewport *  viewport)
◆ RenderOverlay()
int vtkGridAxes2DActor::RenderOverlay ( vtkViewport *  viewport)
◆ HasTranslucentPolygonalGeometry()
int vtkGridAxes2DActor::HasTranslucentPolygonalGeometry ( )
◆ ReleaseGraphicsResources()
void vtkGridAxes2DActor::ReleaseGraphicsResources ( vtkWindow *  )
◆ GetMTime()
vtkMTimeType vtkGridAxes2DActor::GetMTime ( )
◆ Update()
bool vtkGridAxes2DActor::Update ( vtkViewport *  viewport)
◆ UpdateTextProperties()
void vtkGridAxes2DActor::UpdateTextProperties ( vtkViewport *  viewport)
◆ UpdateLabelPositions()
void vtkGridAxes2DActor::UpdateLabelPositions ( vtkViewport *  viewport)
◆ UpdateTextActors()
void vtkGridAxes2DActor::UpdateTextActors ( vtkViewport *  viewport)
◆ vtkGridAxes3DActor
friend class vtkGridAxes3DActor
friend
Definition at line 260 of file vtkGridAxes2DActor.h.
◆ vtkLabels
friend class vtkLabels
friend
Definition at line 285 of file vtkGridAxes2DActor.h.
◆ GridBounds
double vtkGridAxes2DActor::GridBounds[6]
Definition at line 262 of file vtkGridAxes2DActor.h.
◆ Face
int vtkGridAxes2DActor::Face
Definition at line 263 of file vtkGridAxes2DActor.h.
◆ LabelMask
unsigned int vtkGridAxes2DActor::LabelMask
Definition at line 264 of file vtkGridAxes2DActor.h.
◆ TitleTextProperty
vtkTuple<vtkSmartPointer<vtkTextProperty>, 3> vtkGridAxes2DActor::TitleTextProperty
Definition at line 266 of file vtkGridAxes2DActor.h.
◆ LabelTextProperty
vtkTuple<vtkSmartPointer<vtkTextProperty>, 3> vtkGridAxes2DActor::LabelTextProperty
Definition at line 267 of file vtkGridAxes2DActor.h.
◆ Titles
vtkTuple<std::string, 3> vtkGridAxes2DActor::Titles
Definition at line 268 of file vtkGridAxes2DActor.h.
◆ Helper
vtkNew<vtkGridAxesHelper> vtkGridAxes2DActor::Helper
Definition at line 270 of file vtkGridAxes2DActor.h.
◆ PlaneActor
vtkSmartPointer<vtkGridAxesPlane2DActor> vtkGridAxes2DActor::PlaneActor
Definition at line 271 of file vtkGridAxes2DActor.h.
◆ AxisHelpers
vtkNew<vtkAxis> vtkGridAxes2DActor::AxisHelpers[3]
Definition at line 272 of file vtkGridAxes2DActor.h.
◆ AxisHelperScene
vtkNew<vtkContextScene> vtkGridAxes2DActor::AxisHelperScene
Definition at line 273 of file vtkGridAxes2DActor.h.
◆ UpdateLabelTextPropertiesMTime
vtkTimeStamp vtkGridAxes2DActor::UpdateLabelTextPropertiesMTime
Definition at line 274 of file vtkGridAxes2DActor.h.
◆ ForceOpaque
bool vtkGridAxes2DActor::ForceOpaque
Definition at line 276 of file vtkGridAxes2DActor.h.
◆ TickLabelFunction
std::function<double(double)> vtkGridAxes2DActor::TickLabelFunction[3] = { nullptr, nullptr, nullptr }
Definition at line 277 of file vtkGridAxes2DActor.h.
