| | pqBackgroundEditorWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr, bool forEnvironment=false) |
| | ~pqBackgroundEditorWidget () override |
| bool | gradientBackground () const |
| void | setGradientBackground (bool gradientBackground) |
| bool | imageBackground () const |
| void | setImageBackground (bool imageBackground) |
| bool | skyboxBackground () const |
| void | setSkyboxBackground (bool skyboxBackground) |
| bool | environmentLighting () const |
| void | setEnvironmentLighting (bool envLighting) |
| | pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) |
| vtkSMPropertyGroup * | propertyGroup () const |
| void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
| char * | panelVisibility () const override |
| | Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
| void | setPanelVisibility (const char *vis) override |
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) |
| | ~pqPropertyWidget () override |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| virtual void | select () |
| | These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
| | called to set the active view. More...
| template<class T > |
| | Parse a XML element as a list of label to use for this widget. More...
Definition at line 13 of file pqBackgroundEditorWidget.h.
