pqBoolPropertyWidgetDecorator is a base class for enable/disable or show/hide widgets based on the status of another property not directly controlled by the widget. More...
#include <pqBoolPropertyWidgetDecorator.h>
Signals | |
| void | boolPropertyChanged () |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
| pqBoolPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
| ~pqBoolPropertyWidgetDecorator () override | |
| bool | isBoolProperty () const |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
| virtual bool | canShowWidget (bool show_advanced) const |
| Override this method to override the visibility of the widget in the panel. More... | |
| virtual bool | enableWidget () const |
| Override this method to override the enable state of the widget in the panel. More... | |
Protected Attributes | |
| vtkWeakPointer< vtkSMProperty > | Property |
| QString | Function |
| int | Index |
| unsigned long | ObserverId |
| bool | BoolProperty |
| QString | Value |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
Definition at line 16 of file pqBoolPropertyWidgetDecorator.h.
| pqBoolPropertyWidgetDecorator::pqBoolPropertyWidgetDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parent | ||
Definition at line 26 of file pqBoolPropertyWidgetDecorator.h.
signal |
Definition at line 32 of file pqBoolPropertyWidgetDecorator.h.
Definition at line 33 of file pqBoolPropertyWidgetDecorator.h.
Definition at line 34 of file pqBoolPropertyWidgetDecorator.h.
Definition at line 35 of file pqBoolPropertyWidgetDecorator.h.
Definition at line 36 of file pqBoolPropertyWidgetDecorator.h.
Definition at line 37 of file pqBoolPropertyWidgetDecorator.h.
