vtkGridAxesHelper Class Reference
is a helper object used by vtkGridAxes2DActor, vtkGridAxes3DActor, and vtkGridAxesPlane2DActor. More...
#include <vtkGridAxesHelper.h>
Inheritance diagram for vtkGridAxesHelper:
Collaboration diagram for vtkGridAxesHelper:
enum  Faces {
  MIN_YZ, MIN_ZX, MIN_XY, MAX_YZ,
  MAX_ZX, MAX_XY
enum  LabelMasks {
  MIN_X = 0x01, MIN_Y = 0x02, MIN_Z = 0x04, MAX_X = 0x08,
  MAX_Y = 0x010, MAX_Z = 0x020
 Valid values for LabelMask. More...
vtkTuple< vtkVector3d, 4 > GetPoints ()
 Get the 4 points in world coordinates that define the grid plane. More...
vtkVector2i GetActiveAxes ()
 Returns which of the 3 coordinate axes for the 2 axes for this plane: 0 for X axis, 1, for Y axis, and 3 for Z axis. More...
vtkTuple< bool, 4 > GetLabelVisibilities ()
 Returns the visibility for labels for each of the 4 axis defined by the face points based on the LabelMask. More...
vtkTuple< vtkVector3d, 4 > GetTransformedPoints ()
 Get the 4 points of the plane transformed using the transformation matrix set using SetMatrix(), if any. More...
vtkVector3d TransformPoint (const vtkVector3d &point)
 Transforms the give point using the Matrix. More...
vtkVector3d GetTransformedFaceNormal ()
 Get the normal to the grid plane face after applying the transform specified using transformation matrix. More...
bool UpdateForViewport (vtkViewport *viewport)
 Call this method before accessing any of the attributes in viewport space. More...
vtkTuple< vtkVector2i, 4 > GetViewportPoints () const
 Get the positions for the plane points in viewport coordinates. More...
vtkTuple< vtkVector2d, 4 > GetViewportPointsAsDouble () const
vtkTuple< vtkVector2d, 4 > GetViewportVectors () const
 Get the axis vectors formed using the points returned by GetViewportPoints(). More...
vtkTuple< vtkVector2d, 4 > GetViewportNormals () const
 Get the normals to the axis vectors in viewport space. More...
virtual void SetGridBounds (double, double, double, double, double, double)
 Set the bounding box defining the grid space. More...
virtual void SetGridBounds (double [6])
virtual double * GetGridBounds ()
virtual void GetGridBounds (double &, double &, double &, double &, double &, double &)
virtual void GetGridBounds (double [6])
virtual void SetFace (int)
 Indicate which face of the specified bounds is this class operating with. More...
virtual int GetFace ()
virtual void SetLabelMask (unsigned int)
 Set the axes to label. More...
virtual unsigned int GetLabelMask ()
void SetMatrix (vtkMatrix4x4 *)
 Set the transform matrix to use to transform the points. More...
virtual vtkMatrix4x4 * GetMatrix ()
virtual bool GetBackface ()
 Get if the face is facing backwards in the current viewport. More...
static vtkGridAxesHelper * New ()
static vtkGridAxesHelper * SafeDownCast (vtkObject *o)
 vtkGridAxesHelper ()
 ~vtkGridAxesHelper () override
void SetLabelVisibilityOverrides (const vtkTuple< bool, 4 > &overrides)
 Get/Set label visibility overrides. More...
vtkTuple< bool, 4 > GetLabelVisibilityOverrides ()
double GridBounds [6]
int Face
unsigned int LabelMask
vtkMatrix4x4 * Matrix
vtkTuple< vtkVector3d, 4 > Points
vtkVector2i ActiveAxes
vtkTuple< bool, 4 > LabelVisibilities
vtkTuple< bool, 4 > ComputedLabelVisibilities
vtkTuple< bool, 4 > LabelVisibilityOverrides
vtkTuple< vtkVector3d, 4 > TransformedPoints
vtkVector3d TransformedFaceNormal
vtkTuple< vtkVector2i, 4 > ViewportPoints
vtkTuple< vtkVector2d, 4 > ViewportPointsAsDouble
vtkTuple< vtkVector2d, 4 > ViewportVectors
vtkTuple< vtkVector2d, 4 > ViewportNormals
bool Backface
vtkMTimeType GetPointsMTime
vtkMTimeType GetTransformedPointsMTime
Friends
class vtkGridAxes3DActor
vtkGridAxes2DActor, vtkGridAxes3DActor, and vtkGridAxesPlane2DActor shares a lot of the computations and logic. This class makes it possible to share all such information between these classes. This class works with a single face of the bounding box specified using the GridBounds.
