link for live-coprocessing. More...
#include <vtkLiveInsituLink.h>
| enum | NotificationTags { CONNECTED = 1200, NEXT_TIMESTEP_AVAILABLE = 1201, DISCONNECTED = 1202 } |
| bool | Initialize () |
| Initializes the link. More... | |
| bool | Initialize (vtkSMSessionProxyManager *) |
| void | InsituUpdate (double time, vtkIdType timeStep) |
| Every time Insitu is ready to communicate with ParaView visualization engine call this method. More... | |
| void | InsituPostProcess (double time, vtkIdType timeStep) |
| Every time Insitu is ready to push extracts to ParaView visualization engine, call this method. More... | |
| void | RegisterExtract (vtkTrivialProducer *producer, const char *groupname, const char *proxyname, int portnumber) |
| void | UnRegisterExtract (vtkTrivialProducer *producer) |
| void | OnInsituUpdate (double time, vtkIdType timeStep) |
| void | OnInsituPostProcess (double time, vtkIdType timeStep) |
| void | LiveChanged () |
| Signal a change on the ParaView Live side and transmit it to the Insitu side. More... | |
| void | UpdateInsituXMLState (const char *txt) |
| void | InsituConnect (vtkMultiProcessController *proc0NodesController) |
| void | DropLiveInsituConnection () |
| Called to drop the connection between Insitu and ParaView Live. More... | |
| virtual void | SetInsituPort (int) |
| Set the port number. More... | |
| virtual int | GetInsituPort () |
| virtual void | SetHostname (const char *) |
| Set the host name. More... | |
| virtual char * | GetHostname () |
| virtual void | SetProxyId (unsigned int) |
| When instantiated on the ParaView visualization server side using a vtkSMProxy, ProxyId is used to identify the proxy corresponding to this instance. More... | |
| virtual unsigned int | GetProxyId () |
| virtual int | GetSimulationPaused () |
| 'SimulationPaused' is set/reset on Paraview Live and sent to Insitu every time step. More... | |
| void | SetSimulationPaused (int paused) |
| int | WaitForLiveChange () |
| is called on the catalyst side. More... | |
| void | OnLiveChanged () |
| Description: Called on INSITU side when LIVE has changed. More... | |
Public Member Functions inherited from vtkSMObject | |
| static vtkLiveInsituLink * | New () |
| static vtkLiveInsituLink * | SafeDownCast (vtkObject *o) |
| static bool | FilterXMLState (vtkPVXMLElement *xmlState) |
| This method will remove references to proxy that shouldn't be shared with ParaView Return true if something has been removed. More... | |
Protected Types | |
| enum | RMITags { UPDATE_RMI_TAG = 8800, POSTPROCESS_RMI_TAG = 8801, INITIALIZE_CONNECTION = 8802, DROP_CAT2PV_CONNECTION = 8803, LIVE_CHANGED = 8804 } |
| vtkLiveInsituLink () | |
| ~vtkLiveInsituLink () override | |
| void | InitializeLive () |
| Called by Initialize() to initialize on a ParaView Live process. More... | |
| bool | InitializeInsitu () |
| Called by Initialize() to initialize on a Insitu process. More... | |
| void | OnConnectionCreatedEvent () |
| Callback on Visualization process when a simulation connects to it. More... | |
| void | OnConnectionClosedEvent (vtkObject *, unsigned long eventid, void *calldata) |
| Callback on Visualization process when a connection dies during vtkNetworkAccessManager::ProcessEvents(). More... | |
| vtkSMObject () | |
Protected Attributes | |
| char * | Hostname |
| int | InsituPort |
| int | ProcessType |
| unsigned int | ProxyId |
| bool | InsituXMLStateChanged |
| bool | ExtractsChanged |
| int | SimulationPaused |
| char * | InsituXMLState |
| vtkWeakPointer< vtkPVSessionBase > | LiveSession |
| vtkSmartPointer< vtkMultiProcessController > | Proc0NodesController |
| The controller that communicates between the INSITU and the LIVE process 0 nodes. More... | |
| vtkSmartPointer< vtkExtractsDeliveryHelper > | ExtractsDeliveryHelper |
| enum | { LIVE = 0, INSITU = 1 } |
| Set/Get the link type i.e. More... | |
| virtual void | SetProcessType (int) |
| virtual int | GetProcessType () |
vtkLiveInsituLink manages the communication link between Insitu and Live visualization servers. vtkLiveInsituLink is created on both ends of the live-insitu channel i.e. in Insitu code (by instantiating vtkLiveInsituLink directly) and in the Live ParaView application (by using a proxy that instantiates the vtkLiveInsituLink).
