list widget for file selection More...
#include <pqFileListPropertyWidget.h>
Signals | |
| void | fileNamesChanged () |
| Signal fired when filenames are changed. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqFileListPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqFileListPropertyWidget () override | |
| const QStringList & | fileNames () const |
| Get/Set the filenames. More... | |
| void | setFileNames (const QStringList &filenames) |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QStringList | fileNames |
| template<class T > | |
pqFileListPropertyWidget is intended to be used with properties that allow users to select files (or directories). Instead of showing a single input widget, which is the case by default (see pqStringVectorPropertyWidget), this custom widget shows a list (rather a table) with all the selected filenames. Users can add/remove files.
To use this widget on your string-vector property, set the panel widget to "file_list".
For example:
Definition at line 43 of file pqFileListPropertyWidget.h.
explicit |
| const QStringList& pqFileListPropertyWidget::fileNames | ( | ) | const |
| void pqFileListPropertyWidget::setFileNames | ( | const QStringList & | filenames | ) |
signal |
readwrite |
Definition at line 47 of file pqFileListPropertyWidget.h.