Definition at line 27 of file vtkGridAxesHelper.h.
Definition at line 31 of file vtkGridAxesHelper.h.
◆ Faces
Enumerator
MIN_YZ
MIN_ZX
MIN_XY
MAX_YZ
MAX_ZX
MAX_XY
Definition at line 45 of file vtkGridAxesHelper.h.
◆ LabelMasks
Enumerator
MIN_X
MIN_Y
MIN_Z
MAX_X
MAX_Y
MAX_Z
Definition at line 66 of file vtkGridAxesHelper.h.
◆ vtkGridAxesHelper()
vtkGridAxesHelper::vtkGridAxesHelper ( )
◆ ~vtkGridAxesHelper()
vtkGridAxesHelper::~vtkGridAxesHelper ( )
static vtkGridAxesHelper* vtkGridAxesHelper::New ( )
virtual const char* vtkGridAxesHelper::GetClassName ( )
static int vtkGridAxesHelper::IsTypeOf ( const char *  type)
virtual int vtkGridAxesHelper::IsA ( const char *  type)
static vtkGridAxesHelper* vtkGridAxesHelper::SafeDownCast ( vtkObject *  o)
void vtkGridAxesHelper::PrintSelf ( ostream &  os,
◆ SetGridBounds() [1/2]
virtual void vtkGridAxesHelper::SetGridBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
This, together with the Face identify which planar surface this class is interested in. This class is designed to work with a single planar surface.
◆ SetGridBounds() [2/2]
virtual void vtkGridAxesHelper::SetGridBounds ( double  [6])
◆ GetGridBounds() [1/3]
virtual double* vtkGridAxesHelper::GetGridBounds ( )
◆ GetGridBounds() [2/3]
virtual void vtkGridAxesHelper::GetGridBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetGridBounds() [3/3]
virtual void vtkGridAxesHelper::GetGridBounds ( double  [6])
◆ SetFace()
virtual void vtkGridAxesHelper::SetFace ( int  )
◆ GetFace()
virtual int vtkGridAxesHelper::GetFace ( )
◆ SetLabelMask()
virtual void vtkGridAxesHelper::SetLabelMask ( unsigned  int)
◆ GetLabelMask()
virtual unsigned int vtkGridAxesHelper::GetLabelMask ( )
◆ GetPoints()
vtkTuple<vtkVector3d, 4> vtkGridAxesHelper::GetPoints ( )
The points are in anticlockwise anticlockwise order with the face normal pointing outward from the box defined by the GridBounds.
◆ GetActiveAxes()
vtkVector2i vtkGridAxesHelper::GetActiveAxes ( )
The two axes are specified in order so that together with the face normal (which is point outwards from the box defined by GridBounds), they form a right-handed coordinate system.
◆ GetLabelVisibilities()
vtkTuple<bool, 4> vtkGridAxesHelper::GetLabelVisibilities ( )
◆ SetMatrix()
void vtkGridAxesHelper::SetMatrix ( vtkMatrix4x4 *  )
The matrix's MTime will be used to determine if the transformed points needed to be recomputed, when needed.
◆ GetMatrix()
virtual vtkMatrix4x4* vtkGridAxesHelper::GetMatrix ( )
◆ GetTransformedPoints()
vtkTuple<vtkVector3d, 4> vtkGridAxesHelper::GetTransformedPoints ( )
This method to compute the transformed points the first time its called since the plane points or the transformation matrix was set.
◆ TransformPoint()
vtkVector3d vtkGridAxesHelper::TransformPoint ( const vtkVector3d &  point)
◆ GetTransformedFaceNormal()
vtkVector3d vtkGridAxesHelper::GetTransformedFaceNormal ( )
Similar to GetTransformedPoints(), this method will only compute when input parameters have changed since the last time this method was called.
◆ UpdateForViewport()
bool vtkGridAxesHelper::UpdateForViewport ( vtkViewport *  viewport)
This computes the location of the plane in the viewport space using the specified viewport. This method should typically be called once per render.
◆ GetViewportPoints()
vtkTuple<vtkVector2i, 4> vtkGridAxesHelper::GetViewportPoints ( ) const
inline
Definition at line 146 of file vtkGridAxesHelper.h.
