Public Types | Public Member Functions | List of all members
pqMultiBlockPropertiesEditorWidget Class Reference
This is a pqPropertyGroupWidget subclass that presents a widget to edit several representation properties of a multi-block dataset. More...
#include <pqMultiBlockPropertiesEditorWidget.h>
Inheritance diagram for pqMultiBlockPropertiesEditorWidget:
Collaboration diagram for pqMultiBlockPropertiesEditorWidget:
typedef pqPropertyGroupWidget Superclass
 pqMultiBlockPropertiesEditorWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
 ~pqMultiBlockPropertiesEditorWidget () override
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGroup * propertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It's used as the "widget" for BlockPropertiesEditor property group.
Definition at line 17 of file pqMultiBlockPropertiesEditorWidget.h.
Definition at line 21 of file pqMultiBlockPropertiesEditorWidget.h.
◆ pqMultiBlockPropertiesEditorWidget()
pqMultiBlockPropertiesEditorWidget::pqMultiBlockPropertiesEditorWidget ( vtkSMProxy *  proxy,
vtkSMPropertyGroup *  smGroup,
QWidget *  parent = nullptr
◆ ~pqMultiBlockPropertiesEditorWidget()
pqMultiBlockPropertiesEditorWidget::~pqMultiBlockPropertiesEditorWidget ( )
override
