Public Member Functions | List of all members
pqPropertyGroupWidget Class Reference
pqPropertyGroupWidget is a (custom) widget created for a PropertyGroup. More...
#include <pqPropertyGroupWidget.h>
Inheritance diagram for pqPropertyGroupWidget:
Collaboration diagram for pqPropertyGroupWidget:
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGroup * propertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It provides functions for linking standard controls with Server Manager properties as well as storing the property group.
See also
vtkSMPropertyGroup
Definition at line 29 of file pqPropertyGroupWidget.h.
◆ pqPropertyGroupWidget()
pqPropertyGroupWidget::pqPropertyGroupWidget ( vtkSMProxy *  proxy,
vtkSMPropertyGroup *  smGroup,
QWidget *  parent = nullptr
◆ propertyGroup()
vtkSMPropertyGroup* pqPropertyGroupWidget::propertyGroup ( ) const
inline
Definition at line 36 of file pqPropertyGroupWidget.h.
◆ addPropertyLink() [1/9]
void pqPropertyGroupWidget::addPropertyLink ( QComboBox *  cb,
const char *  propertyName,
int  smindex = -1
◆ addPropertyLink() [2/9]
void pqPropertyGroupWidget::addPropertyLink ( QLineEdit *  edit,
int  smindex = -1
◆ addPropertyLink() [3/9]
void pqPropertyGroupWidget::addPropertyLink ( QCheckBox *  button,
int  smindex = -1
◆ addPropertyLink() [4/9]
void pqPropertyGroupWidget::addPropertyLink ( QToolButton *  button,
int  smindex = -1
◆ addPropertyLink() [5/9]
void pqPropertyGroupWidget::addPropertyLink ( QGroupBox *  groupBox,
int  smindex = -1
◆ addPropertyLink() [6/9]
void pqPropertyGroupWidget::addPropertyLink ( QDoubleSpinBox *  spinBox,
int  smindex = -1
◆ addPropertyLink() [7/9]
void pqPropertyGroupWidget::addPropertyLink ( QSpinBox *  spinBox,
int  smindex = -1
◆ addPropertyLink() [8/9]
void pqPropertyGroupWidget::addPropertyLink ( pqColorChooserButton *  color,
int  smindex = -1
◆ addPropertyLink() [9/9]
void pqPropertyGroupWidget::addPropertyLink ( pqDoubleSliderWidget *  slider,
int  smindex = -1
◆ panelVisibility()
char* pqPropertyGroupWidget::panelVisibility ( ) const
Reimplemented from pqPropertyWidget.
◆ setPanelVisibility()
void pqPropertyGroupWidget::setPanelVisibility ( const char *  vis)
