vtkNetworkAccessManager is used to create new connections and monitor activity of those connections. More...
#include <vtkNetworkAccessManager.h>
| enum | ConnectionResult { ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR, ConnectionResult::CONNECTION_FAILURE } |
| Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More... | |
| virtual void | AbortPendingConnection ()=0 |
| Used to abort pending connection creation, if any. More... | |
| virtual int | ProcessEvents (unsigned long timeout_msecs)=0 |
| Process any network activity. More... | |
| virtual bool | GetNetworkEventsAvailable ()=0 |
| Peeks to check if any activity is available. More... | |
| virtual bool | GetPendingConnectionsPresent ()=0 |
| Returns true is the manager is currently waiting for any connections. More... | |
| virtual void | DisableFurtherConnections (int port, bool disable)=0 |
| Enable/disable further connections for given port. More... | |
| virtual bool | GetWrongConnectID ()=0 |
| Returns true if the last check of connect ids was wrong. More... | |
| virtual vtkMultiProcessController * | NewConnection (const char *url) |
| Creates a new connection given the url. More... | |
| virtual vtkMultiProcessController * | NewConnection (const char *url, ConnectionResult &result)=0 |
| static vtkNetworkAccessManager * | SafeDownCast (vtkObject *o) |
| vtkNetworkAccessManager () | |
| ~vtkNetworkAccessManager () override | |
This is an abstract class that defines the interface. Concrete implementations of this class can be written to support tcp/ip socket or ssl or ssh based network connections among processes.
Definition at line 20 of file vtkNetworkAccessManager.h.
Definition at line 23 of file vtkNetworkAccessManager.h.
strong |
| Enumerator | |
| CONNECTION_SUCCESS | |
| CONNECTION_TIMEOUT | |
| CONNECTION_ABORT | |
| CONNECTION_HANDSHAKE_ERROR | |
| CONNECTION_FAILURE | |
Definition at line 34 of file vtkNetworkAccessManager.h.
Reimplemented in vtkTCPNetworkAccessManager.
inlinevirtual |
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>://<address>
tcp://<hostname>:<port>tcp://localhost:<port>/listen – listen for connection on port.tcp://localhost:<port>/listenmultiple – listen for multiple Examples:tcp://medea:12345tcp://localhost:12345/listenssh://utkarsh@medea Definition at line 72 of file vtkNetworkAccessManager.h.
pure virtual |
tcp://<hostname>:<port>tcp://localhost:<port>/listen – listen for connection on port.tcp://localhost:<port>/listenmultiple – listen for multiple Examples:tcp://medea:12345tcp://localhost:12345/listenssh://utkarsh@medea Implemented in vtkTCPNetworkAccessManager.
pure virtual |
Refer to NewConnection() for details.
pure virtual |
pure virtual |
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
pure virtual |
pure virtual |
pure virtual |