Definition at line 42 of file vtkLiveInsituLink.h.
Definition at line 46 of file vtkLiveInsituLink.h.
| anonymous enum |
whether the current process is the visualization process or the insitu process.
| Enumerator | |
| LIVE | |
| INSITU | |
Definition at line 71 of file vtkLiveInsituLink.h.
| Enumerator | |
| CONNECTED | |
| NEXT_TIMESTEP_AVAILABLE | |
| DISCONNECTED | |
Definition at line 161 of file vtkLiveInsituLink.h.
| Enumerator | |
| UPDATE_RMI_TAG | |
| POSTPROCESS_RMI_TAG | |
| INITIALIZE_CONNECTION | |
| DROP_CAT2PV_CONNECTION | |
| LIVE_CHANGED | |
Definition at line 189 of file vtkLiveInsituLink.h.
This is the port on which the root data-server node will open a server-socket to accept connections from VTK InSitu Library.
Set the host name.
Set the host name.
That helps us construct notification messages that the visualization server can send to the client.
| void vtkLiveInsituLink::SetSimulationPaused | ( | int | paused | ) |
For in situ this returns true it there is a connection and false otherwise. For live it always returns true.
Definition at line 104 of file vtkLiveInsituLink.h.
| bool vtkLiveInsituLink::Initialize | ( | vtkSMSessionProxyManager * | ) |
The goal of this call is too get the latest updates from ParaView including changes to state for the co-processing pipeline or changes in what extract the visualization engine is expecting. This method's primary goal is to obtain information from ParaView vis engine. If no active connection to ParaView visualization engine exists, this will make an attempt to connect to ParaView.
If no active ParaView visualization engine connection exists (or the connection dies), then this method does nothing (besides some bookkeeping). Otherwise, this will push any extracts requested to the ParaView visualization engine.
| int vtkLiveInsituLink::WaitForLiveChange | ( | ) |
Insitu stops until the pipeline is edited, an extract is added or removed or the user continues the simulation. Returns != 0 if the visualization side disconnected, 0 otherwise
| void vtkLiveInsituLink::OnLiveChanged | ( | ) |
| void vtkLiveInsituLink::RegisterExtract | ( | vtkTrivialProducer * | producer, |
| const char * | groupname, | ||
| const char * | proxyname, | ||
| int | portnumber | ||
| void vtkLiveInsituLink::UnRegisterExtract | ( | vtkTrivialProducer * | producer | ) |
| void vtkLiveInsituLink::LiveChanged | ( | ) |
This is called when the state or extracts are changed or when the simulation is continued.
| void vtkLiveInsituLink::UpdateInsituXMLState | ( | const char * | txt | ) |
| void vtkLiveInsituLink::InsituConnect | ( | vtkMultiProcessController * | proc0NodesController | ) |
| void vtkLiveInsituLink::DropLiveInsituConnection | ( | ) |
Returns true if a connection is made.
Definition at line 224 of file vtkLiveInsituLink.h.
Definition at line 225 of file vtkLiveInsituLink.h.
Definition at line 226 of file vtkLiveInsituLink.h.
Definition at line 227 of file vtkLiveInsituLink.h.
Definition at line 229 of file vtkLiveInsituLink.h.
Definition at line 230 of file vtkLiveInsituLink.h.
Definition at line 231 of file vtkLiveInsituLink.h.
Definition at line 233 of file vtkLiveInsituLink.h.
Definition at line 234 of file vtkLiveInsituLink.h.
Definition at line 239 of file vtkLiveInsituLink.h.
Definition at line 240 of file vtkLiveInsituLink.h.
