pqTextLocationWidget is a pqPropertyWidget that can be used to set the location of the a text representation relative to the viewport. More...
#include <pqTextLocationWidget.h>
Signals | |
| void | windowLocationChanged (QString &) |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqTextLocationWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqTextLocationWidget () override | |
| QString | windowLocation () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Protected Slots | |
| void | radioButtonLocationClicked () |
| void | radioButtonPositionClicked () |
| void | updateUI () |
| void | setWindowLocation (QString &) |
Properties | |
| QString | windowLocation |
| template<class T > | |
Definition at line 16 of file pqTextLocationWidget.h.
| pqTextLocationWidget::pqTextLocationWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QString pqTextLocationWidget::windowLocation | ( | ) | const |
signal |
protectedslot |
protectedslot |
protectedslot |
readwrite |
Definition at line 19 of file pqTextLocationWidget.h.
