pqShowWidgetDecorator can be used to show/hide a widget based on the status of another property not directly controlled by the widget. More...
#include <pqShowWidgetDecorator.h>
| pqShowWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
| bool | canShowWidget (bool show_advanced) const override |
| Override this method to override the visibility of the widget in the panel. More... | |
Public Member Functions inherited from pqBoolPropertyWidgetDecorator | |
| pqBoolPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
| ~pqBoolPropertyWidgetDecorator () override | |
| bool | isBoolProperty () const |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
| virtual bool | enableWidget () const |
| Override this method to override the enable state of the widget in the panel. More... | |
Signals inherited from pqBoolPropertyWidgetDecorator | |
| void | boolPropertyChanged () |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
Protected Attributes inherited from pqBoolPropertyWidgetDecorator | |
| vtkWeakPointer< vtkSMProperty > | Property |
| QString | Function |
| int | Index |
| unsigned long | ObserverId |
| bool | BoolProperty |
| QString | Value |
Definition at line 15 of file pqShowWidgetDecorator.h.
| pqShowWidgetDecorator::pqShowWidgetDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parent | ||
inlineoverridevirtual |
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget invisible given the current state.
Reimplemented from pqPropertyWidgetDecorator.
Definition at line 23 of file pqShowWidgetDecorator.h.
