Abstract class used to provide the main implementation of the ParaView session methods for the following classes: vtkSMSession, vtkSMSessionClient, vtkSMSessionServer. More...
#include <vtkPVSessionBase.h>
| enum | EventIds { RegisterRemoteObjectEvent = 1234, UnRegisterRemoteObjectEvent = 4321, ProcessingRemoteEnd = 2143, ConnectionLost = 6789 } |
| typedef vtkPVSession | Superclass |
Public Types inherited from vtkPVSession | |
| enum | ServerFlags { NONE = 0, DATA_SERVER = 0x01, DATA_SERVER_ROOT = 0x02, RENDER_SERVER = 0x04, RENDER_SERVER_ROOT = 0x08, SERVERS = DATA_SERVER | RENDER_SERVER, CLIENT = 0x10, CLIENT_AND_SERVERS = DATA_SERVER | CLIENT | RENDER_SERVER } |
| typedef vtkSession | Superclass |
Public Types inherited from vtkSession | |
| ServerFlags | GetProcessRoles () override |
| Returns a ServerFlags indicate the nature of the current processes. More... | |
| vtkPVServerInformation * | GetServerInformation () override |
| vtkPVServerInformation is an information-object that provides information about the server processes. More... | |
| vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () override |
| This is socket connection, if any to communicate between the data-server and render-server nodes. More... | |
| virtual void | PushState (vtkSMMessage *msg) |
| Push the state message. More... | |
| virtual void | PullState (vtkSMMessage *msg) |
| Pull the state message. More... | |
| virtual void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) |
| Execute a command on the given processes. More... | |
| Returns the response of the ExecuteStream() call from the location. More... | |
| virtual bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) |
Gather information about an object referred by the globalid. More... | |
| virtual void | NotifyAllClients (const vtkSMMessage *)=0 |
| Sends the message to all clients. More... | |
| virtual void | NotifyOtherClients (const vtkSMMessage *)=0 |
| Sends the message to all but the active client-session. More... | |
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| Get the ProxyDefinitionManager. More... | |
| Returns a vtkSIObject or subclass given its global id, if any. More... | |
| virtual void | UnRegisterSIObject (vtkSMMessage *msg) |
| Unregister server side object. More... | |
| virtual void | RegisterSIObject (vtkSMMessage *msg) |
| Register server side object. More... | |
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More... | |
| virtual void | GetAllRemoteObjects (vtkCollection *collection) |
| Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More... | |
| virtual vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () |
| Provides the next available identifier. More... | |
| virtual vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) |
| Return the first Id of the requested chunk. More... | |
| virtual bool | IsProcessingRemoteNotification () |
| This property is used to discard ignore_synchronization proxy property when we load protobuf states. More... | |
| virtual void | UseSessionCoreOf (vtkPVSessionBase *other) |
| Update internal session core in order to use the one used in another session. More... | |
| virtual vtkPVSessionCore * | GetSessionCore () |
| Provides access to the session core. More... | |
Public Member Functions inherited from vtkPVSession | |
| bool | HasProcessRole (vtkTypeUInt32 flag) |
| Convenience method that returns true if the current session is serving the indicated role on this process. More... | |
| virtual vtkMultiProcessController * | GetController (ServerFlags processType) |
| Returns the controller used to communicate with the process. More... | |
| virtual bool | IsMultiClients () |
| Allow anyone to know easily if the current session is involved in collaboration or not. More... | |
| bool | GetPendingProgress () |
| Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More... | |
| virtual vtkPVProgressHandler * | GetProgressHandler () |
| Provides access to the progress handler. More... | |
| void | PrepareProgress () |
| Should be called to begin/end receiving progresses on this session. More... | |
| void | CleanupPendingProgress () |
Public Member Functions inherited from vtkSession | |
| virtual bool | GetIsAlive ()=0 |
| Returns true is this session is active/alive/valid. More... | |
| static vtkPVSessionBase * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVSession | |
| static vtkPVSession * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSession | |
| static vtkSession * | SafeDownCast (vtkObject *o) |
| vtkPVSessionBase () | |
| vtkPVSessionBase (vtkPVSessionCore *coreToUse) | |
| ~vtkPVSessionBase () override | |
| void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj) |
| Register a remote object. More... | |
| void | UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location) |
| Unregister a remote object. More... | |
| vtkPVSessionCore * | GetSessionCore () const |
| Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More... | |
| void | SetSessionCore (vtkPVSessionCore *) |
| void | PrepareProgressInternal () override |
| void | CleanupPendingProgressInternal () override |
Protected Member Functions inherited from vtkPVSession | |
| vtkPVSession () | |
| ~vtkPVSession () override | |
| virtual bool | OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) |
| Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More... | |
Protected Member Functions inherited from vtkSession | |
| vtkSession () | |
| ~vtkSession () override | |
| virtual void | Activate () |
| Subclasses must call this to mark the session active. More... | |
| virtual void | DeActivate () |
| Subclasses must call this to mark the session inactive. More... | |
Protected Attributes | |
| vtkPVSessionCore * | SessionCore |
Protected Attributes inherited from vtkPVSession | |
| vtkPVProgressHandler * | ProgressHandler |
Friends | |
| class | vtkSMRemoteObject |
| class | vtkSMSessionProxyManager |
| class | vtkSMLiveInsituLinkProxy |
| bool | ProcessingRemoteNotification |
| Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More... | |
| virtual bool | StartProcessingRemoteNotification () |
| virtual void | StopProcessingRemoteNotification (bool previousValue) |
Protected Types inherited from vtkPVSession | |
| enum | { EXCEPTION_EVENT_TAG = 31416 } |
Definition at line 27 of file vtkPVSessionBase.h.
Definition at line 30 of file vtkPVSessionBase.h.
| Enumerator | |
| RegisterRemoteObjectEvent | |
| UnRegisterRemoteObjectEvent | |
| ProcessingRemoteEnd | |
| ConnectionLost | |
Definition at line 33 of file vtkPVSessionBase.h.
Reimplemented from vtkPVSession.
Reimplemented in vtkSMSession, vtkSMSessionClient, and vtkPVSessionServer.
e.g. if the current processes acts as a data-server and a render-server, it returns DATA_SERVER | RENDER_SERVER. The implementation provided is suitable for server processes such as pvserver, pvdataserver (both root and satellites).
Reimplemented in vtkSMSession, and vtkSMSessionClient.
These include server-side capabilities as well as server-side command line arguments e.g. tile-display parameters. Use this method to obtain the server-side information. Overridden to provide support for non-remote-server case. We simply read the local process information and return it.
Implements vtkPVSession.
Reimplemented in vtkSMSessionClient.
Forwarded for vtkPVSessionCore.
Use GetLastResult() to obtain the last result after the command stream is evaluated. Once can set ignore_errors to true, to ignore any interpreting errors.
Note if location refers to multiple processes, then the reply is only fetched from the "closest" process.
location identifies the processes to gather the information from.
pure virtual |
Implemented in vtkSMSession, and vtkPVSessionServer.
pure virtual |
| vtkSIProxyDefinitionManager* vtkPVSessionBase::GetProxyDefinitionManager | ( | ) |
| vtkSIObject* vtkPVSessionBase::GetSIObject | ( | vtkTypeUInt32 | globalid | ) |
| vtkObject* vtkPVSessionBase::GetRemoteObject | ( | vtkTypeUInt32 | globalid | ) |
This implementation works locally. without any code distribution. To support the distributed architecture the vtkSMSessionClient override those method to call them on the DATA_SERVER vtkPVSessionBase instance.
1 = ReverveNextIdChunk(10); | Reserved ids [1,2,3,4,5,6,7,8,9,10] 11 = ReverveNextIdChunk(10);| Reserved ids [11,12,13,14,15,16,17,18,19,20] b = a + 10;
Therefore, if we load any camera state while that property is true, this won't affect the proxy/property state at all. It will simply remain the same.
overrideprotectedvirtual |
Overridden to relay to the server(s).
protectedvirtual |
protectedvirtual |
friend |
Definition at line 225 of file vtkPVSessionBase.h.
friend |
Definition at line 226 of file vtkPVSessionBase.h.
friend |
Definition at line 227 of file vtkPVSessionBase.h.
Definition at line 237 of file vtkPVSessionBase.h.
Definition at line 250 of file vtkPVSessionBase.h.