◆ GetViewportPointsAsDouble()
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::GetViewportPointsAsDouble ( ) const
inline
Definition at line 147 of file vtkGridAxesHelper.h.
◆ GetViewportVectors()
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::GetViewportVectors ( ) const
inline
These are in non-normalized form.
Definition at line 156 of file vtkGridAxesHelper.h.
◆ GetViewportNormals()
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::GetViewportNormals ( ) const
inline
There are not true normals to the axis vector. These are normalized.
Definition at line 162 of file vtkGridAxesHelper.h.
◆ GetBackface()
virtual bool vtkGridAxesHelper::GetBackface ( )
◆ SetLabelVisibilityOverrides()
void vtkGridAxesHelper::SetLabelVisibilityOverrides ( const vtkTuple< bool, 4 > &  overrides)
inlineprotected
This is more of a hack. We needed a mechanism to override which labels are drawn in vtkGridAxes3DActor. This makes that possible.
Definition at line 180 of file vtkGridAxesHelper.h.
◆ GetLabelVisibilityOverrides()
vtkTuple<bool, 4> vtkGridAxesHelper::GetLabelVisibilityOverrides ( )
inlineprotected
Definition at line 184 of file vtkGridAxesHelper.h.
◆ vtkGridAxes3DActor
friend class vtkGridAxes3DActor
friend
Definition at line 185 of file vtkGridAxesHelper.h.
◆ GridBounds
double vtkGridAxesHelper::GridBounds[6]
Definition at line 187 of file vtkGridAxesHelper.h.
◆ Face
int vtkGridAxesHelper::Face
Definition at line 188 of file vtkGridAxesHelper.h.
◆ LabelMask
unsigned int vtkGridAxesHelper::LabelMask
Definition at line 189 of file vtkGridAxesHelper.h.
◆ Matrix
vtkMatrix4x4* vtkGridAxesHelper::Matrix
Definition at line 190 of file vtkGridAxesHelper.h.
◆ Points
vtkTuple<vtkVector3d, 4> vtkGridAxesHelper::Points
Definition at line 192 of file vtkGridAxesHelper.h.
◆ ActiveAxes
vtkVector2i vtkGridAxesHelper::ActiveAxes
Definition at line 193 of file vtkGridAxesHelper.h.
◆ LabelVisibilities
vtkTuple<bool, 4> vtkGridAxesHelper::LabelVisibilities
Definition at line 194 of file vtkGridAxesHelper.h.
◆ ComputedLabelVisibilities
vtkTuple<bool, 4> vtkGridAxesHelper::ComputedLabelVisibilities
Definition at line 195 of file vtkGridAxesHelper.h.
◆ LabelVisibilityOverrides
vtkTuple<bool, 4> vtkGridAxesHelper::LabelVisibilityOverrides
Definition at line 196 of file vtkGridAxesHelper.h.
◆ TransformedPoints
vtkTuple<vtkVector3d, 4> vtkGridAxesHelper::TransformedPoints
Definition at line 198 of file vtkGridAxesHelper.h.
◆ TransformedFaceNormal
vtkVector3d vtkGridAxesHelper::TransformedFaceNormal
Definition at line 199 of file vtkGridAxesHelper.h.
◆ ViewportPoints
vtkTuple<vtkVector2i, 4> vtkGridAxesHelper::ViewportPoints
Definition at line 201 of file vtkGridAxesHelper.h.
◆ ViewportPointsAsDouble
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::ViewportPointsAsDouble
Definition at line 202 of file vtkGridAxesHelper.h.
◆ ViewportVectors
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::ViewportVectors
Definition at line 203 of file vtkGridAxesHelper.h.
◆ ViewportNormals
vtkTuple<vtkVector2d, 4> vtkGridAxesHelper::ViewportNormals
Definition at line 204 of file vtkGridAxesHelper.h.
◆ Backface
bool vtkGridAxesHelper::Backface
Definition at line 205 of file vtkGridAxesHelper.h.
◆ GetPointsMTime
vtkMTimeType vtkGridAxesHelper::GetPointsMTime
Definition at line 207 of file vtkGridAxesHelper.h.
◆ GetTransformedPointsMTime
vtkMTimeType vtkGridAxesHelper::GetTransformedPointsMTime
Definition at line 208 of file vtkGridAxesHelper.h.
