This is a pqPropertyGroupWidget subclass that presents a widget to edit several representation properties of a multi-block dataset. More...
#include <pqMultiBlockPropertiesEditorWidget.h>
| typedef pqPropertyGroupWidget | Superclass |
| pqMultiBlockPropertiesEditorWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) | |
| ~pqMultiBlockPropertiesEditorWidget () override | |
Public Member Functions inherited from pqPropertyGroupWidget | |
| pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) | |
| vtkSMPropertyGroup * | propertyGroup () const |
| void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
| char * | panelVisibility () const override |
| Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More... | |
| void | setPanelVisibility (const char *vis) override |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
It's used as the "widget" for BlockPropertiesEditor property group.
Definition at line 17 of file pqMultiBlockPropertiesEditorWidget.h.
Definition at line 21 of file pqMultiBlockPropertiesEditorWidget.h.
| pqMultiBlockPropertiesEditorWidget::pqMultiBlockPropertiesEditorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smGroup, | ||
